leaking fuel line
The gas lines above the fuel tank where leaking and I was told that they were plastic and a mouse chewed them. Is this a common problem? Also I was told that they would replace the lines with the same plastic lines and I wondered if they a better solution. I cannot afford to pay the estimated $500. very often.
I keep moth balls in the car port just in case, and they haven't been back since.
