2011 F 150 Electric Power Steering Issues
in Ford
I have a 2011 F 150 with electric power steering issues. I have come across others who are having the same problem. The issue is what feels like a loose joint in the steering shaft. Some people refer to it as popping. It feels like a loose ball joint would feel. I have had it to a local Ford dealer and they essentially "blew me off." They can find nothing when they put it on a lift and do a visual. It is something that would require more than that. It does not occur when you are making turns. It is when you are driving straight, especially when you hit small bumps in a row. I am concerned about the safety of it. The truck has 10,000 miles. It seems to occur more with higher temperatures. I have filed a report with NHTSA.gov and they have responded back that they are looking into it. The only way anything will come of it is that other people have filed a report with the same problem.
It sounds as if Ford may be using a slightly different technique to prevent EPS overheating, converting from a tightly closed-loop servo system, continuous, "finite" assist, to more of a "Bang-Bang" servo technique.
A "Bang-Bang" servo system will not provide power assist until the difference between the desired stearing position differs from the actual position by a specified, wider amount.
Porsche seems to think that an electro-hydraulic system is a better answer, a small electrically driven hydraulic pump.
2013 Escape FWD 2.0: Dramatic torque steer at launch, but more serious, at ~ 40 MPH WOT kickdown. Huge amount of correction required to keep the vehicle in one lane. I'm required to constantly input alternating left-right-left major corrections.
It also has very poor on-center feel.
1) Any suspected causes?
2) I like to find schematics of the control system ... where's a good place to look?
FWIW, One of my reference popints is my 2011 Ford Edge, which also has electric power steering, but negligible torque steer.
Both the Escape and Edge are claimed to have "Torque Steering Composition"
kcram - Pickups/Wagons/Vans+Minivans Host
I've been to the Escape forum & will try the Edge forum.
My hopes here are for a technician, or other person with technical knowledge, who can provide me with guidance toward a source of diagnostics of Ford electrical power steering. Or schematics of the Ford electrical & electronic components in the system.
shaking a thing that you feel in the steering system through the steering wheel or is the steering wheel visibly shaking?
For instance if the rear tends to come about, skid, oversteer, the stability system will momentarily brake the front wheel on the outside of the skid/oversteer. Newer systems with EPS will also BIAS the steering effort AGAINST the driver exacerbating the situation. Sorta forcing you into a counter-steer effort.
Some systems react so quickly the driver has no opportunity to recognize what just happened, in the indicator light extingusihes too quickly.
IN you case a loose or failing yaw sensor might cause a reaction's onset and finsh so quickly....
