Do 1999-2003 Jetta's have known issues? (100k+)
in Volkswagen
any know issues with these models, I'm looking mostly at 1.8T, are they pretty reliable?
I think what you are really asking is known as MKIV (Mark four) VW platform which included Jetta, Golf and NB (New Beetle)
Some of the early issues were resolved by voluntary recalls by VW (Window regulators, MAF sensor,EGT seonsor... etc.) Also, each of the available 4 engine-types had their own idiosyncrasies.
The 1.8T which you ask about REQUIRES synthetic oil and hi-octaine fuel. It also falls undher the MAF sensor and coolant-sensor issues. (once replaced, they should not be a problem.) Of-course, the standard knowledge of how to care for a turbocharger should be understood also.
Then there are issues of specific model years like the foam inside the front fenders which comes loose and thru vibration, wears the paint on the inside of the fender. In some cases, ihis causes rusting of the front fenders. The 12-year/ unlimited miles corrosion warantee still covers this problem to this day.
There are still many of the MKIV VWs still on the road today. It is not unusuall to get over 150,000 miles on them. Here in Vermont, it is EXCEEDINGLY important that the body does not rust into oblivian before the rest of the car. This is why I like the 12-year/ unlimited miles corrosion warantee which is not found on US nor Asian makes.
Your questio is kinda vague... Do you have a specific question which we can help answer?
I took this car today for a test drive
http://sfbay.craigslist.org/scz/cto/2159711910.html
The car looks, sounds, and drives very nice, has good power, I was wondering if all the replaced parts means it's in good shape, or perhaps there are different problems needing attention, I mean, would it be safer to get a car that hasn't had allot of work done or vise versa, Thanks!
To be honest, none of us can answer this kind of question about an individual vehicle we haven't seen. Each used car is unique, and anticipated issues can be related to care & maintenance... and luck.
If you are strongly considering this vehicle, I'd recommend asking to take it to a local mechanic for a check. Some of the recent services have been listed, which is nice, but it's hard to tell if belts and other components have been replaced as needed.
MODERATOR /ADMINISTRATOR
Review your vehicle
I have found such specialists in every city I have lived in - even now in Red Wing, MN (pop about 20k) there is a European-specialty repair shop that has proven his worth in maintaining my car.
I bought a 2001 VW Jetta Wagon last year and brought it to my VW shop and they identified three major areas that needed service right off the bat - timing belt, brakes (easy for any mechanic) and a leak issue with the sunroof.
Why? because they knew to look for this stuff.
As they did the timing belt repair - they also discovered that one of my two cooling fans were not working.
All said, a little over $1000 invested after the purchase and my car has been running solid ever since...but had I brought it to them before the purchase - I wouldn't have missed those issues and I could have either not bought the car or negotiated a fair price.
All in all, I like my little wagon and it has been solid since I let my mechanics spruce it up.
I've had my car for a couple of years and just recently I have run into a problem with my transmission.
This is basically what is going on. I drive 40 miles to work when I drive in the morning and there is no traffic the car is fine. But in the afternoon when there is traffic the rpm gauge drops rapidly and bounces right back up to where it was once I let off the gas. Then after a while the rpm hiatus jumps to 4-5000 rpms when I'm only going 60 miles per hour and doesn't shift at all......but if I turn off my car and turn it back on it shifts normally . It only happens after awhile in traffic and always around the same stretch of highway. At first it had a check engine light when I took it in for service. When i went to pick it up they said nothing was wrong and the check engine light hasn't come back yet....any ideas?
