2010+ Buick Lacrosse Interior
2»
    e_net_ridere_net_rider Member Posts: 1,380
    edited November 2010
    unknown reasons the link was not put up that way. Hopefully it works this time.
    http://www.nhtsa.gov/DOT/NHTSA/Rulemaking/Rules/Associated20Files/202FinalRule.p- - df
    Something is wrong with this site today. I have had several things not working as they should.
    Just copy the link and paste it. Delete the hyphen and space from the pdf extension.
    bobinorbobinor Member Posts: 63
    Your link is broken. Perhaps this is what you were trying to give us: http://www.nhtsa.gov/DOT/NHTSA/Rulemaking/Rules/Associated%20Files/202FinalRule.- pdf (not active, must cut and paste).
    But whatever the rules that Buick has complied with, I find no fault with the head restraints in my CXS. Whiplash is a very serious result of many rear end accidents. I think your chiropractor would likely favor a deterrent to serious neck injury as opposed to posture comfort, comfort that I find extremely good in my new car. Just recline a bit more and your head won't contact the restraint. I would not join your effort to have the rules repealed. I think safety is paramount, which is why I opted for the rear thorax bags.
    Bob,
    Yes link is messed up, Edmunds was having server trouble that day.
    Laying back is not acceptable because such poor posture while driving causes aggravation to my problems. Although it may not cause an immediate problem for you it will catch up with time/use and age. Whiplash are common enough that they get a lot of attention and have treatment. Spread those injuries out over several places on the body, sort of like treating repetitive use injuries for a wide range of occupations and it does not get the attention toward a curative action.
    And if you read enough of the rule, you'd see that NHTSA was not acting in the best interest of the driver or patient or even listening to auto makers of what has worked. They did listen but took that input and their own and created rules that are just plain overkill and remain to be seen effective.
    The head being forced toward chest very much resembles how Marines are taught hand to hand combat to kill an enemy. Much like the incident a couple of years ago where the 70+ Marine on vacation tour near Cauncan killed one of the two robbers. So you don't have to worry about whiplash? I guess not, what is to worry if you are dead? Besides, your insurance premiums might go down. It is much cheaper to deal with the dead ones.
    How long will it take to figure out what is going on via your doctor when problems start showing up caused by driving with poor posture?
    The worse injury does not occur when the head is going back but when your chin meets your chest.
    And they have blundered with this before, since the time headrests became mandatory. Some earlier designs had the headrest too stiff compared to the seat back. Thus when rear-ended, your body being propelled back, the trunk of your body sunk into the seat but your head met the stiff restraint and forced forward to chest.
    "Not repealed, but fixed!"
    Maybe they just need to consider it rocket science and use something like on the shuttles to absorb the energy. Is high density memory foam that expensive? And it returns slowly to the original position.
    BTW, I ordered mine with those thorax bags and knew there was no insurance premium benefit for them.
    So when are you getting rid of your CXS? It sounds like you've built yourself a case for insurmountable incompatibilities.
    Sometimes you have to do what you have to do. I'm hoping to hear from someone on a fix. Not a good fix, but headrests do turn around.
    I have had terrible smells entering vehicle, even in recirculate.
    Is there something wrong with my vehicle?
    According to ACDelco site, "Cabin Air Filters
    The air inside your vehicle may actually contain more pollutants than the air outside. That's why ACDelco Cabin Air Filters are designed to help filter out molds, pollen, allergens, smoke, fumes, and odors. When changed regularly, our filters can help reduce wear on your vehicle's heating, ventilation, and air conditioning system. Here are more great reasons to use ACDelco Cabin Air Filters:
    •Advanced filter media technology helps reduce particles that reach the interior, for more comfort
    •Highly durable and reliable
    •Remove most allergens from the air before it enters the vehicle's ventilation system
    •12-month/12,000-mile limited warranty (whichever comes first)*
    •Designed to fit most of today's vehicles that are equipped with a cabin air filter
    Note it says odors are filtered so I must have something wrong.
    Any thoughts?
    Cooter bfd. Apparently only those with instant notification got to see part of your post that now seems to be removed.
    The smells have been since new and prompted me to try recirculate which does not seem to make a difference. The odors are from different sources, away from vehicle, such as passing downwind of a papermill or sewage processing plant. Most I don't know the source but found them undesireable.
