Subaru Outback: Slips from Drive to Manual/1st gear on its own
I drive a 2011 Outback (automatic). A few months ago the strangest thing happened: From a stop sign, I turned left and as I accelerated, the engine revved really loudly. I took my foot off the gas, moved the gear shift from "Drive" quickly to "Manual" and back -- and it reset. It has happened many times since, and I noticed that when it occurs, the display goes from “D” to “1” or even “2”. Every time I reset it the same way and it drives fine from that point.
Subaru has serviced the car 5+ times for this issue and they have no idea what’s happening – and tell me they’ve never heard of this before. They've re-set the computer (which shows no issue) and driven it themselves for weeks (of course it doesn't happen when they have it!). At first they suggested that I was accidentally hitting the paddle shifters, but I hold the bottom of the wheel when I drive – nowhere near the shifters.
Hopefully my very non-technical description makes sense and sounds familiar to someone out there! Any ideas???
Are you wearing gloves when this usually happens?
Note that the paddle shifters work regardless of whether the gear selector is in normal drive mode or manual mode.
FYI, I have used the shifters intentionally from drive mode as you note, and am aware of the amount of pressure needed to make these work. Unfortunately, this is not the culprit!
Have you tried slapping a paddle to select the next gear when this happens? I wonder if that would clear it back to normal mode or leave you in manual.
...as a temporary band-aid, good idea to try using the paddle shifters to reset. I'll keep that in mind.
My bigger issue, though, is that it makes me feel unsafe driving the car --- a relatively NEW car, at that! Thankfully, I've been able to react quickly enough so that the car(s) behind me haven't hit me. But I can easily see how this could become an accident, if the driver behind me thinks I'm accelerating normally and the car does the opposite.
Has anyone else experienced this? (and I reeeeally appreciate the suggestions!)
My 2011 Subaru Outback is at the dealership again for the second time since January. The first time that this occurred I called my dealership. They had my car in the shop for 4 days, they did all sorts of "tests" on it and they turned up nothing. I did call the 800 customer support line just so that my problem was reported to them.
The support line did tell me the next time that this occurs, pull over immediately and call the dealership for a tow. They said not to drive the car more than 5 miles because it would clear the "records" of what occurred with the transmission.
Yesterday, March 27, 2012 it happened again. After I had made a left hand turn at a light, the car went from manually driving at 40 to 2nd gear. Talk about a safety issue! I pulled over immediatly and called the subaru dealership. They sent a tow right away. They gave me a rental and are keeping my car for a week. Their service manager is going to drive it every day to see if it will happen again. I told them that it would not happen and wouldn't until about 3 months from now! grrrrrr.
They did tell me that the 2011 Premium model is having the same issues, but this is the first time that they have ever heard of it happening in my model. BS!
Let me know what they are telling you. if you need to email me at barker.tara@gmail.com
TB
I troubleshoot for a living and it's really tough when a customer has a problem but I'm not able to observe it, makes it much tougher.
If you can duplicate the conditions where the problem occurs and the dealer can see it, that helps them fix it.
I don't live far from SOA HQ, so one of their lead tech guys got involved to help figure this out. He came out to meet me one day over the summer for a test drive and to watch my driving position, technique (without telling me he was doing so). Super guy, very genuine in his wanting to figure this out. Kudos to Subaru of America.
Long story short, here was his theory: I drive with my left leg at a near-90-degree-angle, and so without realizing it, occassionally when I would turn, the paddle shifters brushed my leg with enough force to kick them into gear, but not for me to really take note of the sensation against my leg. It happened even more during the winter with a heavier coat, when I really wouldn't feel it at all.
I am relieved to share that ever since my test drive/discussion about his theory, I have NOT had the issue at all. As a side note, we just welcomed our first child, and I have no hesitations about having her in that car.
SOA had received a handful of complaints about this same issue (side note: the Dealers' handling of this is another story -- they all seem to have had the same approach: deny anyone else has the issue and make it our fault...ugh.) Coincidentally, all were from women drivers; and it seems that women drivers drive with more of an upright left leg, which triggers the issue.
...I know this may sound a bit odd. But try it for a while - notice your leg position the next time in your car, and make a conscience effort to make sure it is not anywhere near the bottom of your steering wheel.
Hmmm, the very first reply to your original post (from me ) ...
Is it possible that you are accidentally hitting the paddle shifter on the steering wheel?
:shades:
Maybe a more visible display when the paddles are used?
Interesting that the "shift" is smooth enough that it isn't felt.
The in dash display changes from D to a number (1 to 6).
Volvo had this idea for brake lights, to grab attention.
If the car is doing this, then something needs to be modified to prevent it from happening.
so far never happened while at highway speeds...
This just happened to me. I'm driving a 2014 Subaru Crosstrek xv premium that I purchased from Carvanna last year. I've driven it from Colorado to Seattle then to California where the issues have started.
First the CV axle which clicked since I purchased it. I fixed it and now the transmission according to Goodyear.
Nothing out of the ordinary seems to be happening except today. I made a right turn and accelerated a tiny bit and noticed the car had dropped into 1st gear. I don't know what a paddle is, but my feet and hands were not near anything to change it. You have to physically push the clutch into manual for it be in manual and I'm never interested in that mode so I never touch it.
I found these comments that have the same.issue. never buy a carvanna car. They claim a 150 pt inspection, it's just an inspection not a fix. The history of the car claimed the front axles were replaced, they were not
The car probably has never had servicing until me
I'm very much in need of this car.
