2002 ES300 A/C Problem
                                  in Lexus
                    The A/C light on the dash is blinking green and my mechanic says that the compressor is ok but that the high pressure switch is bad.  I called Lexus parts and they don't seem to know what the heck I'm talking about.  Does anybody else know if this part goes by another name?
Most common reason for that blinking A/C light is that the compressor input drive shaft is not rotating cognizant with engine RPM when the compressor clutch is enabled. Slipping (wet?) belt/clutch.
