Beaters Out Of Choice, Not Necessity
Many Americans buy the nicest vehicle they can afford, because it makes them feel good, or to impress others. Some stretch to own something beyond their means, for similar reasons, and have trouble making payments. A few, on the other hand, maybe you, drive something considerably below what they can comfortably afford.
Tell us about people you know who, for whatever reasons, drive a car that's below their financial circumstances. Do they suffer from low self esteem, do they want to be inconspicuous, are they just plain cheap, or do they enjoy the freedom that comes from driving something they don't need to worry about?
It is a 380SE, and is just ready to turn 260K. It needs a paint job and some 'freshening up', but still runs like a top and tries to get me speeding tickets.
Initially, I thought the water pump would be the straw that broke the camel's back, so to speak. But, in talking to the mechanic today, he said that, while the suspension needs work and the truck is getting rusty, as little as it gets driven, it should last indefinitely. It currently has about 137,000 miles on it, and these days, might see 2800-3000 miles per year.
I figure if it lasts through the winter and into the spring before anything else major goes wrong with it, I'll be ahead. And the engine, transmission, and driveline, are still nice and solid the mechanic said, and will most likely outlive the body. So, I hope I'm making the right choice in keeping this aging relic around. I guess time will tell!
Our Arizona car actually belongs to my MIL but at 94 she no longer drives her 2000 Buick LeSabre which has relatively low miles at just under 50K. It's cosmetically okay, needing just a good wax/polish but shows signs of it's age in several ways. The right rear window motor has failed for the second time in two years, the cruise control is erratic, the tranny doesn't shift as smoothly as it should and the fuel pump was replaced last year. I don't much care for driving it but a free car is a free car.
In New Hampshire we have a 2000 BMW 528iA which was my sales sled for a couple of years when I was working and now has close to 140K on it. It's in better shape than the Buick, everything works except the gear indicator lights on the console (there's a working indicator in the dash display). Cosmetically it's in good shape give or take a few dents and scratches.
I really like the Bimmer; owning it has taught me that there's a reason why it costs twice what a LeSabre or Malibu does. IMO it's at least twice the car.
In a few years we'll buy some newer cars, perhaps even brand new but I might hang on to the BMW just to see how long it'll go.
I hope I'm making the right choice. I think I'll feel better about it a couple months down the road, provided nothing else has gone wrong with the truck by then.
We have been very fortunate. In both of the places that we've lived since we bought it, we've found a terrific private mechanic who has maintained it at moderate cost. The parts are relatively expensive, but it hasn't asked for a lot of them. Other than replacing the A/C system with an R134 unit (the compressor had gone out on the original system) and replacing the transmission with a rebuilt unit because the engine was out to replace the rear seal anyway, the costs have been for routine maintenance and the expected replacements (e.g. the rear seal). In short, keeping the old dear has saved us a moderate fortune over replacing it (probably several times) with another vehicle. It is, of course, at the place where if it needs a major repair we will probably have to just shoot it. If that happens I will mourn.
I will mention one other major expense, but I can't hold it against the car because it was my own damned fault; I stupidly did not realize that timing chains are mortal. One of the chains slipped an unknown number of links and the valves tap danced on the pistons, much to their detriment. A word to the wise; you don't want to make that mistake.
New cars have started bouncing back but are "increasingly skewed to high-income households," said Tom Webb, an economist with Manheim Consulting, which does research on the automobile market. And "all dealers are much more attuned to their used-vehicle operations," he said."
Older cars keep their shine as drivers pinch pennies (Detroit News)
Oh, on the subject of beaters, it was almost 9 months ago now that I had my water pump issue with my '85 Silverado. Other than a flat tire that wasn't the truck's fault, is hasn't cost me anything at all, other than gasoline, since then. That's not to say it's been perfect, though. The power window in the driver's door quit working. Motor still runs, so I'm guessing something came loose, or off its track. And then, about a month or so ago, the parking brake broke.
So, there are a few inconveniences here and there. But I think it's worth it, for the money I've been saving. I imagine anything new I bought would be at least $2000 down and around $300+ per month.
Edmunds Used Car Best Bets for 2012
As a treat, I changed the oil on the '99 Quest when we got home from blueberry picking.
Last change was 11,760 miles ago. Even sprung for a new oil filter.
I use good ol' dead dino - got SuperTech from Walmart today, which is what I usually get unless I stumble on a sale somewhere.
Put a nice ol' Fram filter on it too.
Oil changes have been running me about $17 each the last couple of years.
I don't think this engine came with a crush washer. If it did, it hasn't seen one for a decade or more.
Would be fun to see what an oil analysis says but I'm too cheap to spend the $20 bucks on one.
Around here the van is more likely to either rust away or get totaled by a deer than suffer catastrophic engine failure. I do check the oil level every fill up, but it never uses any. Still on the original timing belt as well.
The Subaru's rear hatch catches, well inside the door, are pretty rusty. That's an odd one.
I have some rattle cans from Ace Hardware but the silver on the van is turning out to be hard to match. :shades:
It's kind of a dumb milestone, but I took this pic of the Buick's odometer back in November 2010...
Here's when my 2000 Intrepid hit 100,000 miles, back on Christmas Eve, 2004...
