Door Locks
chmeekschmeeks Member Posts: 5
Does anyone know what is the cause when the door locks won't work when you shift from park?
  • gonogogonogo Member Posts: 879
    Not programed in the DIC.
  • chmeekschmeeks Member Posts: 5
    edited December 2011
    Does anyone know if it can be programmed without going to the dealer?
    Your owners manual shows you how, if you don't have one get one online.
    http://www.gm.com/gmownercenter/gm/?campaignId=&vin=
    Thanks for the input, but the manual says that it was programmed at the factory. There is no where in it on saying how to program it. Any suggestions?
    Sounds like you don't have a DIC, was this a rental? If you have DIC there will be some buttons on the left side of the radio, info, menu, arrow or enter, if not dealer program.
    Hi Gonogo,
    I do have a DIC. This was not a rental. I have checked all the buttons as you said, but no way of programming. I have a 2006 base model.
    Menu is the button you push to program, do you have menu?
    Yes, I do! I push the meunu button. Do I press and hold at some point? Exactly, what do I do?
    Press menu button until you see the what you want to change. Then press arrow or enter to make selection, then press menu to record your selection.
