Visitor Agreement.
But that's supposition. If you were William Shatner, I'd guess it could be a gremlin under the car pulling parts off and tossing them onto the street. Have you seen a man with black hair, a dark suit, and smoking a cigarette standing off to one side recently, muttering something like "Submitted for your approval..."? (Sorry, very obscure reference.)
I only heard it once last night, and then the noise was gone this morning. I did take it to Hyundai again this morning before work, and when they test drove it, they could not duplicate the noise. They did look everywhere...even took the tires off but found nothing wrong with my car. *knock on wood*.....I haven't heard the noise again.
It is actually a pretty simple device and building a quality one in a new car is not a challange. For yours to have trouble at 2600 miles is not normal at all. If your car was an airplane it would have fallen from the sky. I don't get why a lot of the people who responded don't get that.
Parts used in an airplane are held to a much higher sampling standard than those used in cars. (units pulled from the factory line for random testing)
She obviously had a major component failure. And even more obvious, very prematurely. But since we don't read about this being a troublesome tranny, proves this is one of an extremely low number of isolated incidents. Possibly the only one. There are some weird things happen at a factory level that sometimes get discovered, and sometimes (most) not.
I'll never forget many years ago discovering a small carved wooden boat that was installed INSIDE the watercooling track of an old Evinrude outboard motor. The engine would overheat and no one could figure out why. Some lowlife factory worker who decided to play a prank, PUT that carving inside the motor. Had it lodged someplace else that didn't block the flow of cooling water, it might have never been discovered.
I guess it's a good car, but I'm still not 100% happy nor do I feel 100% safe.
I bought my 2010 elantra gls on september 2010. After putting around 12k miles on it, the trans is giving me unusual feed backs. Jerks when it upshift, shakes when slowing down, and my engine will rev 200-500 rpm even after I let go of the gas pedal.
The car drives fine as current it's at 16k, I am hesitating to take it back to dealer I bought it from, because I heard they tend to 'break' things when they try to fix something, heard that while I was in the lounge last i took it in for service.
I have no history of dealing with such matter, any adivise would be appreciated. Oh yea I've check the level of the ATF, it wasnt the problem.
I think this may fall under the NYS Lemon Law? Anybody know? I am do so done with Huyndai cars, and their service is below grade.
Also, I was just informed by the dealer that I might have a problem if I choose to have my scheduled maintenance service performed by a mechanic other than Hyundai's ??? Anybody got any info on any of this, I'd appreciate it.
By federal law you can have your car serviced wherever you like with no impact on your warranty. However, you do need to maintain your maintenance records in the event you need to make a warranty claim.
The only potential problem with not using the dealer for service is if the shop you use doesn't use parts/supplies that meet OEM standards; i.e. they use the wrong transmission fluid or oil that doesn't meet the specs stated in your owner's manual.
Lemon laws vary by state, but typically they involve three or more attempts to repair the same vehicle within a limited time period (like, say, the first year). I'm in Illinois so I can't really say what NY's requirements are.
I feel for you with the trans problem. For a little perspective, my wife had an '01 Elantra that was almost perfectly reliable over 10 years & she recently bought a '12 Elantra to replace it. My ex-wife, BTW, had a Camry trans fail on her. No manufacturer is immune to these sorts of problems.
I would suggest that if your local dealer isn't being as helpful as you think they should be (and from what you've said they don't sound that good), feel free to use another dealer or call Hyundai customer support (http://www.hyundaiusa.com/contact-us.aspx) & ask for their intervention.
Thanks for the info. I will give them a call tomorrow.
1. Cold starts: first thing every morning when the car is not warmed up, when the tranny shifts from first to second, there is a dramatic lurch forward as though the tranny is holding back and then releases the car into second. This situation diminishes as the tranny (and fluid) get warmed up. After a recent flush of the transmission, the issue is now occuring with shifts from second to third gear
2. Reverse delay: there have been instances when the car takes 3 seconds to engage into reverse.
3. Rev surge: The engine revs up several hundred RPMS just before the tranny shifts from 3rd to 4th and 4th to overdrive.
