You might want to switch, in Winter, to 0-30...
-Brian
So far as I know, it is a multi-function indicator, and engine mis-fire isn't the only reason it would be on. Check the Owners Manual....
This is the whole part regarding blinking light. The other part is related to CEL staying on steadily.
If it's engine misfire, can anyone confirm if this is under major component warranty?
This morning when I started the car, the CEL did not blink nor come on. Please note that the temperature I used was Celsius and not Fahrenheit. This morning it's 2C, i.e. about 35.6F, which was colder than last two mornings, which were around 6-10C, i.e. 43-50F. So I don't think cold weather is the reason. I'll update the situation after I go to the dealer tomorrow morning.
A new ignition coil costs about $80 and there's only one, so it's not that expensive.
$400 sounds high to me. I've replaced one in less than an hour, it's not hard. It's right at the top of your engine, where the spark plug wires end.
See if they changed the wires or anything else.
-juice
I'm a little bummed that this happend, but any car with >=100K seems to be candidate for major repairs.
I have a 05 Accord EX6 Coupe to drive, but recently we bought a new dog, so I'll probably sell both cars to get something that gives me a smooth, fast ride with some level of utility. I'm leaning towards either a 6 Cyl RAV, or a Legacy GT wagon.
Overall this was great car, and I would recommend it, I just don't like to own cars as they get older and more problematic.
Plugs are about a 1 hour job, I would hope out of good faith that the job didn't come to more than $100. If you are in the Fresno area holler at me I will do it at no cost. Least I can do considering how much work my two boys have caused teachers over the years
Your Forester will run just fine on 87 octane. I always get ARCO as it is the cheapest.
Seat warmers always on? Haven't a clue.
John
Even your local Subaru dealer should be willing to plug into it and tell you what the trouble codes are for nothing. The check engine lite is programed to come on for major maintenance, as a reminder.
When posting here about issues, always make sure you specify the mileage, and in the case of a Subaru Forester, if it is Turbo or not.
With several things going on, it does seem to be electrical, and if the seat heaters are on, the lights on the switches should be lit.
Take it to the dealer, it might be something simple. If not, they can easily diagnose, and you can decide what issues to fix first, second, and all of that, and where. ALL teachers are on a budget, we know that, let us know what the outcome was! Just by posting you already have an offer of help from a user nearby.
As for plugs, $100 would be the min amount, it's a royal PITA to change em on most subies (except my XT6)
-mike
Sometime you just have to learn to face facts, man! You guys in NY are used to being ripped off, lol. :P
If a dealer charged me for that, I would never do business with them again. Out West we don't think much of those business practices...
mike is right, most dealers will charge $88 or so just to reda the code for you.
You can buy an OBD2 scanner for that much, and read codes forever.
But even better, find someone local that has one, and borrow theirs. I have one, if you're in the DC/MD area I can show you how to use it and read/reset that code.
-juice
Autozone does it for free, but that is just about the only place I've ever seen a free OBD II scan. Most places will take the diag cost off your bill if you get the repair done by them.
-mike
Trak Auto does that as well, and I have even had the Manager of a Pep Boys do it.
How far will you guys go to make yourself right? My Subaru dealer, my Mercedes dealer, have never charged me to put the code reader on one of my cars, if I suspect something is wrong. Now, I might have to wait, if they are busy, or bring it back, but my experience isn't what yours has been.
Used it that time, then once on my wife's car (just a gas cap), and for two friends of mine. 4 times already.
-juice
Autozone here scans, as does the Trak Auto. And of course, both sell the devices.
-mike
But...in my wife's case, it was an Evap code, i.e. loose gas cap. I would hate to have to pay to find that out. I think a case like that should be free.
Others that need a repair should obviously stick with the place that helped them scan it in the first place.
-juice
Even though my buddy with a CEL on his pickup is willing to buy me lunch for a scan, it's still 15 mins + of both our times.
Pick up you own, you can get a basic unit from Amazon for about $50. The P0174 on my Mazda MPV that indicated a lean burn condition on bank 2, ended up being a dirty Mass Air Flow sensor. An $8 can of MAF cleaner from NAPA took care of the problem.
Basic DIY, I am all for it. After that, fork over the big bucks (hopefully the big Subaru Bucks at that).
John
Once you know where the plug is, it's easy to hook it up.
-juice
John
I just did a quick web search, found the code and people reported causes being the spark plug wires and the ignition coil.
Guess what? Found some wires had been chewed up. Probably by a chip munk I've seen coming from under the hood more than a few times.
