transmission slipping in 03 acura tl
hello,
just recently had trans oil changed in my 2003 acura tl. prior to changing it, i had slight delay when shifting from 2nd to 3rd. new oil seemd to help but didn't cure it completely. my mechanic didn't seem to think there was a transmittion issue at this time. today i ran some errands and notice on 4 different occasions a big delay and slight jerkyness when shifting from 1st to second. i checked the oil with the car running and it seemed to be a bit full. not sure if this would cause this issue. having owned 4 hondas in my life with no trans problems i'm hoping this acura isn't failing me already.
Is there a special acura oil that should be used when changing the trans fluid and is there a filter that should be changed in the process?
Any thoughts on what may be causing the issue or comments in general would welcome. thanks, owen
I had the Type S and the tranny went out at 30k, the dealer claimed they fixed it on a TSB recall, tranny went out again at 36K miles. I got frustrated and sold the car, but if you look back in boards you will see the many complaints for those model years 2002-2003-maybe even earlier.
How many miles are on your car? I ask because Honda/Acura extended the warranty for your transmission to 100,000 miles for those model years. I don't know if there's a time limit, but if there is maybe your Acura dealer would give you a pricing concession to repair or replace it. I would bargain hard because Acura has acknowledged (at least implicitly) that the transmissions of the '00-'03 TLs are problematic.
Good luck, and please let us know the outcome, since it could help others in your situation.
I also had a transmission go out on my 2000 TL last year. The transmission slipped for many many years but they always maintained it was ok. It went out after the 100 k passed but they took 12 days to contact me with their decision that they would do nothing although the transmission issues began at around 60,000 miles. We were in limbo for those 12 days. My daughter drove this vehicle and hated every minute of it with the transmission slipping every day. We bought her a new Altima with a CVT and she loves it.
Acura sales are terrible in general and no other brand has the transmission issues they have.
Acura may not survive if this continues and they only have themselves to blame. Butt ugly designs, the worst transmissions and a dismissive national customer "care" division.
The Car Show on Speed Channel ripped Acura a couple of weeks ago.
MODERATOR /ADMINISTRATOR
Review your vehicle
I had the 2003 TL Type S, tranny went out twice and I sold it. I then passed on the 2004-2008 TL because I thought it just blended in too much with the accords and camrys, not a bad thing but I still passed.
Its two years now since I pulled the plug and the 2009 TL SH-AWD and the car is bullet proof, no rattles, squeekes or tranny issue and all I get is compliments. Car shows rip a lot of manufacturers including BMW and Mercedes so i dont see your point here.
These car guys all were critical of Acura's dismal sales, their ugly designs, and their quality. They were unanimous with their criticism across the board. It is unlikely that 4 car guys would be this critical of the brands of BMW and Mercedes.
I hope your TL remains bullet proof. You have more faith in this brand than I have which is suprising since you had 2 transmiisions go out on an '03 TL.
My 00 TL was "bulletproof" for a few years and then the tranny began slipping every day. Acura said it only affected the '00 TL. Then the 2001, '02, the '03s and on and on for the TL.
Same thing with the MDX. Acura minimized the problem and more and more years were similarly effected.
Acura has not solved these problems and couple that with the worst customers service I've ever experienced, this brand is in trouble.
These forums are loaded with disgruntled customers of Acura 's transmissions and the interest in filing or joining class action lawsuits grows every day. Check the MDX boards if you don't believe me. Facebook too.
I would unload your current TL in a heartbeat while it is still bulletproof.
To answer your question, we have 2 G35X sedans, an '04 and a '07. I will either give the '04 to my son or trade it in. The '04 had prematurely wearing brakes and Infinti replaced rotors twice and pads twice at their expense. There were no hassles from them re the brakes. The first replacement was pursuant to a recall and the second replacement was done as good will. I have 86,000 miles on the '04 and have not spent anything on the car except oil and routine maintenace. The 07 has also been problem free. Their customer service was excellent.
I want a small AWD crossover and will problably buy a 2011 Infiniti EX 35. Also looking at the Mercedes GLK, the X3 or the Q5.
I do hope you have good luck with your TL. I've owned Preludes, CLs, several Accords and a TL. The Acura line has clearly declined in every respect.
Knock on wood this TL puts a smile on my face every I fire it up.
Next stop for me is the E63-hopefully.
I called the dealer and they said tough luck. Referred me to Acura. Talked to them, they said I am out of luck too. Too bad the extended warranty (100,000 miles) didn't apply since I passed the 7yr 9 mth limit. Asked for some good-will. They said "out of our parameters ... can't help you." And I was just thinking of getting a new Acura before the problem happened.
This episode, plus the numerous similar unhappy Acura owners' sharing on the Internet of Acura's lack of goodwill towards this transmission problem experienced by so many, has convinced me not to own any more Acura's or Honda's. Even if their newer transmissions are better, their attitude in not helping with repair costs for a poorly designed transmission, and the unhelpful response at the dealership, leaves me unconvinced that they will be reasonably helpful to customers, withoutstanding customer loyalty.
Good luck!
