Ready To Blow Up My Diamante!!!!!
mrimaxmrimax Member Posts: 2
Hey, Hoping you can help me with an issue I am having with a 97 Diamante. Problem, radiator fan not turning on. Here is what has been replaced so far.
Fan Motor Works When Jumped To Battery
Replaced Fan Switch
Replaced Fan Sensor
Replaced Fan Relay (All 3) with Horn Relay, All Work Fine
Replaced Thermostat
Only way I get the fan to come on is when I pul;l the connection to the sensor, then it comes on with and without the air.
If I had a gun I would shoot it right now. But since I need it I',m asking for suggestions, Any Thoughts????????
Joe Bianco
  • Kirstie_HKirstie_H Administrator Posts: 11,254
    You might have better luck with this in our answers section:
    http://answers.edmunds.com
    Members with technical knowledge can often be found there. There's a very conservative character limit, so you could just write the basics in your question, then add more info by "answering" your own question.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
