2011 and 2012 Sonata - Pulling Problem
 sonataorcamry
                    Member Posts: 5
sonataorcamry
                    Member Posts: 5
                                  in Hyundai
                    Just how prevalent is the left and/or right pulling problem with Sonatas? I have read that in some cases a tire switch will fix it but... So among those of you who have been driving 2011 Sonatas or the new 2012s, what have you experienced? Currently driving a 2000 Camry LE with 120,000 miles and looking at Sonata GLS with Pop. package or the new Camry. Thanks for your input.
LG
LG
Test drove 3 2012s last weekend. 2 had bad noticeable Right pull. One seemed to drive pretty straight.
I dont know how on earth 1 year pulls left and the next pulls right. They obviously tried something that didnt work. At this point im weighing my options before investing in a car that they cannot align straight. Hyundai does not know how to fix this.
The 2009 tracked straight with no problems for 3 years. The 2012 is annoying to drive, requires constant effort to keep it going straight. It will run right off the road in about 200 feet @ 35 mph. This car has the standard 16" tires.
I have an appointment with the dealer in a few days. I will see if they can get this corrected.
If you are thinking about buying one, be sure to do a test drive and look for the pulling problem.
I am leaning toward buying the Sonata over the Accord but now I`m getting a bit antsy.I suppose I could test drive the car I am buying to be certain it doesn`t exhibit the pulling.
Any further details would be appreciated
JCC
My 2011 Sonata now has 18,000 miles on it and has never had a pulling issue.
As other posters have mentioned, the Kumho tires get increasingly noisy as the miles pile up on them. My Kumho KH25's are VERY noisy now. They look like they could easily go another 30,000 miles before needing replacement, but if they get any louder they will have to go. Plus they are starting to show a slight hint of traction loss and hydroplaning on wet pavement.
Of course, you wouldn't understand if your car does not have the problem.
I had a 2009 Sonata for three years that didn't have any problems. I traded it for a 2012 that constantly wants to turn right. I don't understand why it steers this way and neither does the dealer. They checked the wheel alignment and pretend that it is "fixed."
It took Hyundai a year to acknowledge there was a left pull problem of some 2010. Hope it doesn't take them a year to figure this proble out.
'...Hyundai is alerting owners of the 2011 Sonata of a new service campaign to deal with vehicle tracking issues some owners have reported. Hyundai says that about 3% of 2011 Hyundai Sonata owners have reported "dissatisfaction with vehicle tracking (commonly referred to as 'pulling left' in on-line media and customer reports)."
The fix, says Hyundai, involves checking the alignment and, if necessary, installing new front suspension struts and a new alignment. The repair is estimated to take 4.5 hours and a free loaner will be provided to those who need one...'
Sorry for the late delay. The problem started on the way home from the dealership after I bought it. As I said, I purchased the car 90 miles from my home so I had plenty of drive time to determine if I came across any noticeable quirks. I purchased the 2.4 Limited. I did not opt for the Nav. system but now too am regretting that choice. Not because of the camera/Nav feature, but because of the irritating buzz from the right side door speakers. In fact the entire sound system set up is as frustrating as any I have ever owned. To start with the built in antenna sucks! I don't know where it is or what kind it is but the music constantly fades and I can't pick up half the channels I could with my old Buick. Then, every song sounds totally different in terms of the equalizer being able to stabilize the sound quality. In other words a song will play and sound almost like listening to an am station, then the next song will come on and sound beautifully balanced with the right amount of everything, and the next will come through with what sounds like 90% coming out of the front speakers and the base buzzing out the drivers side door speaker!! It's crazy. I am constantly reaching across going through the entire sound menu setup(which is what you have too do) to try and change the settings so that the music will sound balanced! Anyway, I hate to make this car sound as though it has no redeeming qualities, but for having been the Limited model I am really surprised at some of the things I did not pay closer attention too when shopping around. In case any of you make the assumption I did and overlook this other little detail....it does not come with the passenger side seat powered. Limited only has power on the driver side seat, so be prepared to feel like you are sitting on the floor. Sorry for all the negative...can you are tell I might be experiencing just a tiny bit of "buyers remorse"?
Im trying to find out now if I am able to take off the regulator. You have to turn the volume up to mid 30's and it still isnt loud..... the old system would blow you away at 14. Also, no matter what you do in SETUP, it never sounds good.... This is my 4th sonata so I love the car.... just hate the new stereo they felt a need to change. I never had any pulling issues.
But it is ashamed that dealerships and manufactures are so inclined to play these games with consumers. They know it is a problem - why can't they just honestly say that they will keep working on it and let you know when there is a solution. The dishonesty is what really makes the problem a problem.
When sitting at idle and you gently move the steering wheel left or right it clicks to the next position like the detents in the volume knob on a digital radio. The stiffness of the steering along with the lack of smoothness exaggerate my steering adjustments at speed. This tends to make me drift left and right in the lane when driving at highway speeds. Alignment is perfect. Their software isn't. I haven't noticed this in Kias.
I don't have this issue with my other cars. Personally I'd like to see them reduce the steering effort in their programming. This 3,000 lb car feels heavier than my old Buick station wagon when maneuvering.
The TSB didn't work very well on my Sonata but it seemed to be effective for some people.
You will get feeling so bad and get tired because of wandering while drive. (especially on Highway)
The poor steering won't be centered as much as 1/2 inches.(left and right)
Dealer and Customer center seemed like they have no solution about this so far.
I'd like you to go with Honda accord.
I'm waiting for my payoff day.
Also FYI, there is a camber kit that Hyundai can put on the Sonata if the camber is out of specs - no big deal with the knuckle bolts mentioned on another post. So far our dealer has been most responsive to our minor concerns and promptly fixed the alignment. Oil change was inexpensive and MPG is actually improving so all is good. Hyundai appears to be encouraging dealers to cooperate with owners so they can continue to seel more new cars. Bad service = bad press= bad sales so they are giving good service and so quibbling about warranty issues.
The only time you want to replace the struts is if the vehicle was involved in a collision and it needs to be replaced because of a bent component.
If you want to learn more about struts assembly, here's a good link: https://www.yourmechanic.com/services/strut-assembly-replacement
__________
Otto Ym
YourMechanic.com
facebook.com/yourmech
twitter.com/yourmechanic
I love my Sonata and just bought a 2014.