    I even suspected they may have forgotten to put the filter in at the plant but wanted to know just how the filter was supposed to work before removing glovebox to check. Some filters only remove particles, odors being too small. I learned from the ACDelco site that they do "filter out molds, pollen, allergens, smoke, fumes, and odors". So something definitely seems to be wrong.
    The odor thing, I asked about at dealer and was told it depended upon whether it was a carbon filter. That was before I found the ACDelco site.
    I've had CAF before in Fords and they worked extremely well. One in particular which was $100 for replacement. It had no paper whatsoever. The media was a mat of fiberglass long fibers heatset in place with carbon impregnated. Overlooked it had become totally clogged with dirt and road grime, I'm talking layers of caked on. Soaking with oven cleaner it rinsed clean like a brand new filter and worked perfectly fine afterwards. This AC one is far cheaper but have no understanding of why.
    Has anyone else noticed odors entering?
    Sevice suggested it might be from an air leak, but I have not noticed any.
    cooterbfdcooterbfd Member Posts: 2,770
    ".....Cooter bfd. Apparently only those with instant notification got to see part of your post that now seems to be removed."
    Well, the good folks here don't seem to have a juvenile sense of humor. I wondered aloud if that maliferous(???sp) odor may have eminated from your hind quarters (yes, I used the "A" word) :P
    In all seriousness, depending on the smell, it could be a number of things. I had stated that a sulfur (rotten eggs) smell could be an overcharging battery, or that had something been inadvertently been kicked under a seat or floor mat, that could be a cause. Also, formaldehyde is used in the mfr of some of the components too. If it is a musty type smell, that could be from a water leak of some sort. If it is continuous, than that should rule out another car. Other obvious scents would be antifreeze, gas, oil, etc.
    My wife drove my car for the first time today. She is quite short and adjusted the seat as she needed. She had her own FOB because mine was in my pocket all day. I later drove it and hopped in quickly because of the seat moving as soon as door is opened. It was trying to put my knees into the dash before I realized it was trying to adjust for her and mangaged to stop it by hitting one of the memory buttons on side of seat.
    What a messed up system, mine is.
    She later drove it with her FOB again and this time the seat did not move at all when she got in.
    Update. Vehicle in for memory issues.
    I see they noted that it is supposed to go to last used position. Their response is comedic. "Vehicle must be in park for memory to function."
    OK, is anyone not putting their vehicle in park before shutting down? Upon picking up vehicle the seat again went to what was the position for FOB when I first got it. And sometimes it goes to where I actually set it.
    At least, I'm guessing I will have to go over it with tech and maybe fixing this one issue will fix the rest of the memory issues.
    gberpagberpa Member Posts: 44
    It always is in park before shutting. You might need an adjuster memory module.
    I have commented on my memory seat problems before, which are relatively minor compared to some. These are apart form the 'bass ackward' programming which recalls the memory position upon 'door open' vs 'door close' or 'ignition start'. My dealer says this programming cannot be altered. At this point, I can get in before it moves much .
    Again, my config is for easy exit, memory recall and passive entry. When I use the FOB unlock, 100% of the time, the seat goes to back to or very close to my last setting. Sometimes, I check after I'm in and push seat button 1 and it may move a fraction of an inch. This is not too bothersome.
    What does bother me is on passive entry, the seat moves to a strange low and far back position. This was on my list when I got the 'clang' issue taken care of last week. I mentioned the PI0187 issue noted here and on another forum . Apparently, this is a fault. They reported on my invoice "document 2542475, ordered seat module". I'll report back when it comes in and is installed.
    edited December 2010
    We seem to be using the seat memory in the same fashion. When using passive entry I sometimes get the position you mention. Other times it actually goes to correct point. At the very least this points to a bug in the computer.
    Since getting back, I discovered it is possible to shutdown engine without being in park and not sure why you'd want to unless towing vehicle.
    Also, I forget the exact actions at this moment, but I've had it retract more than one time without going forward. (Not sure I may have halted forward motion) This gets the seat back much farther and seems to make exit and entry easier. I have to wonder how it determines the correct stops and if it is possible to program it to retract more normally.