Replaced those, and the code never came back.
-juice
-juice
-juice
-mike
LOL, what you are experiencing is a well known phoenomena with Subaru's. Don't worry about it unless there is something else going on. It appears to be just a "noisy" characteristic of the Boxer engine.
-juice
-mike
1998 Forester, 2.5, auto trans, 117k miles. Driving along, fully warmed up, outside temp about 25 degrees F, Coolant temp was normal, going about 40 mph. All of a sudden AT Oil Temp light starts to flash and the Service engine light comes on solid. On a country road so I pull over to the side. All seemed normal except for the SE and AT Oil Temp lights.
I drove another tenth of a mile or so to a “flatter spot” to check the trans fluid. Left her running in park and pulled the trans dipstick which is difficult at best on this vehicle. As I was putting the dipstick back in, the engine stalled. After that, all it would do is start, rev up to about 1800 rpm, come down to an idle and fumble at idle and stall. It will do this consistently. I’ve started and watched it stall about 20 times.
Had to Flatbed her home.
My genius son rang the code out and then erased it. It came out as a P0103, Mass Air, High Input. I have started this car no less than 20 times and it consistently goes up to fast idle and comes down to idle, fumbles and dies. The SE Light has not come back on and the Airflow Data looks OK on my scanner during this short running period.
Any ideas?
Checked mounting of crank and cam sensors.
Checked to make sure EGR valve was not hanging open.
Pulled Fuel filter: had a small amount of water in it but filter only has about 16K on it.
Threw a new fuel filter on anyway. Cycled key a few times to fill new filter. Started car and it ran longer than usual before stalling, about 15 to 20 seconds. During these 15 or so seconds, the SE Light came on and the AT Oil Temp light started flashing. I scanned out the codes, P0103 with a P0102 pending code. Both codes point to the MAF sensor.
I went to the wrecking yard during the day today and rescued the MAF out of the previously pristine 1995 Legacy that my daughter rolled almost a year ago. You would not believe she walked away from that car without a scratch. I cleaned the MAF Sensor and installed it in my air cleaner box. The PN was a match. Well, close enough.
Started it up and she race up to about 1500 rpm and slowly came down. Both lights, SE and AT Oil Temp (flashing) were still on. I cancelled the codes with the scan tool but did not know what to do with the flashing AT Oil Temp light. For giggles, I shut her down and waited about the length of the Jeopardy theme and restarted her. The AT Oil Temp light was out. I road tested her and all is well with the world.
My only two questions now are:
Isn’t there supposed to be a limp home mode so you don’t have to call for a tow?
What’s was the deal with the AT Oil Temp light flashing?
Given the mileage, I would suspect the spark plug wires if they are original. I'm on my 2nd set, you're close to needing your 3rd set.
If it still has stalling issues, I'd look to spark or fuel. You were spot-on with the fuel-filter, and for spark I'd look to, in order:
* spark plug wires
* spark plugs
* ignition coil
Don't be intimidated by the 3rd, they're just $80 for the OE part and it only takes one.
No idea about the AT Oil Temp light, it almost seems unrelated.
-juice
Temp light flashing is related to the MAF and that there is no limp home mode for a MAF failure.
Wires are less than a year and 10,000 miles old.
She runs good now but I have the 2.2 MAF in it. I am ordering the correct OEM MAF from Subaru
All codes in this case were MAF related. Early on in this affair, (Tuesday) I did procure the factory manual info to trouble-shoot the MAF Sensor but with my real life middle name being Thomas, I doubted the result that told me the MAF was in fact bad.
All is well now. I mainly posted the follow-up in order to help others with a similar probem. Online research for this problem, which was a little help, uncovered horror stories from people with similar issues but no resolution.
Thanks for the reply.
-mike
This annoyance was resolved after a negative maint. survey was sent in. The dealer contacted me and wanted to look at it again. They ended up changing the cam tensioner, pulley and the cam belt. The noise is now gone, forever I hope.
I read the early posts on this thread about this issue with inferior head gaskets on some on the 1999-2001 (or 2002) Foresters, but I wanted to know of someone had detailed info on what it was that the dealers added to the coolant to "fix" this problem.
Was it some sort of "stop leak" stuff? Was it aluminum pellets?
Does anyone know if this was just a way for Subaru to get the car past the "extended" warranty period without having to shell out big bucks for lots of engine rebuilds?
By the way, this same "mint" Forester needed a new rear wheel bearing - $450! It also needed an alignment (toe was WAY off), new tires and moonroof has mechanical problems (sticks, won't open). Sigh!
