Taurus/Sable Brake Questions
in Ford
Hi, I used autobarn dot com and ordered some Brembo brake rotors for my 2000 Taurus. I used regular, off-the-shelf brake pads and had a tiny, hole-in-the-wall garage install them for me. The Brembo brake rotors totally transformed the Taurus into a vehicle with exceptionally good overall braking performance with no brake fade.
I have also noticed that my 2000 Taurus can at times pick up speed quickly making the Brembo brake rotors upgrade mandatory.
Autobarn.com lists Brembo rotors from $47 (vented) to $80 (slotted). Are the $80 ones worth the extra $?
I've also come to find that the car has zero engine braking when in Drive (OD). You don't get any of that until you shift into "3", which is only good around town or on snowy roads when you're not traveling over about 45 MPH, anyway. Otherwise you lose a couple of miles-per-gallon.
I've also disconnected the torsion spring from the brake pedal and that's eased up on the pedal effort at SS's by maybe 25%. (The master cylinder has its own return spring that's more than adequate for returnng the brake pedal). Brake fade is still an issue though as it happens almost immediately any time you have to brake even moderately hard.
Brian
when i purchased it the former owner informed me that it needed a new break master cylinder.
we replaced it and there is still no breaks in the car.
Any ideas to what could be wrong with it?
Also, if you don't have one already, a brake bleeder works pretty well for that situation.
:confuse:
:confuse:
A while back I noticed that the brakes were a little "soft"....it had been about 2 years since last brake job, so I assumed that was the issue.
I replaced the pads and rotors.....still had the same feel.
I had my mechanic check it out.....he clamped the brake lines going to the calipers and said it held pressure....but when any one was unclamped, the brakes went soft.
Note...NO leaking fluid.
Mechanic said that ruled out the master cylinder, and told me I needed all new calipers.
I replaced all of the calipers....NO CHANGE.
When the vehicle is not running, the pedal stays firm....once the vehicle starts, the pedal will depress easy....and stop the car. If I continue to press the pedal, it will continue to depress, and eventually stop near the floor....
The brakes have been properly bled until no air-bubbles.....note the fluid is a bit darker, a light brown in color.....
Any advice or tips would be greatly appreciated....trying to do this myself, but I may be in too deep.