4. Manually downshifting to 2nd gear: tranny takes 3 seconds to actually engage into 2nd after manually shifting
5. I am getting intermittant "slamming" from upshifts from 2nd to 3rd.
Mzonnet: you posted that you had some of these same issues a year ago. Did you get them resolved at all?
For proof of this, here are just 3 random links of threads that describe perfect examples of what I'm talking about. I have read every post of all three links. I recommend starting at the very beginning of each. I suspect that before you get even 1/4 of the way through each one, you will become a believer. And without question you will be if you make it to the end of each one. Some stats just can not be ignored.
http://townhall-talk.edmunds.com/WebX/.f0d9b0e/539
http://townhall-talk.edmunds.com/WebX/.f19ab51/96
http://townhall-talk.edmunds.com/WebX/.f0d3fb5/2124
Now here's the kicker #2. That receptacle I tested in their kitchen??? they said was installed by a so-called licensed electrician...obviously one who was NOT doing anything they remembered in their school of trade to get that license. Either that or a Monday morning hangover install...either way, totally unacceptable.
Certain repairs on cars are not much different....but you don't discover the incompetent repair till it is too late.
Ignition (x2) - it locks up and gets very hot
AC - valve replaced
Drivers Sunshade Mirror cover - cracked mirror cover -replaced
Shifter knob replaced - silver trim was peeling & sharp
Driver interior door handle replaced - silver trim was peeling & sharp
Trim under windows - cracked -being replaced
Trim along windshield - cracked - being replaced
Trim under roof rack - cracked - replaced
Issues they won't repair:
Clear coat on paint exterior door handles bubbling
I have the upgraded cloth seats and they're complete crap - they stain when you look a them
Trim around sun roof is cracking
I live in Florida so I am probably seeing sun damage earlier than most. I still enjoy driving this car and it is the perfect size for me. But I'm over all the repairs. My warranty will be up in a few months.
They found that clunking from front was from sway bar end links, so they replaced and car drives 100 times better. The also found hatch supports needed to be replaced, and they would under warranty.
Today, after picking up car from completed repairs, I was driving to get my daughter. I went into her school to get her, and when I put car in reverse - reverse was nearly gone. It did a neutral-drop type shift and suprised the heck out of me. Come to find as Jettech5 says that it takes it 5-10 secs to engage - it is almost like being on a trans brake in reverse. Took car back to dealer and they will "contact me tomorrow" with an update. Any suggestions as to what to ask for in frustrations? Is there a lemon law in IL if it needs another trans?
Old forum, so I'm not sure what good posting here will do. In the old days (the early to late 1990s), Hyundais were infamous for being junk cars. A friend had one. Yes, they had the warranty but they didn't care how many times the consumer had to bring it in to be fixed for the same problem.
A transmission dying at under 3k miles is not just a part not working. It's a major repair and I would be outraged. It's now 2014 and this is the problem about which I am concerned and Consumer Reports needs to follow this (they rated it on a drive test just under the Subaru in their 2013 CR car mag). The parts I've seen - battery, tires, spare - and the unseen parts (they're called unknown risks - are cheap and the rest are likely cheap (like my dealership where the guys don't know how to operate the computers in the car).
Sarah, I'm definitely on your side. I have not experienced it but understand your anger and frustration. I haven't had anything like this happen to me but I've seen the cheap. I've mainly been dealing with dopes at the dealership. They're the face of the company and since they've proven their lack of worth, why should I trust anything beyond it.
Again, not surprised. I figure I'll get some reporters on the issue when problems come up. If they're enough issues and they may affect your life, attention will be placed on the manufacturer (maybe).
I read a bunch of metric-related data on the internet. Many of you probably saw the push for Hyundai during the Super Bowl. It's the adverting/marketing that's pushing up their mark. It's also getting y'all to register on Hyundai's website so they can keep track of you and market to you (and me but I clearly told them nothing was going on their website from me and I refused to give them a VIN).
The cars supposedly got better since I last look at the piece of junk and took two for a test drive many years ago. It feels good and I am concerned about what will go wrong because customer support at corporate is useless and I don't trust the local service at the dealership to repair the car right since I was lied to by the service manager (explained by the general manager - he was just trying to bring in business).
