Note - I was never thrilled by my 07 TL noise levels; I replaced the original tires after 40k miles and put on some very quiet tires (Turanza Serenity), but after about 30k miles they turned REALLY noisy and ended up going back to OEM tires. Acuras, at least, don't do well with non-OEM tires I discovered.
I test drove the CR-V EX-L again today, a week after the RDX. It really wasn't bad, mainly higher pitch 'wind-like' noise around 80mph. I thought 'road noise' was quite well handled. I'm guessing the wind noise is due to the large rearview mirrors and roofrack, etc. I'm not ready to play roulette with a Ford or Chevy, I'm afraid, so I'll probably go with the CR-V ...
What occurred to me last night was this ... I have read that some cars (RDX, Buick Enclave) are using 'active noise cancelation' (ANC) to quieten their cabins. This is, to me, a great idea. I've use Bose ANC headphones on planes and such and they do wonders to block out the mundane 'drone' of engine, A/C, etc. I was wondering if there are variations on this that can be applied to cars as an after-market solution ... probably not due to the need for careful placement of microphones, etc. But something worth thinking about. I also wondered if it would work to use ANC headphones in the car ...
I made sure I wasn't stepping on the break and accelerator at the same time so that couldn't be it. Anyone notice this?
I recently bought a used 2008 CRV AWD. We will be using it as a toad behind our motorhome
and some light off road use. I spent months researching this and similar vehicles. I chose the
CRV because it will 'flat tow' (all four tires on the ground) without modification, it's legendary reliability, economy and resale value. I was forewarned about the road noise but I got a lot more than I bargained for. Years of time in aircraft have deafened me but the road noise is still overwhelming. In order to listen to the radio one must increase the volume to an uncomfortable level, conversing with another passenger is difficult. It's road noise is nearly unbearable on some
road surfaces while on others it's tolerable. Thus far I've spent a couple of grand trying to quiet it down. Dash cover, seat covers, more carpeting, blanket folded up with the spare and jack, $100 worth of
sound deadening material and six days of labor ripping out the interior and gluing it in. New Michelin's at $1100. all in an effort to quiet it down. The result thus far is moderate improvement.
. The rear wheel wells seemed to be a major source of the road noise, that appears to be the area
that improved the most from the application of the sound deadening material. I've yet to do the front doors (the back doors were a royal pain). The noise is still much greater than it needs to be.
I regret not following progress with a db meter and hope someone does.
Future plans include treating the front doors and getting the CRV on a hoist and shooting
polyurethane foam into the numerous holes in the floor pan. If I'd thought of it I'd have shot foam into the holes in the floor when I had the interior ripped out. I'd recommend it to anyone who embarks on a similar quest for peace and quiet.
Now; a word of scorn for those apololgists who happily sacrifice ride comfort for fuel economy: BUNK; my 2003 DeVille gets better mileage (average 25.6) than the CRV and does it with very little road or wind noise and vastly better handling and ride comfort. Unfortunately it wants to be dolly towed and is not so sprightly off road as the CRV..
I will happily entertain suggestions from others who have had success in quietening the otherwise fine little CRV.
Oh, c'mon...is it really THAT bad??
I agree, that one downside to ALL Hondas is road noise. Each new model get's better but they still have room to grow. We have had one of every CRV generation and still have a 2003 we bought new and a 2013. The 2013 is MUCH quieter than the 2003 and I can assure you your 2008 is quieter than our 2003.
When I was still selling them, the road noise bothered very few people but once in awhile it would be an issue. You are probably comparing it to your De Ville and that may be part of the problem. I just tune it out and don't give it a second thought.
Tires make a difference too. The new Michelin Defenders on our 2003 made a noticeable improvement. There is a product called Dynamat that can be installed under the carpet and in the door panels that I've heard make a huge difference.
That said, yeah, Honda has long been taken to task for this and they have improved but they still can do more to quiet down their cars.
If you do flat tow your CRV, MAKE VERY SURE you follow the towing directions or you WILL ruin your transmission. So many people didn't follow the directions and destroyed their transmissions and they tried to blame it on Honda that Honda quit saying they could be flat towed.
Then I had the customer that didn't release his parking brake completely and TOTALLY burned out his rear brakes and rear differential. It had gotten so hot, it stunk up the entire shop.
Of course, he accepted no blame and refused to admit he left the parking brake partially on.
It is a very subjective issue and everyone is different, but truth be told "honda is a noisy ride"
