Oldsmobile alero tachometer and security issues
Hello
So my girlfriend has been having some issues, suprise! First off, when you start the car the tachometer (rpm gauge) goes all crazy! It starts just fluctuating from 0-7 without affecting the engine. Secondly, the security light is on but the car starts up just fine. The odometer also switched to KM instead of miles. She tried to drive the car this morning and said that it was stalling and cutting out.
I've replaced the battery and checked the fuses thus far and still the issue continues. I heard it could be the cluster ($300 repair!) or possibly the ignition switch? I don't know, so I was hoping someone has ran into a similar issue and figured it out.
Also here's a link to a video of the occrance:
http://videobam.com/IodKf
These things have problems with gauge clusters and ignitions.
If you are somewhat mechanically inclined its rather easy to replace both. The iginition is a bit more tricky and expensive than the cluster. You can try going to a parts yard and ripping one out of another car (Pontiac Gran Am's have the same engine and same ignition if you need other parts as well).
