Mazda3 Exterior & Bodywork Issues
Has anyone had any paint issues on their brand new 2011 Mazda3. Mine is a month old and I noticed grey/white spots in the paint. It's all over the car and are very random spots. Finally the dealer now sees the spots and needs to consult Mazda. Anyone else have these issues and what are my rights in this matter. Repainting the whole car will depreciate the value, so should I ask for a new-new car?
Please let us know how it works, sounds awesome to take out dings as well.
By the way, I used a new product called Meguair's Hi-Tech Syn wax with UV protection. I bought it for $15.99 and it took all the swirl marks and scratches out of the car. This product is the best!!!
When I showed it to the dealer they said it wouldn't be covered under warranty.
When the weather gets warmer I am going to try some glass polish on it to try and lessen the visability of it.
What is the color of your Mazda3?
When you say all over, does that include the roof and trunk? Imperfections on the front and sides of the car could be attributed to stone chips.
Can you feel the spots when you run your hand over the affected areas?
Some paints use mica to reflect light with a shimmer, but there is nothing wrong with the surface.
The advantage of getting a new car, is that you no longer worry about the solution to the problem! Hopefully, Mazda and or the dealership see it that way also.
When you say all over, does that include the roof and trunk? Yes, on the roof and trunk also. Even the parts of the frame above the door. They are just white spots and not grooved like rock chips or etc.
Some, yes, others no. There is like a hard spot on some that are actually pertruding out from the spot. Using a finger nail will not remove the hard spots. Other spots are just spots like when you get sun damaged white spots on your skin and there is no roughness at all to the spot.
We do have a Lemon Law in our state that does say that if the issue causes a depreciation in the cars value, then the dealer must buy it back and a replacement given to the owner.
How much does a repaint depreciate the value?
I have an appt set up with the dealer's Mazda Representative next Tuesday.
Thanks for your help
I would consider documenting the problem by:
- taking as many photos as possible (pretend you work for CSI),
- reviewing the requirements in the lemon law,
- drafting a letter describing the problem, the times you have visited / spoken to the dealership (include the earliest date possible you mentioned the problem to them), stating your preferred remedy (i.e. a new vehicle) and finally mentioning legal action via the state Lemon Law, if you are not satisfied.
If your dealer does the right thing and provides you with a new vehicle, you won't need the documentation. But, if not, you should consider taking the next step. The longer this takes, the more the dealer will claim it is your responsibility (i.e. wear and tear) rather than admit that the problem is due to the manufacturing process or some other reason.
The dealer may want to make a deal and have you "share" in the repair. It seems clear from what you have said that you are not responsible for the problem and therefore should not accept any burden to remedy it.
Frankly, I don't know how much a repainted vehicle would be discounted. Most buyers would be curious if not concerned why a vehicle was repainted. One could always say, "I did not like the color" (except of course if you repaint it to the same one!).
Let's hope the dealer does the right thing.
Amazing!
Still waiting on Mazda to come to come to some sort of decision. It seems like now my emails and phone calls are not being answered by the dealer. So, this weekend I filed a BBB complaint and will see where that goes. You would think that they would give me some sort of response back since it has been a month and do they really want me driving around with the paint looking like this and their name on my car. I almost tried to get the dealer's name off, but haven't even washed it since a month ago. Don't want them to claim it was something I did that caused it to get worse. I did take a video of the vehicle pointing out all the spots around the car and it's pretty darn good. The spots have even showed up on the black window and door jams. I don't think a repaint will fix it all in my opinion. :lemon:
Yes, they have not heard the end of this!!! :mad: :mad: :mad: :mad:
The dealer/Mazda may be trying to see the minimum that you will take. The "goodwill" gesture is part of a strategy to come to a quick agreement and avoid lengthy negotiations; it would surprise me if they accepted your initial terms without trying to bargain you down. Offering to pay 2 of your car payments may be an initial bargaining position.
Have you heard back from the BBB?
Has a paint "professional" seen the problem?
Have you considered hiring a lawyer?
It's good that you are following up with the dealer/Mazda in a timely manner. As the car gets older, the case will become more difficult to prove.
A key question to consider is why did you purchase the car if it had a paint problem? On the other hand, if it did not have the paint problem originally, I would think it would be more difficult to have the dealer/Mazda take responsibility for the problem once it's left the lot.
Good luck!
The Arbitrator will be neutral lawyer and I still do have the right to sue Mazda even after the out come of the arbitration. I have not spoken to a lawyer because that would cost me $$.
Why did I purchase a car with a paint problem? Maybe because I didn't know it existed. The spots can only be seen in cloudy or shaded light. In the bright Atlanta sun in the middle of July, the spots cannot be seen at all. We haven't had many cloudy days here in Atlanta, and I just so happened to see it as a cloud passed by the day I was giving it's first bath after purchase.
Even if the damage happened within the 4 weeks I had the car, you would think that the clear coat on the vehicle would have protected it.
The reason for the questions in the earlier posting was not to put you on the spot, but to have you "practice" answering questions to see what responses work. Also, getting experts (e.g. paint professional / detailer) to back you up should strengthen your case. Finally, getting it documented should make it clear that your case is not frivolous but based on solid evidence.
Once again, good luck with the BBB and let us know how things work out.
Thanks for all your help and especially for testing me....
Your dealership should be able to provide the part numbers.
How old is the car?
