Clay
Didn't have a chance to try it off-road but I can see it getting 11mpg or less during some serious off-roading.
I'm in the SF Bay Area and am shocked at how much gas I am guzzling.
You need to immediately check the other wheels. If you can't remove them with the lug nut wrench that came with the truck, they're probably overtorqued. Overtorquing can also warp the brake rotors. Scary stuff -- thank heaven you stopped safety! :surprise:
It goes off within 5 minutes of me locking the truck w/ the key fob. It will go off every 5-7 minutes, or maybe every 10 minutes. In recent weeks it will go off within 2 minutes of locking the truck. It is definitely getting worse.
I no longer lock the truck, because I don't want to upset my neighbors with the constant alarms.
I took the truck to mechanic who didn't know how to lower the sensitivity. I asked him is he could simply disable the alarm, but he wasn't sure about that either.
Is there a way to just disable the alarm function without affecting anything else? I would just as soon be able to lock the car without the alarm feature. Or, how does one go about decreasing the sensitivity of the car alarm?
Thanks in advance!
I go so frustrated with mine, instead of tinkering with the dial settings, I disconnected the battery and pulled the siren out and clipped the wires. Now it sometimes doesn't want to crank if I don't hit "unlock" on the key fob or press the "secret" override button that mine has, so I really can't recommend this method. But it did shut it up!
Good luck - durn alarms can really drive you boinkers.
Ugghh.
I know that it'd make only $3-4 difference per fuel up but it all adds up.
I was so welcome to see your clutch problem, and as many others stated, it can't be my driving habilts as you have driven mannual your whole life. Me too. I find my 2005 Frontier clutch is bad at 47,000 miles. The dealer says it is not covered unless they open it up (with my authorization for $400 if not covered) and it is a spring.For a truck that is supposed to be rated for a towing capacity of 5000 punds plus what a buch a nonesense. My dealer has reffered me to nissan. I was wondering how you made out with your situation.
Thank you, judy
i have an 08 6 speed and I can verify that the parking brake is an old fashioned handle between the seats (thank god!).
Can somebody tell me where 2009 XTerra is ? I don't see it at Nissan dealerships here in Houston. Isn't it due ? It was supposed to be released for sale back in October 2008 as far as I know !? Wanted to take a look at the new 2009 model and drive it, but where the hell is it ???
thanks!
They must be rare though - I only see one 2009 model within 200 miles of Boise right now.
I don't see anyone posting about buying an '09 over in the Nissan Xterra Prices Paid & Buying Experiences discussion.
Any Nissan salespeople here with the scoop? Did we miss an announcement about the release date?
I am hoping you had a positive outcome. It would be great to know so I could use your experience to help me.
When I went to see the '09 at my dealer, the salesguy was first and foremost interested in where I worked and how long I'd worked there. I thought it odd and only afterward did it occur to me that he was checking my potential creditworthyness before spending time with me! Sheeesh.
My wife is interested in a 6-Speed 4x2 in S Trim. The downside of Xterra is that it's a bit wide for our garage, it's fuel economy isn't all that attractive and it's priced at a level that is more than we wish to pay. If March '09 brings better incentives, we might take a 2nd look.
COWBOY
I got Off Road edition - it comes with nice set of shocks. Probably not quite as good as bilsteins but they'll do for now
Xterra S model with manual transmission no longer available
Technology Package content standard on SE and OR models
Revised X Gear Package content, now standard on S and SE models
Simplified exterior color selection (six available colors)
1 good off road
2 happy with the bf goodwich tires rugged trail tires 265 65 17, yes iv'e tired other
3 tires but these work the best for me
4 ok on road 17 -18 on hwy 14 - 16 in city
5 i go off road alot and it brings me out the ditch each time.
6 i use full syn castrol and only change oil every 7 - 9 k miles.
7 i do a once a year complete service of change all belts, hoses, and fluids.
8 and at 200k i finally got to change the o2 sensors.
9 ive only changed the spark plugs once around 100k ago.
10 no paint fading, some chips here and there ; got to hate the road debris
11 on my 3rd set of front brake pads and rotors but still on the org back set!
12 no major problems with suv
13 after market tow system from nissan
14 tows what i need to tow here and there
15 all windows go up and down with ease
con's
1 driver seat fading color from seating in it so long.
2 the arm rest on front doors the paint shows wear and tear and hardly any body
3 rides shot gun.
4 the trim around the gauges, glove box, and radio are fading; and im a neat freak
5 when it comes the cleaniness.
6 the cd button on player is loose and i rarely touch it!
7 sunroof bolt that holds latch had to be adjusted
8 had to replace wiper hose and nozzle, some thing made it back up on the passenger side only
9 rust under the back end above the spare tire
10 rust on the transmission dip stick
and for those that complain about gas mileage, its an suv not a car not a hybird, so you pay for what you get
