Head Gasket oil leak at 60,000 miles - second engine
My 2003 Forester must be the worst one Subaru ever made. I had some repairs under warranty (faulty hose clamps, axle boot replacement, axle replacement, rebuilt engine due to piston slap). Now, at just 60,000 miles, of which about half is on the "new engine", my Subaru mechanic (not a dealer) told me today that I have a slight oil leakage on the passenger side head gasket. Last fall he noticed a bit of coolant leakage which was odd because I always had the "Subaru Superglue" - or coolant conditioner added to the coolant.
I'm not putting any money into this car. The catalytic converter has also kicked the can (and sounds about the same). So my decision is just to run this car until it quits.
Will I get a warning or will the engine suddenly die?
I suspect that if your cat isn't working properly at that low mileage, you might have a slight internal coolant leak that has fouled the cat. If that's the case, ignoring it might mean you don't have too many more miles left.
The Subie dealer will change about another $1000 for a cat. converter if I remeber that repare estimate. A non-subaru cat will be cheaper.
Ask yourself this, "Can you find a semi-reliable car for under $3000?"
If we get another 2 to 3 years from it it will be worth it.
There really is no choice. The dealer tells me that as of the 2011 models the engine design has changed. But I heard all this before, when I purchased the 2003 Forester new.
I'm walking away this time.
There was no engine change in 2003. The EJ belt-driven SOHC engine was used in naturally aspirated Foresters essentially unchanged from 1999 to 2010.
But it is true that in 2011 naturally aspirated Foresters were given the new FB chain-driven DOHC engine. This a completely new design.
http://www.caranddriver.com/news/subaru-fb-series-engine-subaru-flat-four-engine- - - s
http://subarudrive.preprod.dcim.com/Win11/itsWhatMakes.htm
One interesting change is that the heads of the FB engine have their own separate coolant supply, that does not come from the block through the head gaskets. This will eliminate the head gasket leaks that were possible with the EJ design, and were especially common in your 2003 year.
The FA is a performance-oriented engine, first to be found in their new BRZ sports car (FA20).
The FB is more a mainstream engine, aimed at getting high gas mileage, especially so when combined with the new CVT transmission.
The FB20 engine is in the new Impreza; and the soon-to-be-released XV Crosstrek, an Outback-like version of the Impreza (see links), with a jacked up suspension and larger tires. The Impreza is rated for up to 36 mpg on the highway, the best of any AWD car; the XV Crosstrek a little lower.
http://www.autoblog.com/2012/04/04/2013-subaru-xv-crosstrek-new-york-2012/
http://www.autoblog.com/2011/12/13/2013-subaru-xv-crosstrek-first-drive-review/
The larger FB25 is in the Legacy, Outback and Forester models. It too gets improved gas mileage over the older EJ engine.
One especially nice feature of the new FA/FB-based engines is that the oil filter is now on the top of the engine, in the front, thus making oil changes a breeze.
I haven't heard of any problems with the new FB engines; but they are new, so only time will tell.
Bob
Legacy/Outback does not get the FB25 'til MY2013.
"Power comes from the same 2.0-liter boxer four that's found in the standard Impreza, putting out 148 horsepower and mated to either a five-speed manual or Continuously Variable Transmission."
I know that when I wanted to trade in my Forester, there was no such thing as an Impreza with a 2.0L engine. In fact, when I checked, I found that the 2.0L engine was discontinued in the Impreza back in 2000.
I do know that in Europe they have different engines - lower hp but the good reliable ones. Not as power crazy over there I guess. So maybe the article is referencing the Japanese and European model Imprezas.
On another note, I found a really nice 2004 WRX Turbo that I am thinking about, although it's not really my style my research has found that the turbos do not have HG problems. A little old but probably better than sticking my neck out with new untried engine. Once burned........
I did try out a new Honda CRV - didn't like the drive too much. So it's off to an independant garage for a HG fix for $600 (for one only) that will gain me some search time.
Semi-closed deck block sure helps...
Nope, the 2012 U.S.-spec Impreza (non-WRX/STi) has the new FB20 (2.0L) engine.
While the FB20 in my '12 Sport Limited has less HP and torque than my '03 OB EJ25, it "feels" like it has more power. Of course CVT vs. 4EAT, and slightly less weight, helps a lot .
A favorite tactic? Take an overused (abused?), highly modified WRX approaching its last leg, put it back to "stock," and try to pass it off to an unsuspecting buyer for top dollar. :sick:
Bob
Bob
* Pleased with power (compared to '03 OB 2.5L 4EAT)
* Loving the moonroof (haven't had one since my '86 VW Jetta GLi)
* Getting ~29 to 30 mpg on my commute (was getting ~23 to 24 mpg with '03 OB)
* Visibility is not that great (compared to '03 OB)
* I'm going to have to keep on my toes if I want to keep the front end in one piece (haven't had a car sit this low in years)
* I keep playing with the seat, but my back still gets sore ... I had no idea there was no lumbar support
Bob
Your wait was over with the 2011 FB 2.5L engine in the Forester, and the 2012 FB 2.0L engine in the Impreza. New head design, with separate cooling, no more coolant passing through the head gasket.
