Toyota Sienna Maintenance and Repair (2004+)
1. FM modulator for the port installed dvd player had a buzzing sound through the speakers when in operation. Resolution: moved FM modulator away from the nearest power source.
1a. Parking brake would not disengage. Resolution: adjustment and lubrication.
1b. Abnormal sound in drive side door frame (next to my ear) like adhesive being pulled apart repeatedly. Resolution: lubricated foam door seals.
2. Gas tank recall. Resolution: replaced.
3. Passenger side second row captain's chair rattled. Resolution: adjusted anchor and replaced brace.
4. Pause before transmission engages after depressing gas at low speeds. Resolution: updated software for transmission timing (see Technical Service Bulletin).
All the problems listed above were all covered under the warranty and was resolved by the Toyota dealership in Katy. I just needed to articulate the problem carefully.
We have taken our van long driving from Houston to El Paso then to the Grand Canyon last summer. After a few days in Las Vegas we continued our trip to San Diego before spending the rest of our vacation in Los Angeles. The van is fun to drive and did not make me tired even on long hauls. The dvd was great. It kept our two kids occupied (with headphones) while my wife and I talked and listened to music and other things on the CD. This year we are going to Washington DC and New York.
We would get 26 to 28 MPG on the interstate on the long trips. Usually about 23.5 mixed city and highway around town.
I've had van about 4 months. Dealer will have part in tomorrow, went there yesterday. I'll let you guys know if it's the bulb or another part. Strange to have it fail so soon.
Along with the AC problem I posted about recently, I have experienced this sluggish transmission as well. It will be great to be able to not only describe the situation to the dealer but to reference the TSB on transmission timing.
And this makes me wonder how many other characteristics of the Sienna I've been taking as "that's just the way it works" when in fact they are defects. And that makes me determined to read this forum much more often!
I tried following the owner's manual instructions: Press and hold the desired homelink button and cycle the garage remote button every 2 seconds until the homelink display light flashes quickly. This should happen about 20 seconds after holding down the homelink button. All I get is a slow flashing. I assume it will have learned the frequency when it flashes fast.
Help, any suggestions?
Thanks in advance? Oh btw, I have an LE AWD (arctic pearl white) with a spoiler, fog lights, 17" rims and tinted front windows. It looks very cool in an SUV kind of way. :-)
I purchased both (desert sand) and I used it on a spot... I purchased a paint pen. Its very hard with the metalic paints to match exactly... But its better the nothing.
Message #587 Re: Finally able to program my garage door opener by kip Mar 29, 2004 (5:01 pm)
I had the same issue as ideaphoria, but ours was a single CD player (9/03 XLE build). Over the course of six months, the dealer was not able to re-create the problem. It drove me nuts because it was completely random. After I filed a complaint with Toyota and got my salesperson involved, the dealer agreed to replace the unit. Problem completely solved.
As ideaphoria described, if you have the same problem, you can isolate it to the CD unit if you wait until you hear it again, then stop the sound by pressing upward inside the cassette deck (in my case). The sound should stop until you stop pressing upward. My sound was more of a rattle vs. the banging sound you described, though.
I needed a front end alignment anyway so the trip wasn't a waste.
It could also be bad wiring. I'd be suprised if the technician hasn't check for voltage at the light.
We have the same sound. It sounds like the weather stripping at the top of the door is moving. At first I thought the door wasn't closing enough, but it seems tight to me (and doesn't leak). It hasn't bothered me to the point of bringing the car in. I was waiting for the next oil change to mention it. Regarding MPG, we have about 7,000 miles and are getting between 20-24 mpg overall. On long trips we get around 27.
my wife had the very same experience except it was on a freeway at 65mph with several children in the car. She pushed the gas pedal all the way down since she wanted to pass a car in front of her. When she let go, the pedal stayed on the floor. She tried to brake but against the full throttle, it did not really work very well. She actually started smelling the brakes. Then she put the gear to N and tried to stop it that way but the engine was revving up so she put it back to D and stepped on the gas several times until released itself and then she stopped the car. As you say - very frightening experience.
We towed the car to the dealer, they had it for several days, tested it, called a factory specialist and declared that there was nothing wrong with the car. We could not make them do anything else (e.g. replace all parts that could have contributed to the problem, etc.)
Anybody else had an experience like that? Any advice what to do? We don't want to have this happen to us again.
Worth checking for carpet interference.
The major problem that we have had with this minivan is the manual sliding door. This door refuses to latch open on an intermittent basis. It occurs with the window fully up and does not occur on a predictable basis. It is extremely annoying as it is the side that my infant daughter rides on. The minivan has been back to the dealer 4+ times for a repair and the dealer has 1st time: replaced the latch, 2nd time: could not duplicate the problem so they did nothing, 3rd time: replaced the latch, and 4th time: told us that it happens when the window is down because that was how they observed the problem. We are picking the minivan up tomorrow (after it being in the shop 6 days this week) with no resolution.
We have not had the minivan a complete month since we took delivery and we estimate that we have been without it for 15-20 days over the 5 month period. In MD where we live for a car to be declared a lemon a complaint must be registered before 15,000 miles, the problem has to be "repaired" 4 times, and you have to be without the car for 30 days over a 15 month/15,000 period. We have complained to the dealership and their resolution was to offer us the option of purchasing (at our cost) an extended warranty which normally is not available outside of the 30 day period after delivery. We contacted Toyota directly and they are referring a regional rep to deal with the dispute. Anybody else have suggestions what to do?
You need to put your light switch to Auto
I came back 15 minutes later and it was still making the sound though with slower intervals.
Some earlier posts mentioned possibly similar clicking sounds, but I saw no resolution.
Does anyone know what might be causing this or if it is just normal?
By the way, for roadtrip averaged about 26.5 mpg with A/C running most of the time and doing about 70 mph.
Has anyone else noted this? Could I ask some of you to try this at about 60 mph and let me know what you experience. You just have to cruise at a steady 60 mph or so and check the rpm when you go up a hill. has anyone noticed this when towing a trailer?
My concern is that I want that additional torque when needed when towing the trailer.
Thanks for your help.
Re: "Many thanks to tolenal for posting this message - I found it very helpful, especially: 4. Pause before transmission engages after depressing gas at low speeds. Resolution: updated software for transmission timing (see Technical Service Bulletin).
"Along with the AC problem I posted about recently, I have experienced this sluggish transmission as well. It will be great to be able to not only describe the situation to the dealer but to reference the TSB on transmission timing."
