1) First thing you have to do is Pair the Phone with the Car which was pretty straightforward.
2) I then tried a call and found it worked great so now wanted to transfer all me phone numbers from the phone to the car. This is where I got stuck. I called Verizon and they are usually great but had no clue on this one and passed the buck to Toyota of course. As it's New Year's Day Toyota was not open so I did some surfing and cobbled together this solution.
3) When you go into the Bluetooth menu on the Camry Hybrid Nav system there is an option to "transfer phonebook." When you click it you see "transferring data" but then the Bluetooth DISCONNECTS. So I thought there was a problem with the phone or the Camry because it keeps disconnecting in the middle of this. Turns out this is the desired procedure.
4) So when the Camry says transferring and you see the Voyager (or your phone) disconnect from Bluetooth that is good. Now here is the answer.
5) Go To "Settings and Tools" on the LG Voyager
6) Select "Bluetooth Menu"
7) Click on the "Camry Device" which comes across as "HANDS FREE" unless you change it to "Camry" like I did because I also have a Motorola Bluetooth T505 Visor Speaker in my wife's car.
8) Click "Optioins" at the bottom of the Voyager screen while "Camry" is the selected device.
9) Click "Send Name Card" and then the Voyager will search for the Camry Bluetooth and reconnect and show you all your contacts.
10) Within my Contacts list on the Voyager I click "Options" and click "Mark All" and then send all the contacts from the Voyager to the Camry.
11) It took about 15 seconds to transfer 244 contacts and now they are all safe and ready to go in the Camry. Real nice process but not that intuitive to figure out.
12) As far as maintenance goes I think I will only update contacts in my phone and maybe once a week transfer all thos contacts to the Camry.
Hope this helps someone!
The compatibility chart is nice but it isn't even half the story. For those of us who are stuck w factory installed bluetooth, who can recommend a good phone? (a reliable unit that connects easily, where listener and caller sound very good,) Cell provider and model please & thank you.
I'm just talking about pairing, connecting, and call quality. No problems.
I have never tried to import my contacts, though. I've just entered the 5 or 6 that I call the most. for others, I just dial from the phone's contact list.
Could you share the brand name of
"My local shop could have provided SUPPORTED bluetooth with display, gps, and on-star-esque service for half the price I paid for factory installed bluetooth."
I would like to pursue that.
aldelfino
I recently bought an '07 TCH and am trying to get my Samsung phone (with ATT) to work with hands free bluetooth.
When I turn on bluetooth it directs me through the "pairing process"
I say and confirm a name.
Then it shows a passkey number and says it is searching for passkey.
And this is the farthest I get.
* I have tried to dial the passkey #
*I have tried to dial a number in hopes it would pair with my phone.
*I have tried to ask for "help" through this phase, with no success.
Since it is a used car, I wonder is bluetooth trying to find the previous owner's phone?
I would love to initialize and start from scratch, but I cannot find a way to get around the "pairing" exercise.
In connecting this phone to other bluetooth devices, my phone has usually phond such devices with no problem. But it doesn't seem to find this system.
I sure hope I am doing something idiotic and can be steered into the right direction.
Please help this frustrated new owner.
The "linking' does not hold!! I need help!
Select Info on the Nav system.
Select Telephone.
Select Settings.
Select Bluetooth.
Select Delete (in case you have a phone registered already; I also noticed it's good to start with a clean slate, as it were!).
Select the phone(s) to be deleted. Say OK.
Select Yes for "Delete the registration of this telephone".
Go back to previous Bluetooth Settings menu.
Select Register.
Set your first phone - follow the prompt on name, passkey, etc., and pair your phone by entering the passkey for Bluetooth.
Follow procedure for second phone. When you do this, it will ask if you want to Disconnect the other telephone already connected. Select Yes. Follow prompts for pairing second phone. At any time, only one phone can be used; if both are present at once, you have to select (by default it selects the one that had been connected).
Hope this helps.
http://t.co/tV82l0Qsrh