    There is some rather "stupid" funtioning and allowance of functioning. If it is impossible to have the computer wait for a weight on seat or ignition switch change of state, I'd think they could at least insert pause into movement forward. Or even change the state of door for going forward. Wait for door closed signal, or even door locked, such as hitting lock control on dash console.
    This BS is unaccemptable.
    I've seen ads for the new Lincoln and its mention of Nav system with Sync. I noticed that there is a four way switch on steering wheel, maybe even 5 way by pressing after scrolling to the wanted point. And it seems I heard Sync has thousands of voice commands. Certainly GM could have done far better than this.
    As to not altering program, I sniff some BS. They also told me that about the headrests and it took me about an hour to figure it out. I suspect they do nothing unless GM tells them to, so as to avoid any liability.
    Elsewhere, someone mentioned using a 'delay' action in opening when using passive entry, i.e., pull open part way and then complete the action. This supposedly allows the memory recall to work better. I tried this and it improved it on a few tries. But, it didn't work 100%. This 'delay' issue also was noticed before. It came about sometimes when spouse tries to get in passenger side when I know the car is unlocked and I had passive set for all doors to open. I then changed it to 'driver' only for more secure entry as I had to go into the city a few times. Now, I reconfig'd for all doors so will see if this approach improves passenger side unlock.
    I did test drive a Lincoln MKZ standard 6 but didn't like the ride-too harsh on streets with imperfections- compared to LaCrosse. While I tried the Nav, I didn't play around with voice commands. Not too sure if 'thousands of commands' makes it easier-I have trouble remembering the few for the Buick and need to check the manual or the 'help' once in a while. What is needed and within the capabilities of PCs now is true 'voice recognition'.
    BTW, what did you do on the seat had rests, reverse them? I finally found a position that works for me with the stock location of the rests, slightly more reclined than on previous cars.
    Upon returning to Savannah, we got that horrible smell of paper mill entering vehicle again. Passengers commented about it thinking it was of the type you insinuated only to realize quite quickly it was too chemically smelley. The system is definitely not doing its job of removing odors. Also the quirky part of maintaining temp constant showed up. My son-in-law noticed the sudden blast of cold air when it wondered in that direction. Having to change the setting by as much as 10 degrees to maintain comfort after the vehicle is thoroughly warmed is just wrong.
    ".....Passengers commented about it thinking it was of the type you insinuated only to realize quite quickly it was too chemically smelley."
    This, coupled with the engine idling, and the poor FE keep leading me back to the Cat. A malfunctioning cat will give you poor FE, rough running and a bad odor (rotten eggs).
    Good thinking but at least partially wrong in this case. We have paper mills in the area and a good reason for having CAF, carbon impregnated. Fortunately, where I live has predominant winds that only once in 30 years have I smelled it.
    But on one occasion I think I smelled bad exhaust after cranking up in the parking lot. I drove to the exit with window open and stopping at street I thought I was getting another faint smell of it. The wind was coming from behind me. If it was my exhaust, I've never smelled anything like it before or since.
    Tomorrow I will pull glove box to make sure filter is installed and look to see if it appears to be carbon impregnated although ACDelco claims all their filters are to remove odors.
    That filter is rather pricey and the NAPA version is close to $50. I found another that is only about $18 including shipping, but details are skimpy. I wrote the company asking if it is carbon impregnated and what its capabilities are. I will post back if it looks like it is a good replacement.
    I need all the allergy relief I can find.
    Update on found CAF. I talked to company rep today about the capabilities of their replacement filter. They make two types, the better being carbon impregnated and was told the C at the end of the part number indicated it was carbon.
    TYC Part # 800149C {#13271191}
    Think Rock Auto or some other supplier. $9.09 + shipping and that is far less than half the NAPA branded box, but may be same thing?
    How do you get at that filter?
    I've read the manual and something about the instructions is not very clear, starting with step 1.
    "Remove the end cover located on the side of the instrument panel in the top right corner."
    Is the end cover the darker piece that would abutt the door? How do you remove it without damaging?
    BTW, another guy on the final line I'd fire. To darned wasted/lazy to put the middle screw in the panel below glovebox.
