Lexus RX 400h Engine Problems
Since day one (now got 8000 miles) I often get a stuttering or engine miss feeling at steady 30-40 mph. This problem isn't constant, but it does bother me. Anyone else experience this?
I just got my 400h last weekend. When I test drove it, the engine was as still and quiet as could be at startup when still in the "park" position. Now that I have it in my garage, I am noticing different behavior. When I turn the key position, it is completely still at first for about 3 seconds. After that, I will still be in the 'park" position, but it will feel like the engine has come to life and I actually feel it running, like I would feel the engine of a non hybrid car. Is this normal?
Mine is a problem that occurs in same speed range as yours and probably happens 30-40 percent of time time. None of the gauges (mpg, etc) show any corresponding "fluttering" when the engine pulsing happens.
If you ever find a solution, pls respond.
Garrett
That sounds bad. Most of our surface streets are 35-40 MPH. Does your state have a Lemon Law. If you have all the dates you were at the dealer I would try to invoke the law. They may be trying to jack you around till the warranty expires. I would get a signed statement each time you take it in, stating they are working on the problem. Keep us posted.
Thanks for your response and I will keep you all posted.
sorry...
Regarding the free service at 5k miles. I was unhappy with the dealer service for the following reasons;
-they had me wait at least 2 hours before they reported that the service was completed.
-they did not rotate the tires. (I marked them so I could tell)
-they ignored the issues I brought to their attention. eg. squeeks.
The dealer has all kinds of services they subscribe to in order to get a report about how "wonderful" they were with my car. When they called me, I let them have it! The next day, the customer service rep from the dealer called me up to find out why I was so unhappy with their service. She asked me what they could do to rectify the problems. I said; Pick up my car and leave me the loaner until you deliver it to me with the service completed and do it next time for no charge. They agreed and sent me a letter confirming the free service. We will see about the car pick up.
Another thought-- The prices they charge for an oil change and tire rotation are outrageous. I think its about $70 in Florida. Not as bad as getting a Porche done for $300. I have always done my own oil changes on the Lexus rx300- vin tage 2000. I use only Mobile 1 and Toyota oil filters. The car has 189k miles and runs like the day I bought it. I would like to sell the car, but when people see the milage, they run as fast as they can.
Good luck with the stuttering.
Bobgail
My father drove the car after taking up to the airport, and he said that he thought that he was going to get sick from the rocking/pulsing that was going on around 40 mph.
I have called an arbitrator to start process and if they don't have a soulution very soon, I guess that is the next step. I should have given them the car back the first time because it was within the 30 day, but I believed them when they told me they were working on a fix. I thought that it would not be the right thing to do to give them the car back and demand my money back although at that point I had the legal right to do that. I thought that I was standing by my word to buy the car and that they would stand by their word to deliver a car worthy of the $55,000 price tag and Lexus name. Guess they are trying to prove me wrong and a fool!
Cheers.
Hope your situation improves.
Ethan
Yes, car now has 2,000 miles and has gotten better. Problem before was that at cruise at about 60 mph with constant gas peddle, power would oscillate up and down. Power still feels a little off, but oscillation is gone.
Does anyone else have this problem? Should I take it in under warranty? I still get 26-28 MPG so for the most part I'm satisfied, but this one thing irritates me.
So, now there is an 'official' technical service bulletin isssued by lexus. EG013-07 Title: "Rocking" Feeling at Highway Speed (Around 70 MPH)
I went back to dealer today armed with this info, and after more convincing to take me seriously (more test drives with the tech who didnt sense anything wrong), they finally read this service bulletin after my insistence.
It took a few hours to install the software patch. i just did a nice long, test drive tonight, and the problem is fixed. so nice to reach 60mph without feeling a powerless, shuttering blob. what a relief after putting up with this for 15,000 miles.
so if there are others out there w this problem, you now have the cure at hand. you just have to bring Lexus a cure to fix their own vehicles, and you will be fine
what's year/month is your RX400h?? because I do not have that stuttering/pulsing issue. I 've tried all range of speed (5mph-35mph in local road & 40pmph-80mph on hwy)
I drive a C6 Corvette so the wife thinks I don't like the way it drives in general....but really it's quite irritating. Anyone else had this issue?
Have you tried that..?? Same symptoms...??
Almost all new cars use DBW, E-throttle, wherein the gas pedal is NOT connected mechanically to the throttle plate. The gas pedal is connected ONLY to the engine/transaxle controlling ECU.
So the car can react to "pertubations" in the roadbed, along with MANY other circumstances, without any movement whatsoever of the gas pedal. For instance if the SOC of the hybrid battery is such that it requires use of the ICE for recharging the ICE RPM can rise to meet the additional HP/torque requirement but due to the CVT roadspeed should not be affected...."should not" being the operative term.
Has anyone else had this problem?? I know for certain that I was not pressing on the accelerator when this occured.
