It's also possible that the methods of the tire changer could crack a wheel, but most of the modern machines are pretty good at protecting them. The simple expedient of overinflating the tire to help seat the bead can be problematic as well. It usually damages the tire but could damage a wheel under extreme situations.
I was disgusted to learn this rim problem is not uncommon, and that BMW is not backing their product... ARG.
Personally I believe the problem "demand" in that folks have become so conditioned to "believe" the larger the wheel in relation to the overall diameter of the tire looks "better" and is a good thing for handling (it isn't beyond wheel sized of 16"-17"). Many manufacturers have been caught in this trap as they've found that if they offer a car with say 17" wheels and 18" wheels, the car with the smaller wheels rarely (if ever) sells.
BMW gave me a similar response; sorry, wheels are not covered. I did finally take the car to a local shop here in northern CA (Wheel Technologies) and they repaired the wheel; they showed me the three cracks present in my wheel. They also told me they see this problem at least ONCE a day for later model BMW and Mercedes cars.
This does seem to confirm (at least to me) that BMW really does have a problem with their alloy wheels; they simply aren't strong enough to hold up to normal streets, at least here in CA. I decided to wait until I need new tires to have my other bent wheel repaired at this shop.
I have NEVER had a broken wheel in my life before this car (30+years of driving), and it is unfortunate that BMW doesn't seem interested in dealing with the issue. I'll certainly keep this in mind for my next car (at least if I go with another BMW I'd make sure to get the wheel insurance)!
Please very one with this tire problem call and write to BMW nationally and locally so they will fess up to this mess.
I do not feel safe taking my car farther then 50 miles away from a BMW dealer because that is as far as a run flat will go and I don't want to get stuck in Tim Buck 2 while I wait another week plus for a replacement tire to be found.
I haven't experienced a bent wheel.
FWIW, the wheels for your 550i can be "downsized" to either 17" or 18" which will imbue the tires with an extra inch or half inch (depending on what you have versus what you might opt for as a replacement set) in sidewall height. The taller the sidewall, the lesser the chance of tire and/or wheel damage when abrupt surface imperfections are encountered.
For my part, there's absolutely no way I'd own a 5-Series with 19" wheels; they're almost guaranteed to suffer tire and wheel issues unless you drive on glass smooth roads all of the time.
Can I purchase new vehicle without rft?
- - You have a 2010 what?
- - Are you inquiring whether you can buy any new car with GFTs? Yes. Many companies sell their cars with GFTs.
- - Are you wondering if you can buy a new BMW with GFTs? Yes, and no. As far as I know, all standard model BMWs are now equipped with RFTs while all M-Series BMWs are equipped with GFTs.
The thing is, if you don't want a 535xi with RFTs, simply buy the car and change the tires to GFTs; problem solved.
Has there been precedent with dealer swapping the tires as part of the original purchase?
Finally, are there any redeeming qualities to having rft? I read only horror stories
I've yet to hear of a single dealer policy allowing a pre-delivery swap of GFTs for the factory RFTs; no precident.
Redeeming qualities of RFTs? Being able to drive out of a bad neighborhood if you get a flat.
The kit ($79.00):
http://www.tirerack.com/accessories/detail.jsp?ID=38
Cost of a new TPMS sensor: $53.
The cost difference between a set of RFTs and a set of GFTs: $500.
I'm thinking I'd much rather pay for a few new TPMS sensors than a set of RFTs.
1) It is highly unlikely that any of your previous cars have ever had 20" wheels with such short sidewalls.
2) When you say "BMW does nothing but blame me..." are you referring to your dealer (a franchisee, and not BMW proper), or are you saying someone from Woodcliff Lake, NJ?
3) There is no design or manufacturing flaw, low profile tires such as you're running will, by definition, become easily damaged at the slightest provocation; regardless of tire brand, wheel manufacturer, or vehicle manufacturer.
4) Not only did you opt to "upgrade" the size of the wheels on your car when you bought it, you "upgraded" them two full sizes. The standard 18" wheel setup which comes on the GT has tires with over 4.8" of sidewall, and even the 19" setup of the standard sport package has a fairly reasonable 4.3"; which is typically enough to absorb pot-hole hits and such encountered in normal day to day driving. Instead of opting for either of the above, you went for a setup which only offers 3.8" of sidewall give.
5) All of BMWs web sites and Sales and Marketing literature include disclaimers regarding tire and wheel damage caused by opting for large diameter wheels and low profile tires.
