Dimensions -how big are these things?
                    I can't give you the dimensions, however anyone that can will need to know which configuration you're considering.  Such as the Supercab longbed, Supercab shortbed, Regular cab longbed, etc...  You get the picture.  The length can change considerably depending on the configuration.  If you're concerned about the width, well then that won't change.
Walt? Where are you? I know you have the answer.
Loved it, would have bought one today, but it is just too huge for my garage (length not an issue), just height and width.
Bob
But you need to drive em too.
I do not think the F150 was the smallest dimensions but it sure was easy to drive and visibility is excellent. The Avalanche may have been smaller (I do not recall) but I found it harder to drive and visibility especialy out back was terrible.
Perhaps in about 30 years, my eyesight and other mental capacities will have deteriorated enough to where I will shop for an "easy driving truck"
Get a Titan, dude - or get there last
By the way - the 1500 Crew Cab Sierra doesn't have a 6' or longer bed, does it? And even the Denali 1500 doesn't sit 6 so you can't get 6 passenger in that.
That brings you back to a 3/4 ton - which is NOT what the Titan is and it doesn't try to be. So don't try comparing the Titan to the 2500, compare it to the 1500 - which it beats in almost every way.
Congrats on your 2500, but please don't come here and dump on the Titan because it doesn't offer what your vehicle does. They are not in the same class. The Titan is a 1/2 ton, the Sierra is a 3/4. The Titan is cutting edge, the Sierra is old technology (except the 4ws)
As "kcflyer" said: "...this thread is about size."
Comments like that tells you he isn't dumping on the Titan? Besides this thread was about dimensions on the "Ford F-150, Nissan Titan, GMC C/K 1500 Series" as stated above. That was the point of my post. This thread isn't about why somebody went out and bought a 2500 series.
There are plenty of other threads where you can bash/trash/gush about... whatever truck you want.
Bob
It's still listed in the '04 Chevy and GMC brochures.
8600 GVW has always been a HD 3/4 ton. I believe the F-250 Super Duty and Dodge 3/4 ton models are still rated at 8600 pounds. Yes, the the GM 1500 HD was nothing but but marketing smoke and mirrors.
Bob
