'04 jetta fuse box above battery
                                  in Volkswagen
                    I have a 2004 jetta that has a short causing the fuse box above the battery to short out, it has happened twice now and we replaced the fuse and fuse box but we don't know what the underlying issue is. Has anybody had this issue before? The check engine light is also on and gives no code but says cooling system. Are these issues connected?
I believe you are really referring to the power-distribution-unit (PDU) mounted on top of the battery. The fusebox is INSIDE the vehicle located on the side of the dashboard when the drivers-door is open.
However, It is not unusual for some of the screw-down connections within that PDU can corrode. a poor-connection can build-up enough heat to melt things.
THIS IS NOT A "SHORT" - it is simply a poor connection. Heat is generated when resistance goes up.... basic electricity.
To prevent this kind of thing from happening, the screw-down connectors should be regularly snugged-up and perhaps even removed and cleaned.
I personally check mine about once a year... along with snowscreen-cleaning and other maintenance items.
It is ENTIRELY possible that the wire has poor connection to its termination. (rather than the termination to its screw-down)
This is simple to diagnose. Use voltmeter across the connection in question whilst there is current passing thru it. If you measure any more than say 30mV... then you have isolated the bad connection.
(A good connection should have 0volts across it with full-rated current passing thru it.)
The cause of this is that over time, the envrionment under the hood of a car is corrosive to all the exposed electrical connections. Even the slightest winter roadsalt into a connection can become an electrolite. Dissimmilar metals with an electrolite between them causes copper to to turn green (Copper-Sulfate). This green stuff is NONconductive to electricty.
You can continue to replace parts... or FIX the problem... your choice. Anyone knowledgable with basic electricty should be able to pinpoint the problem and effect a long-lasting fix.
Need help please!!!!
There are not a lot of things on the MKIV to PM.... but this is one of them.
PM = Preventive Maintaince
Oh -- and to answer your question.... use a VOLTMETER to determine the problem and then fix it. This is simply a bunch of fuses.... how hard is it to make sure voltage is on both sides of each one?
Dont forget that your radio may go into "SAFE" mode when you disconnect the battery unless you use a back-up power source.
I would argue that ANY vehicle which you ignore the recommended major preventive maintenance could end up the same way. Hence, save yourself some grief and prepare to blame your next car now. - LOL
Also, a "recall" (by federal law) is solely for proven SAFETY issues. Perhaps you are suggesting a TSB (Technical Service Bulletin) should be created?
