2001 T&C
loidyloidy Member Posts: 2
2001 Town and country, 163k on 3.3l motor, has developed a problem. The electric fans run constantly, it is not hot out, and no ac or defrost is running. Any Help?
  • srs_49srs_49 Member Posts: 1,394
    Sticking fan relay.
  • loidyloidy Member Posts: 2
    srs_49, thanks for the quick response, is the fan relay located in the fuse block under the hood? Or is it in a different location?
    According to this info, it's behind the front bumper. Trace the wires back from the fan and see where they go.
    lFan Relay Location
  • uperparuperpar Member Posts: 1
    2003 chrysler front blower fan comes on when I turn the key and stays on full speed, even if I turn off the air control. I checked the relay and it's fine, it turns off when I take the key out.
    Please help...
  • triedtwicetriedtwice Member Posts: 1
    The blower in my 2001 T&C has started doing the same thing...have you had any luck getting an anwer?
