wwhite2: What did you do to receive an invitation to the SCCA racing? Is it just something they send to CTS (or CTS-V) owners automatically?
Road and Track comparisions judge the cars in 3 categories, Performance, Subjective and Price. The Mercedes took first on performance, Chysler took first in price.
I confirmed my tickets (2) today and they will mail them to me .We will have a 3 day pass and on Memorial Day we can view the racing from the Cadillac Hospitality tent . I am psyched to say the least
M
After keeping the car overnight, it turned out the problem was a broken steel belt in a rear tire. Since I had a LuxSport, my tires were covered under the TSB previously mentioned on these pages, so I got 4 new ones for free. Otherwise, nothing else wrong with the vehicle. I'm a very satisfied customer with Cadillac and with my dealer's service department (Andrews Cadillac, Nashville).
The accessory power outlet will only operate when the
ignition is in ACCESSORY or ON and for 10 minutes
after turning the ignition to OFF. If you would like
the accessory power outlet to operate regardless of
ignition position, and for extended periods of time,
you can do the following:
1. Open the hood and locate the underhood fuse block.
2. Find the I/P OUTLET and OUTLET fuses and
move them over a space, to the open cavity
next to each fuse.
The layman's explanation I read was:
Each of the interior outlets can be changed from a battery feed to a switched ignition feed. (One is the cigar lighter in the ashtray, the other is the auxiliary outlet in the rear of the center console.
To do that, go to the underhood fuse center and look for a bright yellow 20A fuse and a bright green 30A fuse that are in "wide" spaces (sorry, don't have a picture). Looking from the front of the car, they're kinda to the right of center and slightly above, between some relays. Anyway, these are the only fuses that you can move from side to side. The center contact is the one that eventually feeds the outlets. The contact on either side come from either the battery or the "cigar relay" (the switched feed). You use the fuse to bridge the appropriate gap:
If you want the cigar outlet to be on a switched supply, move the yellow fuse one position over in the same space. If you want the rear outlet to be switched, move the green fuse one position over. The factory fuse positions bridge the gap between the battery and the center contact.
GM's "battery rundown protection" circuits have saved my bacon a couple of times, but this one was a little too paternalistic for my taste.
I will give GM this .. their automatic photocell-triggered headlamps are far and away my favourite convenience item, and have probably saved me a dead battery or two. I've had them in my GM vehicles since 1996 and still find it very disconcerting when I'm driving a non-GM rental car, which I do quite often, to have to find and turn on the headlight switch, and then remember to turn them off.
bxd20: Thanks for the info...it will save me a trip to the dealer. All my 2003 manual says is "see dealer for more info".
Exterior Lighting Battery Saver
"If the parking lamps or headlamps have been left on, the
exterior lamps will turn off approximately 10 minutes
after the ignition is turned to OFF. This protects against
draining the battery in case you have accidentally left
the headlamps or parking lamps on. The battery saver
does not work if the headlamps are turned on after the
If you need to leave the lamps on for more than
10 minutes, use the exterior lamp control to turn
the lamps back on."
The way I understand the headlamp switches to work, unless the key is in the ignition and turned "ON" or "START", the AUTO headlamp setting should not work at all. You would have to override by turning the headlamp switch to ON. If you do have the key in and turned on to run lights, radio, etc. you may be disabling the Battery Saver.
I had the same thing happen while setting up my navigation system for a trip the following morning. I had the ignition on to run the navigation system, and because I was inside my garage the headlights came on. They quickly ran down the battery.
If you want to listen to the radio turn the headlights off manually at the light/signal stalk.
7. Volvo S80 T6
6. BMW 530i (!)
5. Audi A6 3.0 Quattro
4. Chrysler 300 (3.5L)
3. Jaguar S-type 3.0
2. Mercedes-Benz E320
1. Cadillac CTS (3.6L auto)
What's really surprising is that the BMW came in next to last. The writers complained about the styling, iDrive and the new steering, which although is great isn't as good as previous BMW efforts. They called the car more luxurious than sporty. Ouch. But the $54k large price really put it to the rear of the pack.
The CTS was 1st in 0-60, 1/4 mile and tied for 1st in the slalom and fuel economy. It won half of the subjective categories including the important driving excitement, engine, brakes, steering, handling and seats categories. They even liked the styling, which is interesting considering how BMW got slammed.
Well done Cadillac!