Other than these two, I can't think of any significant odometer milestones in recent memory. My '85 Silverado had 109,000 miles on it when Mom sold it to me, and now has around 138,500. As gas has gotten more expensive, it's been getting driven less and less, and these days might be good for around 2000-2500 per year. So the 150K mark is probably about 5 years away...if the truck lasts that long. The powertrain's still strong, but rust is really starting to get to the body...mainly in the rockers and lower door panels.
The Park Ave has about 85,000 miles on it now. At the rate I'm going, I think 100,000 will come up in about a year and a half. My '79 5th Ave, the only other car that gets driven fairly regularly, has about 97,000 miles on it. 100K might come up within the next two years.
As for my other cars, my '67 Catalina has about 59,000 miles on the odometer (probably 159,000), '76 LeMans has about 81,000, and my other '79 NYer, the base model, has about 62,000. None of them will be hitting the magical 100,000 mile rollover anytime soon.
Here's my 2005 Mercury Grand Marquis LS on May 4, 2012.
I have a 1988 GMC van which I use on the farm. Bought it from a neighbor for $900 3 years ago. I used it as my winter beater for my other job but the road salt has taken it toll. I've replaced a fuel pump, gas tank, tie rod, e-brake cable and lower control arms. All rust related items. It is a true hooptie. It has about 129,000 miles.
Finally I have a 1984 Corvette that I bought from my older son ( he needed money too). It's not exactly a beater but it's no show car. It has 133,000 miles and various quirks you'd expect from a 29 yo car. Nothing serious. It could use a new interior or at least new seat covers but it drives OK and is kind of fun with the roof removed. I've driven it about 2000 miles since I got it and I'm surprised to see it doesn't burn or leak a bit of oil.
I also have a couple of new cars which I like but there's a feeling of freedom driving a bunch of vehicles which if they were totaled tomorrow wouldn't be much more than a $5k loss. Every time they start and go where I point them I feel like I've got my money's worth.
I'd be less worried about gas milage than the Northstar's habit of blowing the head bolts out of the block at odd moments. Usually totals the car as the repair is super expensive.
My 4.9L can get a solid 28mpg on the highway. Of course if you stomp on it it gets 6.
I have to disagree, and disagree strongly. Years ago, I went directly from a 92 Deville to a 98 Deville. Making the same commute, my average gas mileage went up from 16 mpg to 21 mpg. I am one of those people who keep a notebook in the glove compartment, and record every fill up, with miles driven, number of gallons, and mpg.
The Northstar is NOT a gas hog. Yes, it does blow head gaskets. And I can testify to that from direct experience. But until / unless the head gaskets go, the mpg is decidedly better, and the horsepower / performance is dramatically better. A Northstar equipped Cadillac is a fun ride.
The water didn't feel oily and my wife is sensitive to smells and she would have noticed long before the carpet got soaked if the coolant was leaking into the car.
I think stopping to get gas moved water in the cowl over to a low spot or something. Got to the campground and borrowed a fan and the carpet was dry by the morning.
Rained again last Friday heading back north and got a couple of ounces on the floor. Guess I'll try to find the clog this week. The in-cabin filter is relatively new so will be surprised if it's clogged. It's also odd since the van is parked in the garage most of the time. We do have chipmunks.... :confuse:
Rolled over 179,000 miles and really want to see 200k, but the years are taking their toll at this point. The move to salt country isn't helping.
Of course age matters, but 200,000 is the new 100,000. In the spirit of beaters by choice, your van can do it.
Ruking1 is right in there with me with 178k on his VW Jetta TDi. He drives more than we do so he'll get to 200k a year earlier that we will. And his mpg is twice as good as ours too.
These guys can send you back in time about 30-35 years and you'll find one! :P
Took the cowl off and there wasn't much of anything in the way of debris in there. Didn't pull out the in-cabin filter but it looked like it was fitting well and didn't look particularly dirty. Plus it's all the way to the passenger side and my leak is right at the brake pedal.
I poured a couple of cups of water into the area while the cowl was off and the water drained out quickly through the front fender area.
So, I screwed everything back together and in keeping with my long maintenance tradition, I'm going to ignore it until I can't.
Another commenter talked about falling out of his chair after totaling up ten years of driving expenses.
Originally, I thought about just driving it till it drops, but then the more I thought about it, as little as I drive these days, it probably won't have 35,000 miles on it by the time the 5 year powertrain warranty is up Heck, it might not even need any maintenance in that time, other than oil changes and a couple air filters and, at the worst, front brake pads. So, I wonder if it might be a good idea to trade it around that time, and get into something brand-new again, with a warranty? With only around 35K on it, it should have pretty good trade-in value, even for a Dodge! :P So, that'll be a bigger down payment, so that whatever replaces it won't cost all that much.
But, I'll just see what happens when the time comes. A lot can happen between now and then.
Why Things Fail: From Tires to Helicopter Blades, Everything Breaks Eventually (Wired)
Breaking Up With a Broken-Down Car Is Hard to Do (WSJ)
For the record I have two cars, one is 13 the other is 12, I'm a liberal, don't garden or DIY much and value performance style and bang for the buck more than comfort or security.
I love coffee shops - not the Starbucks kind of places as much as the diners though. Around here I can get a good breakfast for what a triple shot caramel macchiato would cost at 'bucks.
Liberals don't like cars and certainly wouldn't have more than one (remember your slotting LOL).