So, BMW clearly states tire and wheel damage can result from running the low profile setup you have, and you still bought it anyway; how is it BMWs responsibility? Some folks feel they need that much bling, but for my part, I have no intention of ever owning a car with wheels with less than 4" of rubber protecting them from the road (and 4.3" would be even better).
Suggestion; have your dealership put a 19" wheel and tires setup from the standard 550i GT Sport Package on your car. Not only should both the ride and handling of your car improve (not that you need the handling this car is capable of on regular roads), but your wheels and tires will be far more capable of absorbing the impacts from the things you seem to be driving over without sustaining damage.
FWIW, I see that the two different wheel/tire options of the 2012 Audi A6 have 4.8" and 4.3" of sidewall height between the rim and the road (sound familiar?).
Let's face it... For some, it will always be the manufacturer's fault. And, to an extent, I can accept that reasoning. Even if I find a disclaimer that "legally" exonerates the carmaker (as BMW includes in it's manual), does that really go far enough in informing the potential buyer about probable damage to oversize wheels?
Still, in the end, no one is forcing the buyer to take the vehicle... So it's up to the buyer to understand what he is purchasing. Couple that with the fact that only a small percentage of owners ever actually read the owner's manual ( most can be read "on-line" before the purchase has been made) and you get an overall "uninformed" car owner. In fact, most car buyers probably spend more time researching the purchase of a $800 wide-screen TV than the car they buy...
If I had to guess, I would bet the implications of larger wheels/smaller tire sidewalls NEVER crossed his mind. He probably just liked the way the vehicle looked.
Case in point, the 18" wheels which come standard on the previously discussed 550i GT are wrapped with tires endowed with over 4.8" of sidewall height; enough "give" so that one could drive those tires through some of the worst Manhattan has to offer and still not incur any damage.
The next step up is the 550i Sport Package which comes with 19" wheels and tires with a minimal (but still ample) 4.3" of sidewall height. While this setup will be somewhat more susceptible to damage compared to the 18" setup, they'll still survive most of what the big bad world of roads out there can throw at you.
In the Sublime to the Ridiculous department, those whom opt for the 20" Max-Bling setup which sports tires with a paltry 3.8" of sidewall height, had better be sure that the roads they drive on were just black-topped yesterday, because if the roads aren’t nearly glass smooth, they're going to be finding themselves buying new wheels and tires to replace the ones which were damaged when they ran over something as minor as a tar-strip. :P
Everyone: Offered the 5 year BMW Tire Protection package for $1267, my initial reaction is thanks, but no (self insure). Your thoughts? Have a couple of days to think about it, new to run flats and have read here and there that the wheels seem to be (relatively) easily damaged. I'm a bit less worried about the tires as the wheels.
Any and all input appreciated!
Laurasdada
The 245/45 R18s offer roughly 4.34" of sidewall height which should be more than enough to deal with all but the nastiest of road obstructions. Personally I'd pass on the Protection Package.
Spoke to my local shop, they suggested the warranty as they claim to see a lot of BMW, Audi and Saab wheel issues. I've never bought any kind of extended warranty, always self-insured, but this is a bit of a new ball game, shop said price sounded good for five years. We'll see, I think the lovely wife would feel warmer and fuzzier with the warranty.
Hey, we continue to support the economy, two new cars in three months! What have I done??? :confuse:
The price of the tire alone was $310.00 on Tirerack.com. I got the insurance discounted to about $1000.00 when I bought the car. I would have broken even if the wheel had also been damaged.
I guess I would ask..."do you feel lucky?"
Even though one may have driven 50 years without a single incident, most/all of those years were probably on higher profile, non RFT tires.
Is like me blaming BMW for poor design if I happen to hit a speed bump too fast and damage the front fascia on my Z4 coupe.
Sidewalls on RFTs are much more rigid and less forgiving when driven through potholes. It's something folks need to consider when buying large rims with low profile tires.
Was your contract for 5 years?
Went back to BMW this past year when we bought a 2011 535xi. Again, stayed with 18 inch wheels and the 45 series tires. This car has a SERIOUS problem! One pothole on I 40 in New Mexico bent the rim. The car immediately began vibrating badly. We were worried that we were going to be stranded hundreds of miles from any dealer. No damage we could see at night with a flashlight, so we limped 250 miles home.
The pothole is one that would barely have bothered any of the cars we have driven.
