2013 Toyota RAV4
Seen on the street. Big news is no spare tire hanging off the back and no more rear door hinged on the wrong side.
The real thing is supposed to debut at the 2012 LA Auto show.
2013 Toyota RAV4 Spotted in Southern California (Straightline)
Why get the Escape when IT DOESN'T offer the V6 you want? The Rav4 offers a V6 now, so......get it! :confuse:
You contradict yourself well....
BD
And Lexus will offer a version next fall.....
"That said, the 2013 Toyota RAV4 is among the best in almost every other category. It's comfortable with a full load of passengers, has plenty of cargo space when there are no passengers and delivers predictable, if tepid, performance no matter what's onboard. And even though it won't change the world, it delivers all the things an SUV of its type should to those with more reasonable expectations."
About the only negative was the gas mileage.
You may want to go to Toyota.com and sign up for the updates.
Much better looking w/o the spare tire on the rear of the vehicle.
I do like that Toyota got rid of the spare on the rear and went to a lift-hatch.
Toyota made additional changes to models built after April, improving the stability of the steering column and adding more padding under the footwell carpeting.
"The changes, however, weren't enough to lift the RAV4's performance in the small overlap test," said the IIHS. "A combination of poor structure and inadequate control of the dummy's movement prevented the RAV4 from earning better than a poor rating overall."
2013 Toyota RAV4 Earns Poor Rating in Small Overlap Crash Test
Instead of being a unique, outlying data point in the category, the 2013 Toyota RAV4 is just like every other crossover in the segment. Without that uniqueness, the Toyota is outmatched."
2012 Honda CR-V vs. 2013 Toyota RAV4 vs. 2014 Mazda CX-5 Comparison Test
The power tailgate I tried at the dealer was extremely slow--is it possible to override the power function and push it down manually? I don't necessarly want to disable the motor, but it would be nice to be able to help it down.
1. A sales men told me that there is no longer a power steering pump, that its electronic. Ok so I know a little something about cars so I looked this up. When he says electronic, it really means that the power steering is now a motor. Something that can break still is this true?
2. Same salesmen told me that you cant fill the transmission with fluid anymore. He said you no longer have to do it its lifetime, no dipstick. From what I read you still have to change it but have to do it from the differential on the bottom. So he is also misleading there and can also cause harm to your car. Anyone know the answer?
3. One dealer is saying they are the only dealer that gives a lifetime warranty on the power train. No mileage of year limitation. Yet they hide this sign in the back and don't display it where the customer can see it. Sound like a scam to you?
Just some questions?
My Dodge Dakota has a lifetime power train warranty provided by the manufacturer. It is simple enough, bring the truck in every 5 years for a free inspection. Have not had occasion to use it yet.
However, if this is a dealer supplied warranty, I'd read the fine print long and hard, and I bet there is a lot of it.
