2012 3.6 DI 0-60 times
dkgsxdkgsx Member Posts: 8
I can't seem to find the specs/reviews for 2012 Lacrosse with 3.6 DI engine. I rented one and it seemed pretty quick...
  • dodgeman07dodgeman07 Member Posts: 574
    The 300HP V6 will get a new FWD Lacrosse to 60mph in about 6.5 seconds. It is a powerful engine for sure. Add AWD to the mix and it will be a bit slower.
    Google Lacrosse V6 Road Test and you can locate a few results.
  • tjc78tjc78 Member Posts: 17,824
    No one seems to have tested the 2012 version of the V6. I've looked before and came up with nothing. It was very similiar to the 2010/11. All the 2012 reviews have focused on the E-Assist.
    Car and Driver got a 2010 to 60 in 6.5. The little bit of extra power should be good for a tenth or 2. It's quick and smooth but keep in mind no sports sedan. Here is aLink to their test sheet
    Also the PIII trim level with the HiPer Struts is the way to go. They virtually eliminate torque steer. The PII I drove without them had some torque steer, IMO.
