van
I have the same problem with what seems like a line running across the windshield while driving on dark roads. It does diminish greatly when you switch to high beams. I told my salesman about it and he said to bring it in some night and he would check it out. I haven't done that yet. Have you found out anything about this situation?
On top of this, we opted for the $2,900 Technology package. This option adds a panoramic sunroof, a 12-speaker Infinity stereo with HD radio, heated steering wheel, rear side window shades and a navigation system with 8-inch touchscreen."
2013 Long-Term Road Test
While you are not the only person to report steering issues, the majority of owners have not had that problem. Leads me to believe that it an isolated issue, and not a defect across the entire line. Also, as others have mentioned, your tires were significantly over inflated, which would exactly cause the symptoms you've described. Also, for what it's worth, hyping your own credibility actually has the opposite effect. The fact that you feel the need to proclaim that you are in the top .1% of drivers (what does that even mean?) actually takes away from your credibility.
Any idea when the 2014 Sport will debut? We are into August now, so hopefully it will be soon.
Any info regarding the release date or new changes would be appreciated.
http://www.edmunds.com/hyundai/santa-fe/2013/long-term-road-test/2013-hyundai-sa- nta-fe-uncomfortable-ride-with-passengers.html
On a shopping outing, with 5 adults in the vehicle (nothing else), I did experience bottoming-out on the rear axle in a construction zone, but I'd chocked it up to the size of the bump in the road.
The vehicle is too new for me to say it's a problem, but I'll keep an ear open in the future.
It is very disheartening to read that the vehicle bottoms out on rough surfaces.
Evidently Consumer Reports did not test the load/ride performance.
1. It looks like there are ports in the plastic covering underneath the car to change the filter and drain the oil, has anyone changed the oil this way?
2. What size crush washer is used on the drain plug?
3. Has anyone used a Fumoto oil valve on this application and how did it work out?
4. "Top Tier" gasoline is difficult to find in my neighborhood, unless Citgo or Sunoco are OK, Has anyone had driveability issues because of the fuel.