    I got the end cover off. That is the cover in step one. Slide something thin under the cover(between dash end and the cover) There are several clips that hold it in place and you only have to pry it off. I felt for the areas where the clips are, least penetration by pry device. Hope this helps someone not damage theirs.
    But now I'm stymied by the instruction to remove the screw affixed to the side of the glove box. The only one I can see is only visible if govebox is opened which is not done until the next step. If that is the one they meant, it will be a bit difficult to get at and requires a torx driver.
    The numbers & names on the filter are:
    C0930
    GM
    Duns 332766591 06:07:10
    Part 13 271 191 16:36
    DELPHI PP/PET/C
    52420930 Rev 06
    MANN
    FILTER
    CUK 2442
    Hope this helps someone.
    BTW, the filter is out of shape, particularly the side panels made of thick paper. The sides and back have self-adhering black foam weather-strip, approximately 1/4" x 1/4".
    At some locations the foam is very compressed and others it shows no sign of compression. Additionally there is no foam along the front edge.
    Also the dirt pattern on the filter is irregular and seems to match my thoughts of where air was getting past seal. I will have to check again one in cabinet to see if foam on front is needed.
    Also it appears that all air goes through the filter, no by-pass. I can see the outside air entry and where the recirculate air would come from. both above filter. Below the filter is the fan. And it appears to be carbon impregnated and of material ~ 1/16" thick and dense, making up most of the weight of the filter for sure.
    OK, here is the rest of it. Change wording of "remove the screw affixed to the side of the glove box."
    Remove screws (2) affixed at the sides of the glove box, below it.
    There is one on each end of the assembly. Then remove the screws (3) inside at the top.
    There are also clips holding it so you will need to pop them loose by pulling.
    I had also removed the panel under dash, 2 screws and some clips. It may not be necessary to pull this, but I learned the engineers and CAD people made a mistake. They forgot to account for the thickness of glove box assembly at the right hand screw and you will see a wider gap at that end.
    It is relatively easy once you understand the intent of the instruction.
    I hope someone has better luck crossing those numbers. Most of them showed up in foreign countries and for vehicles such as Opel. Mann showed it had filters for 2011 Lacrosse, but then none of them showed part numbers. Also some of the numbers crossed through their system, showing only they were GM.
    Personally, I think I will try another brand when it comes time to be my pocket. After laying a carpenter square to the sides of this one, it showed a lot of deformation and likely is leaking past the crooked sides. I will get dealer to replace and then go from there. That is I'm going to again complain about outside odors. Darned if I did not forget to check the functioning of recirculate door while I had it apart.
    Doing quite a bit of research on CAF's, you definitely want a carbon impregnated. And by manufacturer claims, some not only remove small particles and odors, they remove some chemicals from the air such as NO2.
    Afterthought on that foam weather-stripping used to seal filter in place.
    I noticed that light easily came through that foam when held to the light. It since awoke the opinion that it is not closed cell.
    So in addition to any air bypassing it because of the deformation, it is likely that air is passing through the foam itself and the less compressed, the more will bypass.
    There have been a couple of complaints about trunk space. I will say that they did not make the best use of space and the hinge system eats lots of space. Pop the cover on the right side and you'll see what I mean. There is an electric panel in there too. On a trip, my wife and daughter shopped, knowing the vehicle was full. I had to get creative on the return trip. Using the space around the spare and space in that left side I added a lot, including a full case of wine, 12 bottles and clothing. Each bottle wore heavy socks for insulation. And you still have to leave room for that hinge arm to retract when closing.
    The opposite side probably has as much wasted space.
    Another ding on my car. Since day one I've had issues with setting the lumbar support. It has made me wish the system was like in the Olds Aurora where there were two air controlled supports. It seems there is something wrong as I find it almost impossible to achieve a comfort point. Enough that I put it on my hit list for the next time in. Maybe I could get someone to explain the workings of it or even show me a picture of it so that I understand the mechanics of it, or so I thought.
    Yesterday I was on the road for five hours and tried adjusting it several times only to find that a few minutes later it was uncomfortable again. It turns out the mechanism does not stay in the set position but slowly retracts back into the seat. I'd already had the feeling that it was moving in both directions, sometimes, when pushing a single side of the 4 way switch.
    So, one more thing wrong on what is a long list. I'm beginning to think that to keep the number of complaining customers down, as they catch defective parts they save them and put them all on one vehicle.
