Pre-Purchase Questions
in Oldsmobile
Hello, I am considering purchasing a 2001 Oldsmobile Aurora from a local dealership. After taking a look at the car and having it out for a test drive I have noticed a few problems:
1. Drivers side window does not go work, all others work.
2. Seems to be that the Head Gasket is leaking oil slowly.
3. The car currently has 156K thousand miles on it.
I have done some research and found that the windows not working is a normal thing for the car and that the mileage on it is not that large a problem. I was wondering if anyone else has had a similar problem with it and if it was an easy fix or if I would have to sink a large amount of money into it. The dealership is asking 3.3k for it. Anyone have any helpful advice?
MODERATOR /ADMINISTRATOR
Review your vehicle
This is a luxury car, such as an entry level mercedes so parts and such will cost as it would a car of that caliber for repairs. It is a GM car though and alot of parts are interchangeable so actually you should be able to save money and have no problem finding repairs parts for your car. Look at rockauto or other auto sights for good deals. Avoid dealer at all costs they will rape every penny out of you. For the problem you described I would not put 3.3K into it. Repairs I mentioned should only cost you $500, and any other wear and tear you should obviously replace that needs replacing. If there is alot of wear and tear expect to pay at least $1K that is normal if you needs new struts, bearings, or others parts. Just make sure you really need the repairs, some shops like to say you need way more than you actually do.
