I think the probability of that happening is the same as a snowball in hell!
Sure no oil but with level at least at the min mark on the dipstick and even at 7,500-10,000 miles this will not overheat an engine to blow a gasket.
I think that is really reaching
If you go back and look at my previous posts, I have detailed the service intervals once before (it was my second post, I believe, when Scott asked for all the usual details), and I was the one who asked this panel for information on if the underbody damage could have played a role in the sludging.
Your post 1848 makes it sound like I have been changing my story or adding things to it out of the blue. Go back and read my previous posts, as the story has been the same since the first one. I wanted information on the arbitration process that I was going to be facing, and mechanical information on engine sludging because I knew nothing about it. That's what brought me here back in mid-July. Now I guess I need to find a legal advice web site to haunt.
I didn't go back to read who had the accident damage - I thought it was another poster with sludge. I should have.
I agree, though, that the cooling system damage is very suspect. I'm not enough of a gearhead to have a hard opinion, but it is difficult for me to envision sludge causing seizure or a broken rod. I still think something else went on in that engine besides just sludging.
Give me a break.
BTW, your vehicle's not a diesel, is it?
Harry
You can call Amsoil to verify.
Scott
By the time the 80's came around, did this still hold true? For instance, the 2.8 that would've been in an '86 Blazer...would it have been any sturdier than the 2.8 in a Celebrity? Or did the Blazer by '86 have the 4.3? I'd have serious problems believing anything could run 310,000 miles on the same oil, though. Makes me think of the Slick 50 commercials where they used to run Mopar slant 6'es or some other under-stressed inline 6 without oil, and showing how Slick 50 "protects" it. The only problem is, those engines can run without oil for awhile anyway, if they're not under load.
If people knew that they would never buy those Snake Oil Products!
Go ahead it's true,call'em before you talk smack.
I thought not.
Thanks. BTW I used to use Amsoil, I think it's it a good product.
I worked on over the road trucks in the sixties. Then we would change the filters and add a gallon of oil to the big rigs once or twice between oil changes. That was because the contaminants in diesels were not as corrosive as in gasoline engines. Mostly diesels put soot in the oil, and the filters would trap it. One rig I serviced regularly used forty quarts plus four for the filters on an oil change.
Harry
I believe some of today's Amsoil users have a conventional full-flow filter as well as an aftermarket fine-mesh by-pass filter.
efficiency.And they also remove water.The by-pass system is the key to super extended drain intervals,and saving money,and the environment.
HiC
You want info,go to Amsoil.com and have a blast.
http://www.quakerstate.com/resources/index/promos_ads_index2.html
And I think 7,500 is overkill with synthetic
Still, Toyota was very accomodating in my case, replacing valve stem seals and the head gasket just before the powertrain warranty expired. And even though I had done all of the oil changes myself up to that point, the dealer accepted my oil and filter purchase receipts without a fuss. It would have been easy for Toyota to "trample" me -- "You have the receipts, but they don't prove you actually used the oil and filters on your Camry -- you could have just been stockpiling them in your basement. Or maybe the oil went into your '74 MG you drive for fun."
Also, as others have pointed out, Toyota replaced at no cost to consumers the faulty head gaskets on the V6 engines used in the early and mid-90s trucks and SUVs.
So the company's stance on sludge seems completely out of line with their actions on other problems (unless of course, faulty maintenance, for whatever reason, was responsible for the sludge forming).
One more thing: I'm still not aware of any posts from anyone who had their Toyota serviced exclusively by a Toyota dealer and got sludge.
He also told me of another vehicle in which sludge had been detected. The owner claimed that he had done oil changes every 3000 miles, but had no receipts. When he was told that he would have to present the receipts, he left and returned with a printout from an oil change place (don't recall the specific one). Upon examination, the document looked suspicious; each oil change was EXACTLY 3000 miles after the last one. Not 2999, not 3001, but 3000. The dealership contacted the establishment and, upon questioning, the manager admitted that he had falsified the documents at the owner's request.
For the record, my tech friend strongly recommneds the 3k change interval and the use of Toyota filters and 5W-30 oil.
Ken
Ken
No wonder bin Laden can hit us so easily.
Thus, must discount this story!!!!!!!!!!!!!!!!!!!
I posted something similar about a dealership's service department requiring a 5-week wait for an appointment if you bought your car there, and no appointment available at all if you didn't. My source is an insider, and credible to me; however, I would not give him up (if asked) and possibly cause him to lose his job. If you don't trust the secondhand info without a name, you can disregard it. That does not mean the info is untrue.
The way of the world.
Besides, these are second hand acoounts, not even the person that was involved
None of them will have believability without VIN's
For more information on this dealership, check out www.browntoyota.com.