    After having vehicle at shop 10 days, much of it was written off as they could not duplicate. Well the stink entering vehicle is obviously related to bad CAF design although it does not make sense if I run in recirculate all the time. Guess what, the loaner does it too. They wrote the falling shock boots off as no concern, the loaner has same problem, only 3800 miles.
    As to seat memory and lumbar support they said no duplication, but it went to wrong position just after I turned in keys on loaner. And the lumbar support needed airing 5 times in the less than 10 miles home. I called GM Cussing service and they acted like they were concerned. He went into explaining how it was supposed to work, the memory, and had it all wrong as to what the memory buttons do compared to the auto memory of last position. I had to correct him several times shouting into the phone to get his attention and stop him. He excused himself and came back in a minute and congratulated me on knowing how well it was supposed to work. Most customers don't he said. He kicked it to the next level and they listened to some of my concern and said they'd monitor the situation while my vehicle was at dealer.
    Thanks to those who posted new part number and info at GM tech link. When they said my car was ready in about 3 hours after dropping it off yesterday, I took a copy of that info with me.
    When I got there, they rotated the tires, that was supposed to be done last visit with the balance. They reprogrammed the seat memory. I was suspicious and shoved that info to them. They acknowledged having found that but said there was an update to that which counter-manded the part about not reprogramming and to change. They said that mine according to RPO codes, has side blindzone alert, needed an update. I suspect that will be the case for all in the near future. The only differences would be that it remembers mirror positioning I'd think which might have to do with the aiming of the alert system. So the only difference in the program should be that it does not verify the correctness of that system.
    Result, so far good. It introduced a 3 second delay and I only had about 1/2 second before.
    The lumbar support, they could not duplicate. That is very disappointing that it is not fixed because if on a long drive and it won't stay, I'd compare that to being on the way to a wedding that you are part of and a tire blows. You are also in a dead zone for phone service and no other traffic. It sucks!
    BTW, the GM rep that promised to call me between 1100 and 1300. I have no idea what time zone he was in because I'm still waiting.
    Update. They finally called after a few days and then waited to hear from dealer. I wrote elsewhere about the miserable ride, about 250 miles round trip where I adjusted that lumbar at least a hundred times trying to keep it inflated. My back is still tender and started spasming yesterday.
    I made trip to southside of city yesterday. Lumbar did not act up at all, but regardless I planned on stopping at dealer for an update. After about a half hour in Home Depot I started back and the AC system was nuts. Set at 75 degrees it was fine when I shut down. Now it was blowing hot air. Hotter than outside air. Fan was only running at a low speed. Bumping down to 73, the fan sped to a middle speed. Dropping to 69 it ran fast, but still only hot air. By the time I got to dealer I was soaking wet with sweat. I got service writer and showed without shutting off in case it effected.
    Note I had previously complained to them about wild temp swings that needed as much as a 10 degree adjustment after the vehicle was well stabilized. And it was always no duplication of complaint.
    Dropping in without an appointment, they had no loaners left, so I sat with it. The diagnosis is a problem with the expansion valve, for which he quoted symptoms and said it suddenly fixed itself, but are ordering new one and appointment for Tuesday. I had already set my mind that it was something in the automatic control system and after leaving and giving more thought I believe they misdiagnosed. That is he was just getting into it with pressure checking when the problem went away. The pressures he read could be indicative of an expansion valve, but I think he forgot about my input.
    There are the fan speeds I mentioned above. If the system was trying to work on the interior, it should have went to high fan speed without lowering the temp setting to lo which is around 60 degrees. It was 90 degrees outside. And even at that lo setting the air coming from register was only mildly cool feeling, like maybe outside air with nothing blended. Any AC input?
    But it does not stop there.
    Previous complaint about the difficulty to latch the steering column showed itself to the lady who was writing yesterday. She could not get it to latch. The manager walked up about that time and he could not either. New column on order.
    It was written they had replaced the battery again, this time for leaking. A few days later I checked oil and that yellowish fluffy stuff that shows up at battery corrosion was all over under hood. When I drove to Charleston, I noted on the far end that some of it came out and coated the top of car. A taste showed it to be mildly acid.
