Mazda3 High Mileage (2004-2009)
                    Hi, everyone, I am doing a survey to see how many miles can Mazda 3 get before it dies.
If you can, please report the status of your Mazda3.
1. Year
2. Mileage
3. Auto/Manual Transmission
4. Transmission repaired? If yes, at what mileage? New or rebuilt?
1. Year
2. Mileage
3. Auto
4. No.
NB: When cold start, the shifting 1st to 2nd gear jerks. Is this the sign of transmission going bad?
2. 166,000
3. Manual Transmission
4. 3rd issue (slips out of gear) at ~160k, replaced with used trans
5. Engine noise at 166k, dealer says lifters or timing chain (likely) and advised to replace with used rather than repair (teardown to diagnose ~$1k)
NOTES: Replacement transmission shifts more smoothly than the original ever did; car has hit redline at least once per day for the past 5+ years and has required no major repairs.
I just send mine to Mazda dealer, they flashed PCM and transmission fluid. But still feel little shift shock 1st to 2nd gear when its cold, its gets better when it's warmed up. and the dealer quoted me a new transmission for $3.5k.
NO more getting auto transmission on Mazda cars, really like the 3 series, but their transmission really bothers me.
2. Mileage 161,000
3. Auto/Manual Transmission Manual 5sp
4. Transmission repaired? If yes, at what mileage? New or rebuilt? Origianl transmission and clutch; has had four different drivers, two teenagers
2. 103,000
3. Manual(as it should be)
4. Absolutely no issues; I run Ford Synthetic Manual Transmission Oil and change it every 30,000 miles.
2. 130k
3. Auto Transmission
4. Transmission repaired? No, though I get a hard shift between 3rd and 4th when accelerating hard.
You didn't ask about other issues, but I had alternator failure at 115k miles which disabled the car and required a tow to the shop and $700 repair bill.
Otherwise a very fun and reliable car with 35 mpg hwy.
Care to expand on this failure? Were there any warning signs or recommended service checks by your mechanic? For example, when the car was in service was the alternator ever checked? Also, failed alternators are sometimes due to battery failures or a battery due for replacement. Was this not spotted by the service mechanic ahead of time?
The alternator failure caused a bunch of erratic electrical problems. I first noticed a problem about a mile after leaving work. The tach needle started jumping around and lights on the dash started blinking. Then the antilock/stability control started to malfunction and I had to pull off the road. I thought maybe shutting off the engine would clear things up but it wouldn't re-start. $700 and a year later it's been fine.
I have alignment issues now. The car is eating tires. Going to take it in for a full alignment this week. Like I said, it doesn't get professional maintenance but neither does my 2005 V8 4runner with similar mileage. The 4runner has been flawless.
2. 115,000
3. Manual
4. No, but starting to notice a very slight slip in both 3rd and 4th gear; it seems to take a moment for it to actually "get into gear".
I came on here looking to see prices to replace, and what others may have paid. I LOVE this car, and although I could get a new one, prefer to see about possibly replacing transmission when the time comes...
2. 178,000
4. Replaced transmission with a used transmission at 176,000 miles. Used transmission was from a 2008 Mazda5 with 30k miles. Transmission with install labor was $1,100. Dealer quoted me $3,000 to replace transmission with a rebuilt unit. Per the owner's manual, I never changed the transmission fluid. My new mechanic recommends changing every 24 months/30,000 miles.
2. 239,000
3. Auto
4. Original with one flush at 120k
Cold 1-2 is a little jerky but otherwise shifts fine
Keep your mass airflow sensor clean (all 4 wires)
2. 170,000
4. Nope. Still Original and Running great
Outside of normal maintenance which I always do on time (Struts, brakes, etc) I have only had one $250 repair since purchasing it new 9 years ago. Love this car and highly recommend it. No car payment and no major repairs for the last 6 years has been great for my finances. Hoping to get another 3-4 years out of the car @~12,000 miles per year
2. 197,000
3. auto never had a mechanical issue except at 165000 miles the transmission couldn't decide whether wanted to go in 4th or 5th gear so it would shimmy and Jitter like a manual would if you were lugging the piss out of it also noticed it was losing a little transmission fluid put some Lucas Oil stabilizer in it not the transmission fixed [non-permissible content removed] and it's been fine ever since and also stop the leak always ran mobile one change that every 10,000 miles would be about a quart low every oil change 2.3 liter motor
2. Mileage -240,000
3. Auto/l Transmission -Manual
4. Transmission repaired? If yes, at what mileage? New or rebuilt? - no work to transmission so far! shudders a bit when engaging in 1-2, but mechanic said clutch is fine!
5. I do need to put oil in it almost every other week ( no seal leaks) but internally burns oil as I change plugs pretty frequently to keep it running smooth. Cant complain at 240k!!!
2). Km 203745
3). Manual
4). Fist, I Personally do all Maintenance and Repairs myself. As for Transmission problems. I had to Replace the Clutches Slave Master Cylinder before she would shift back into gear. That was Just after 200000KM. When I first bought her. I replaced rotors & brakes, (rotors were shot from sitting in grass to long). She also needed an alternator. I picked 1 up at my local auto wreckers for cheap.
Shortly after the slave master cylinder went, she popped a misfire code. A fairly cheap and easy repair. I replaced The valve cover gaskets, and put in new spark plugs to be safe.
The most common problem with Mazda’s seems to be rust. Currently my underbody is intact but extremely soft. I’ve layered rust killers & Protection sprays to prevent further decay. Although my exhaust finally gave out not long into 2020s winter. The exhaust gave out. Splitting before the pre-catalytic converter.
I’ve seen most Mazda’s written off. Long before the motor completely dies. Due to underbody rust rot or post 2010-2011 poorly made automatic Transmissions failures.
Sure with mileage the pistons wear down causing excessive oil burning, loss of torque, acceleration, & power.
Ill give Mazda credit for finally building their own automatic transmissions witch seem to be a lot better then the post 2010-2011 models. It took them long enough but the improvement is significant according to consumer reports.
Original manual trans
375,000 km's
256500 km
Original 5-speed automatic transmission.
2007 Mazda 3 Sedan
222000 miles and counting
Original Eng and Trans. Mo major repairs.
Engine burns a little bit of oil (Have to change it every 3k) Transmission shifts super smooth still. No leaks as well.
2009 mazda GT 3 htcbk
293000km
manual
Just parked my 2005 with manual transmission at 354000km, I've owned it for 13yrs with no major repairs. Clutch is going though. I have never done the clutch on it and don't know if the original owner had. Crossing my fingers this 'new to me' one is also a gem. Previous owners did the clutch.
257000 miles
manual
zero issues with engine or transmission, no major repairs at any time...still running strong although clutch is getting a little loose.