There was NO driver error here. I have driven over 1.5 million miles on three continents and never had a car suffer anything like this kind of damage from this sort of impact.
$650 and the dealer said that I was lucky that the impact did not take out the tire as well. They usually see tire sidewall bubbles when someone takes out a BMW rim.
When we bought the car, we had planned to replace the run flats with non-run flat Conti Extreme Contact DWS tires (and the Conti inflation kit) this coming fall. Now, we are debating whether we dare keep this car. It spends much of its time on trips in the middle of nowhere.
I know that replacing the RFTs with standard all-seasons will provide more cushioning for the wheel. With earlier BMW's this extra cushioning might be sufficient to have saved the rim in our pothole impact. But, I am far less confident that it will be sufficient on our car. The new 5 series seems to have a particularly soft front suspension. After hearing other reports of 2011 535's crashing over potholes, I took a new, non AWD, 535i out on a test drive this past week and deliberately drove it over a known pothole on a nearby surface street. The Bimmer completely bottomed its suspension with a loud jarring crash. In five other cars -- all with 45 profile tires -- I drove over the same pothole at the same speed with very little fuss.
Stiff run flat tires, soft wheels, a suspension that crashes . . . Not sure how to fix all of these. We are now worried that even if we replace the RFTs with more flexible non-RFTs, this car may still be dangerously susceptible to impact damage.
One possibility would be to replace the RFT's, buy the Conti kit AND devote a sizable amount of trunk real-estate to a spare tire and jack.
Or, we could take the more drastic step of dumping a beautiful new 535xi for an Audi A6.
However, there are many 5-series owners that don't suffer tire and wheel issues. All I was stating is that folks who go through wheel and tire after wheel and tire probably are contributing to their problem, even if it's just because the roads where they live are in a sad state of disrepair.
And, as the wheel size increases and the sidewall height decreases, it creates the "perfect storm" for wheel and tire damage. That's not just a guess, because I have a good friend that's in the wheel repair business (for quite a few years now) and he's been pretty clear that frequency of damage increases as wheel diameter increases.
Add to the, in BMW's case, stiff RFT sidewalls nd you decrease the margin of "give" even further.
Personally, if I could, I would change BMW policy to offer GFT's and a space-saver spare in the truck option.
Go get an Audi and enjoy driving again.
Do a Google on "XXX alloy wheel damage", where XXX is BMW, Audi, Nissan, etc. and you will find every manufacturer shows up with wheel damage.
I'm not here to defend BMW nor accuse any other manufacturer of defects, nor praise them. I'm just saying that the incidence of damage is directly correlated to the diameter of the wheel as it increases in size.
If you want the bling of 18, 19 or larger wheel sizes, get ready to pay extra.
But, I am comparing apples to apples here: a 2011 BMW 535xi with the standard 18" wheels and 45 profile tires against other cars with tires of similar size and profile.
I have driven over 500,000 miles in cars with 17" and 18" 45 profile tires over all kinds of roads on three continents. And, as noted in my post, I have now tested a sampling of such cars over the same pothole at the same speed.
ONLY the 2011 535xi exhibited this problem. I believe that is a combination of the very stiff RFT tires and a suspension design that is not suitable for our potholed American roads. You would probably never encounter this problem in Germany. But our roads are much worse than theirs.
This would not stop me from driving this car in an urban area, but we no longer trust where it could leave us stranded a long way from civilization.
I would love to hear from anyone who has a 2011 5 series and who has replaced the RFTs with conventional tires. Does this solve the problem? Does the suspension still crash? Have you had any tire or wheel damage since making the change?
BMW has replaced all the tires at no cost. This issue, along with the slow tip in at throttle and I am hugely disappointed in the car. Working to return it to BMW this week.
How did you get BMW to pay attention to you? They told me that I had to go through my dealer. So, I got the sympathetic service manager at the dealer to contact BMW on my behalf.
Through the service manager intermediary, BMW has just blown me off. Told me that they are are not aware of any problem with F10 tires, wheels or suspension.
Just for good measure, they informed me that replacing the RFTs with conventional all season tires would void my warrantee on anything relating to wheels, suspension or steering.
Consumer Reports complained about the (non sport) 535i they tested crashing over sharp bumps so hard that it sent shudders through the entire car.
Car and Driver had six bent rims and two blown tires in 40,000 miles on their 550. They blamed wheels that were too soft. I think that it has more to do with the suspension design combined with the very stiff RFT tires. Probably fine for German roads, but not for the U.S.