    And on that trip there, something with bluetooth started showing up. Did reprogramming of seat on last visit cause? Or maybe something with pushing the OnStar button on May 31 and telling them I want a new car?
    Anyway, in the past the incoming call would be auto answered. If I don't push the on screen answer, the phone itself picks up and then I have to fumble for the phone. And in the past if I left vehicle all I had to do was open phone and the call transferred from car to phone. Now it will hang up.
    I will check to see if I got a pushed update to phone and try repairing with vehicle. If that don't fix, add another complaint.
    One other possibility, although not intuitively directly connected, I have been using iPod lately on USB port. iPod is loaded with HQ music and I've learned how to convert HQ and lossless music to Apple lossless. It displays nicely on screen, but is weak in fast-forwarding. Unlike the iPod, it does not fast-forward by moving finger along the play bar on screen. It has to be done by switches and will not jump forward or backward. You just have to wait for it to scroll to the desired point. Also I added a carpeted trunk mat and definitely effects sound. I'll try plugging those speaker holes into trunk next.
    Rattle in exhaust is getting louder when it happens. I could hear it when I remotely started from across the parking lot.
    And with that lumbar issue, I hope to convince them to do something when the car goes in. Change the seat if necessary, that is the whole dang thing.
    All for now because I need to put new wheels, picked up yesterday, on my pressure washer and blast some of grime away.
    bwiabwia Member Posts: 2,913
    edited June 2011
    I don't mean to be rude or insensitive but with so many complaints I must assume GM sold you a lemon or you are an impossible customer to please. If the car is indeed a lemon why didn’t you return it under the 60-days no questions asked money back guarantee and buy something more to your liking?
    With every purchase we have to make comprises especially with mass produced goods. In other words, we have to take the good with the bad so long as the product is not defective or fraudulently marketed as being something other than what it is. If the CXS is not right for you then you should cut your losses by dumping it and buy something else rather than be miserable with complaints ad nauseam.
    A) That 60 day thing had ended by the time it was delivered.
    B) Things are showing up over time.
    C) Dealer can't always duplicate.
    D) If this was a computer or a refrigerator I had bought, it would have been returned and money back demanded.
    If you've read my posts of the last couple of days, things are still showing up or showing up in such a way they are verifiable by the dealer.
    GM really needs to step up quality and fixes or this will be the last GM anything I ever own.
    Two bad batteries in a seven month old car.
    Defective oil filter from factory.
    Cabin air filters will not work as advertised because of the manufacturing process.
    Three trips alone for the seat memory issue.
    Three so far for the AC acting up and taking it in for the parts they ordered will be the fourth trip. And I'm quite sure they misdiagnosed the reason so that will be at least five trips.
    Three so far for the lumbar issue. Dang thing won't act up for them.
    Three so far for the exhaust rattle upon start. Again it has not done it for them. But the last few times for me it was getting louder.
    Twice so far on the boots falling down on rear shocks. Waiting on GM response.
    I'm going to push this darned head rest issue again. It may be as I wrote months ago to others that are complaining about them, "It is because of NHTSA." I see the same issue in nearly all new cars. I watched as a lady drove off in her new BMW. She had that seat inclined so far that the airbag and seat belt would be nearly useless in a really bad crash. In that position the G forces would not slam her heart against the chest but instead pull it toward her abdomen, almost certainly ripping arteries loose. So if you like that position of being reclined, think it over. And it is not like NHTSA would not have data. There are lots of cases where the front passenger was riding/resting in that position and their outcome was far worse than driver.
    I have absolutely no idea when GM will get the cabin air filters fixed. I have no idea when they will fix XM reception issues.
    The list is way too long for any vehicle. And I'm going to add some more over in exterior.
    crankeeecrankeee Member Posts: 298
    bwia: I agree with the comment about mass produced goods. We just went thru the drill with a bad ice maker control on a fridge and after a month of delays and excuses from the extended warranty company, the retailer took back the unit and provided a replacement due to inability to repair.
    A $30-$40,000 automobile that is less than a year old is a different level or situation in my world when major components fail. The manufacturer has the right to R&R to correct the problem(s). Failure to correct real problem(s) raises the issue of what is done next. I hope I am never there with a new car after having to go nuclar (as the man said) when the fridge could not be fixed. In Alabama when your new A/C goes out you go nuclar right away and esp. when it is your house system or your new car.
