Anyone put 285 tires on a new 1500HD or 2500HD ?
For Harvestmooon:
Check out the message boards in the 2500HD
section labeled "Silverado/Sierra 2500HD"
There are several posts that'll give you
some insight about tires and rims.
Recommendations....285 on an 03 HD you must go to a lift kit or cut the bumper in order to achieve the correct unobstructed turning. Inner fender will also have to be smoothed with a heat gun.
Scott
There is a guy over there with a 1500HD with 305s and even a guy with a Z71 running 315s with no lift (it is awesome hard to believe but he does it)
Ryan
Thanks in advance.
kip
Thus, the 285 hits the bumper so much that you end up hooking the bumper with the tire every time you try to articulate the steering from one side to the other.
Options:
1.) Suck up the fact that you just spent $35,000 and cut the bumper. You'll have to use a heat gun to massage the inner fender as well. (stock suspension).
2.) Spend the $1600 or so and get a lift kit that will allow for the use of 285 or larger tires.
Gentlemen, this was a post to help, not hurt. I was the first customer with a new '03 in the shop where I bought the wheels and tires. It was then they told me that 285s' were no problem until....it happened. As I stand there with four other mechanics looking on...they realize that the '03 is different. "No wonder they put 245s' on this thing...because even a 265 will have to have very minor trimming of the valence performed.
That's where the two options came into play for me.
I opted to level that truck out with the torsion bars and use a 265.
Hope this helps.....not really an expert but this should be enough to get you to believe.
315 goodyear MTRs on a stock 2500HD
Pretty sweet (almost makes me wanna trade my truck in
http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=85259
Ryan, I didn't see any pics of that '03 2500HD with the 315's where the wheels were turned. Perhaps he only drives in a straight line.
Here is a link to pics of my 2500HD with the 285's. To me, 315's are too big for stock. But I bet they would look pretty good with a 6" lift!
http://www.picturetrails.com/gallery/view?p=999&gid=747605&uid=526167
Finally decided it was time I got a GOOD present for Christmas. '03 Polaris Sportsman 400 4x4. Now who says that men don't know how to shop. Oh for some snow!
Happy Holidays to all!!!
The roads are plowed (except my street) so its no fun driving anymore
Wish i had a snowmobile but santa didnt bring it or he is still out driving it
I run a 02 1500HD, 6" RCD lift,& 315 MTR's on 8" Weld's. Guess what, my front tires will rub slightly under certain off road conditions. The bumper is not the issue as I have replaced mine with a Ranch Hand front end replacement bumper/brush guard which provides more clearance than the stock bumper. The interference is at the back of the wheel well. I understand that the guys who run 315's on a 10" wheel (lifted of course) have an even greater problem with interference. I run Studded 255/85's on steel wheels in the winter.