05 production begins on May 17th. There are some early build models already being driven as test vehicles. 6-spd manual will be available in June.
The new 2.8 will be available in the fall with a 6-spd manual and the auto. Reported to be around 210hp and 200 lb-ft. torque. I would imagine this should be a decent base engine. Price should base under $30k.
I will be interested in this version of the car. I enjoy the ride/handling attributes of the CTS and have no issues the power of the 3.2 or "ultraleather" seats.
If this saves me some money, then that's great.
The CTS is a great car, but expcept for styling and interrior the G35 can give it a real run for its money, with a 5hp advantage on the engine (although requires premium expensive fuel) and a few thousand dollars lower price, its funny that the Infinity was not invited to play, did the article say why?
BTW WOW! CADILLAC RULES, and now its about 6 points away from Lexus in initial quality too! If this is what GM can do with unions, just imagine what they could do without!
I'm still not quite warmed up to the CTS exterior, and the 3.6L wasn't out when I was ready to buy, but GM's really beefing this car up a little every year. It's nice to see some real competition in the sports sedan market. 3 years ago, BMW was it. Now we have options.
Automatics could be the other reason. I don't think I've seen a test of a G35 auto... maybe it significantly affects the performance of the car.
Looks like GM is already working on a higher performance version of the V...
One thing interesting about that picture was the larger wheel flares hiding the wider tires. It looks like Cadillac is addressing the only serious issue with the current CTS-V...wheel hop on acceleration. The new wider rubber should be more than enough to handle that much horsepower to the rear wheels.
One thing for sure is that the upcoming STS-V and XLR-V can't be any worse for power than an CTS-V+, if produced. That means fun times ahead...
We started using mid-grade ($2.24) every other fill-up. We refuel at half a tank. The CTS runs great, infact we actually picked up 1-2 mpg, but it might be because I'm driving more carefully and watching the mileage closer.
I ran out of gas on the NJ last week, first time ever (hopefully the last also). Cost me (actually GM) $36 to get 5 gallons from the NJ Turnpike Authority. So compared to the $7 per gallon that gas cost, our $2.19 isn't too bad!
However, the 3.2L in the 2003's recommend 91 octane, although they will run without damage on 87.
FWIW, here in the Toronto area, regular gas is running around C$0.90 per LITER, which converts to about US$2.25 per US Gal. Premium runs $0.10/L higher, or about $2.75/USG. $1.92 sounds cheap right now.
Both reasons are archaic, but the voters have chosen to not revoke this numerous times.
6DP69....CTS.............$31,700.00......$695.00
Option Packages:
Optioncode..............Description..............................- ..........MSRP
1SB........................1SB Equipment Group..........................$0.00
1SC........................1SC Equipment Group..........................$8,250.00
PDA........................California CTS Package........................$1,820.00
.............................California Discount w/ PDA....................($550.00)
PDB........................California CTS Luxury Package...............$5,965.00
.............................California Discount w/PDB.....................($1,000.00)
PDL.........................Luxury Package.................................$3,165.00
..............................Luxury Package w/ PDX.......................$2,615.00
PDX........................Sport Package...................................$1,875.00
..............................Sport Package w/ PDB.......................$1,325.00
Additional Options:
OptionCode.............Description...............................- .........MSRP
Audio Systems:
U2K.......................XM.....................................- .............$325.00
U2S.......................Bose...................................- .............$1,275.00
UAV.......................DVD Navigation System.......................$1,850.00
Engine Block Heater:
K05........................Engine Block Heater............................$60.00
Lamps:
TT6........................High Intensity Headlamps.....................$645.00
Paint:
29U........................Red Line Premium Paint........................$995.00
98U........................White Diamond Premium Paint................$995.00
Seat Options:
AM9........................Split - Folding Rear Seat......................$450.00
Sunroof:
CF5.........................Express Open Sunroof.......................$1,200.00
Suspension:
FE2.........................Delete Leveling Suspension.................($185.00)
Transmission:
M82........................5 - Automatic Transmission.................$1,200.00
__________________
I don't think I need 1SB so I may buy an '04 with the 3.6 and auto and sport package when the '05s hit the lot. Color doesn't matter to me so I think I should be able to do alright. I just hope that there is another $1000 bonus cash offer at that time that I can add to my $1000 GM card money and $1500 conquest cash for my wife's Jeep.