    Good luck with the repair Rider.
    Crankee
    Update, I got a call at 0730 this morning, one of the exceptionally few times that I was still sleeping then, and answering machine got it.
    My car was dropped at dealer a week ago yesterday and that was an appointment they set for expected arrival of parts.
    Customer service may have forwarded the FAX I sent them to the dealer and they might be trying to get most things from that hit list. The message said, "Thank you for your patience. They were waiting on muffler system for exhaust rattle."
    I will drop by later today, I hope. And there may be an item I did not have on that list, the door seals breaking apart at the factory splice point. And maybe I'll learn what they have done.
    I did get a phone call from Buick customer service a day or so after I dropped vehicle. I really chewed her and then apologized for being indignant. Not her fault, but hoped to light a fire under her so that I did not become just another lost in the crowd.
    Yes, building an automobile, assembling all those parts is something. But to start with bad parts?
    I told her, "GM could not even make parts that have been around for many years. A defective oil filter (missing anti-drainback valve), two bad batteries, and defective air filters from bad design are just the beginnings of issues."
    The one thing I was told repetitively was, "If it was designed that way there is nothing we can do."
    I smell manure. That is the last thing any customer wants to be told, which translates to "we are intentionally building crap and there is nothing you can do about it."
    I mentioned elsewhere they put me in a new Regal. It has the same lumbar system it seems, at least how it is controlled. There is no way you can adjust the upper and lower portions separately which is just plain dumb.
    But it does seem to be a bit more comfortable in the Regal. The Regal seats are a bit smaller and the impression I got is that they use the same bag parts or same size. It is like the engineers had the CAD people just enlarge the seat from the Regal. And then re-position the bags slightly to accomadate the larger seat. Bad move, which GM has been guilty of repeatedly. That is their newly designed vehicle is not from the ground up, but often uses parts from totally discontinued vehicles. Taking axles from trucks, suspensions from a 90's Bonneville, updating an engine from AMC, and throwing new sheetmetal around it does not make for well designed vehicles.
    May be option on some levels.
    I thought I found the way it was supposed to work when in a CXL loaner. It was so much better. A full five seconds to get in. Also it did not do the stupid "move the seat" if driver door was open and D/S rear door was opened.
    I got mine back and it is as before or worse. I often went to the far side of vehicle so the seat would not move ahead when putting or retrieving something from the vehicle.
    The dealers answer, or really GM's answer, is to make them all alike, stupid or not. According to dealer, the tech is told to compare to a newly received vehicle and then go from there according to their directions. Yes GM, the idiots who made it stupid in the first place.
    The worse? Yesterday, upon arriving at our destination, my wife got out and just as I got out, she opened rear door on passenger side and my GD seat moved ahead. In what world could anyone think that proper? So of course when I get back in I have to fool with buttons to position it. GM SUCK
    Check your CAF first. I have not been driving any dirty dusty areas. By 10K I noticed that the airflow was diminished with full automatic setting. There is a dusty looking area covering the center of the filter and that is apparently enough to restrict flow.
    Perhaps there are better filters on the market that use more media, surface area.
    I like the idea that they decided to filter the inside air, but it will require far more filters than they suggest. I usually set mine to recirculate manually, so of the 10K likely at least 8K were recirculated air, unless there is some sort of defeat when using heated air or defrost.
    If driving dusty conditions, I'd say you need to consider 3K a change point. That is unless you consider an early death of the fan motor insignificant. GM had some notice involving restricted air flow and motor.
    Also I would consider it paramount when checking AC system. If you are not getting full flow across evaporator, you can not get correct readings.
    BTW, pressures are not the correct way for charging systems with expansion valve which I'm told this vehicle has. There are two methods, weighing in the exact amount of freon, and what is called "approach temperature". The "approach temperature is determined by the system manufacturer and works best at temperatures approaching maximum outdoor operating temperature. The proper amount of freon is reached by adding the approach temperature to the ambient temperature and then measuring the temperature of the liquid line after the condensor. The expansion valve will operate mainly according to the temperature at the evaporator. That is it should be putting the best amount of freon into the evaporator to maximize cooling.
