2012 Toyota Corolla LE daytime running lights
I just got a 2012 corolla LE. I'm wondering how the daytime running lights work. The headlights comes on automatically in dark places. But the dashboard light doesn't come on. I called Toyota and they said headlights/dashboard lights should come on automatically in dark places. I called a dealership and they said only headlights come on automatically. Who is correct?
My question to you & all, do I have to remove the plastic fascia on the rocker panels to add the Mud Guards, I'd like to know BEFORE I start.
I will say you must remove the rear tires, unless you use a right-angle screw driver and drill.
I now have the 2012 LE. I noticed the daytime running headlights would be on but the dash lights are not coming on automatically. If I want them on, I'm forced to manually turn the lights on.
Anyone know if this is a factory set default now or is mine also screwed up?
Going to go into the dealership to see why that wasn't set automatically when I got the vehicle.
It appears that a lower intensity daytime running light comes on automatically. But if you want a brighter one AND the dash lights on, you either have to turn it on manually OR it has to be street lamps on/pitch dark outside. This is backwards. Instead of having auto dash lights during the day, it's now manual. See the wiki entry for daytime running lights in Canada for some interesting info related to increased warranty costs on bulbs.
Wiki entry
When I said it was a safety feature and asked if I can enter in a suggestion/complaint, I was dismissed and the rep claimed he had no avenue to lodge that information in their department.
I ended up calling Toyota Canada to lodge my suggestion/complaint. The rep there did appear to take my issue seriously and apologized for the dealership's behaviour. I'm not 100% certain if that went anywhere tho.
I'm basically done with this issue. There's nothing further I can do about it. Guess I'll blame my poor eyesight and lift my lazy hand to turn the darn lights on manually. At least the vehicle has a warning beep when I forget to turn them off before I leave.
If this is still an issue for you econfused and anyone else on this forum or viewers, I recently bought a 2012 Corolla LE about two weeks ago and my night lights wouldn't turn on either, but my day lights were always on. So I played with it the other night. I'm not good with car terminology so bear with me.
The stick to the left of the steering wheel that drivers use to turn on their blinking signals and normal light. You have to PULL it forward and set the light arrow to the middle setting. If you notice, when you try to switch your bright lights on it won't turn on, it will give you that steady light, however, if you pull the lever in more, and even brighter light will be visible. I took that as my normal and bright lights. I assumed I wouldn't get a clearly distinctive brighter and separate set of lights if my bright lights were originally on.
That stream of light is WAAY brighter than the day lights, but not as bright as my bright lights. So now I can see and not guess at night (my neighborhood has no streetlamps whatsoever, I usually drive painfully slow) or risk getting a ticket.
This car was a gift for me from my wonderful mother (she helped me pay half the balance) to send me off to college.
