Noise coming from front end.
luckycaliluckycali Member Posts: 17
edited August 2014 in Lincoln
I have put in new struts all the way around and im still geting a noise from the front like if i need new struts. I took my car to the shop and was told that i had to replace my left sway bar link and my right tie rod. I have put these parts in the car already, and still have the same noise. Anyone know's what it might be?
  • cdnpinheadcdnpinhead Member Posts: 5,639
    Sway bar bushings.
    Take it to the bank.
  • akirbyakirby Member Posts: 8,062
    And if I'm not mistaken you have to change the entire sway bar to get the new bushings, unless someone found a way around it.
    Yeah, you're right. What used to be a $40 90-minute job (even if you'd never done it before) is now a much bigger deal.
  • toomanyfumestoomanyfumes Member Posts: 1,019
    The early LS's are known for the knock from the sway bar bushings. There is an updated sway bar with bushings. SO yeah, I think you have to change the whole sway bar.
    2012 Mustang Premium, 2013 Lincoln MKX Elite, 2007 Mitsubishi Outlander.
  • luckycaliluckycali Member Posts: 17
    Thanks for the answer guys.
