As for the back window - cleaning it is the worst chore... I put up a couple of the cloth (w/suction cup) shades and it does a pretty good job of cutting the heat. Now that fall/winter is approaching fast here (NW) I won't have to worry much about too much sun.
And does it cut outward visibility?
Mike
Are there any out there??
5100 miles and loving it in dk cherry (snotpurple)
"The way you can tell if its the "real" GXP tire set is to look for the TPC code on the tire sidewall, meaning it was devloped by GM. Any Bridgestone dealer will have the tires and I would strongly recommend replacing with the same tire, to take advantage of all the engineering work done."
What are List Price and typical \ actual selling price for those tires?
- Ray
Knowing they'll not be cheap . . .
Pontiac requested this from Bridgestone and Bridgestone's first reply was it was impossible then another tire company came up with it. So Bridgestone changed there tune and somehow came up with a redesign that worked. So YES our tires ARE different.
Also for those of you that live near Snowy weather like myself (Chicago), i would swap them for Bridgestone Blizzaks in the winter.
DUKE
"They were engineered specifically for the GXP application and had inclement weather performance as a high priority in their development.
I drove a GXP last winter in southeastern Michigan for a couple of weeks (in snow) and found the car worked fine in those conditions.
If I had to do it all over again, I'd make sure the tire had an all-season rating to clear up all this confusion."
"I can't be of assistance on the speaker hum. I'm afraid the dealer or service bulletins are your best source of information on this problem."
--Robert
f.y.i.
- Ray
With more than a few "different" impressions (sigh)
Small point, I suppose, but I checked this very carefully after reading your comment here.
My GXP (2005) has no seam anywhere that I can feel on this control - or any other steering column mounted stalk.
- Ray
Acknowledging that THIS won't change anyone's mind . .
For the driveway question, you have 2 choices, 1st leave it in Drive, you have traction control or put in in Manual and use 2 (2nd gear) in those low speed climbs, it'll help keep the wheels from spinning. My initial thought is that 323lb ft of torque is going to be tough to control by just letting your foot off of the brake, they'll probably spin as soon as you release the brake pedal, but thats where the traction control will come in to play. Good luck, regardless its going to be easier than a rear wheel drive car to maneuver in the snow (at low speeds that is)
rlsedition, "Karl's Daily Log Book" #2171, 14 Oct 2005 7:50 am
The one prior to that was a GP GTP w/3.5” S/C drive pulley. (Likely crank TQ = approx. 300.)
I utilize WOT virtually every time I drive my GXP, often in first gear, and though I can certainly detect a bit of torque steer, it has never felt anything like a loss of control – or even imminent \ impending loss of control.
I almost never launch at WOT. Largely because I’d prefer that my tires last for a while longer. The full throttle first gear rumble & rush from 5 MPH to 40 or even 50+ occasionally is enough entertainment for me. At least with the current price of Fuel. . .
Now if one or both sides of the launch surface had a significantly reduced traction situation (sand \ moisture \ etc.), and someone hit WOT immediately, I can certainly see where veering could occur. At least until the Traction Control activated.
Regardless of FWD, RWD or AWD, at this HP \ TQ level, there are limits . . .
- Ray
Who can only imagine the ‘warnings’ that would mean GM would need to issue with purchase of a new 500+ HP \ 470 TQ Corvette Z06 . . .
--Robert
--Robert
If they are different, how are we suppose to tell the difference? I recall seeing a TPC number at one time, but it was different than what is on the side of my tires. I cant remember what is on the side, but I do remember seeing the RE050 on them. Do we have to buy them from GM (Ouch!! I can already feel that one!!), or is Bridgestone able to replace them for us?
Way too much confusion over a little round black thing!!
Mike
That appears to be correct Robert. There is a line in front of the 269 or 270 which almost appears to be a number 1, but I don't think that is the case. The other number on the tires which appears to be a Bridgestone reference would be "050AFZ", which is probably what distinguishes them from a regular RE050.
I'll just keep my fingers crossed I don't have to find out anytime soon first hand.
Mike
Makes me feel good knowing that I shouldn't have to replace these as i only have 1800 miles on mine since JUNE..It sure is nice to have a take home car from work.
furthermore he said if you were to buy the "regular" RE050A they wouldn't last you 15K, and would be horrible in the snow, different compounds and what not in the OEM tire make-up I guess?? These tires should last 30K according to his estimate, he had some knowledge about the tire but didn't know d idly about the GXP, he said this is common for Auto Manufacturers to put out specs for a tire and then the Tire Manufacturer produces one to their (Auto Manufacturer) Spec but for some unknown reason leave the tire as the same name (as in our case). If you ask me it's because they can then stop the limited production of the "special OEM tire" after a year or so and fool you and I into believing their regular production version is equal..
Conspiracy you say?? You do the math!!
Mike
That said, I wonder if any other tire manufacturers will come up with a replacement alternative which will have either a better traction rating, or more miles, etc?
Looks like these will be expensive tires no matter what, they wont be manufacturing that many of them. Just hope they are easy to come by when you need one, since you have no spare.
Mike
And how do we find out what this mysterious 'list number' is?
- Ray
With 5,00+ miles and no significant tire wear, but planning ahead . .
On to a different subject, I'm not impressed with the changes to the 2006, just went back to the dlr with mine and looked at them side by side..
A) Badges on fender look like an exposed bolt from more than 10ft away
C) The new wipers are definitely to address a "chatter" type problem, I once owned a Shelby Lancer (by Dodge) and it had those wipers on it with the fins, I replaced them and payed dearly, flapping all over at highway speed
D) Interior... don't like it at all, they took away the cruise control stalk.. look in from the passenger side and you'll notice the cheapness right away. Something as small as that can have a big effect on an otherwise attractive interior by adding a bit of "HIGH TECH feel", back to the 1970's all in one, too bad they couldn't put the wiper switch into that also??
E) And I'm not sure why but again I have seen the same center caps on the 06 as mine, but on the pontiac site they're the same finish as the wheel on the 06???
Tony,
I guess I never saw an '05, so I am not sure what you are talking about when you refer to the cruise stalk. I know mine is still on the left side of the steering wheel with the headlight, foglight and dimmer switch and directional signal. Were they in a different place on the 05's??
Seems like a traditional layout that I have used before in another Pontiac I had, just cant remember which one it was now. Either a TransAm or a Grand Am. Memory escapes me now.
Do get that elusive list number for the tires. It would be good to have in the glovebox incase of need.
Mike
as for the air bag light, people with kids care about that. kids are not suppose to sit in a front seat with airbags, and there is a sensor that turns the airbag off if there is a small amount of weight in the seat. i dont know what the minimum weight is for it to stay turned on. i guess it could save you a few dollars in repairs during an accident, if no one was in the passenger seat, it wouldnt deploy.
Mike
Exactly!
- Ray
Even more happy to have a 2005 w/the cruise control on a seperate stalk . .
