Mazda5 Climate Control
I just got the car last week and with this heat wave the a/c has been a real disapointment. My question is, has someone that had no tint on the windows, installed it and was there a big improvement. (A lot of the comments I have read say that tint should help...has it?)
zoom 500 :confuse:
zoom 500 :confuse:
The noisey suspension and dash buzzing noise all have appeared as problem with the M3. Same car, same problems different body, maybe?
It hasn't gotten hot enough here in DC to test out the A/C. But I didn't have any problems with the A/C on my 3.
As for the noisy suspension and dash buzzying on the 3 and the 5. I have owned both the 3 and the 5 and I haven't had any of those issues.
I currently have the 5. I traded in my 2004 3 for the 5 last November. I drove it for almost 2 years and 28K miles and didn't have any problems with it.
We traded the 3 in for the 5, because we were expecting baby#2 and the 3 was too small for two kids.
I certainly hope the A/C is adequate now.
Try it again in July and August.
What was your first language?
Never had a problem through the rest of the summer.
Maybe your A/C is blowing too cold? A Mazda lol
Anyone know what this noise is? Has it happened to anyone else during high humidity? I'm planning on asking the service guys about it during my next oil change, but with my luck they won't be able to replicate it.
Just have a question for you all: How accurate do you think your Ambient Temperature Gauge is on your Mazda 5? Do you think it accruately tells you what the temperature is outside?
I ask this because when I first got the car, I noticed that the gauge was ALWAYS spot on! (I would see the temp displayed and then I would hear the weather on the radio and it was always the same figure or very close to it) Nowadays, though, I noticed that it displays a higher temperature than what it actually feels like outside and higher than what is said by the radio weather forecasts. I chalk it up to it being summer and very hot and the varying degrees of temperature throughout the NYC area, but I still wonder if the gauge has lost its accuracy. Please advise. Thanks!
It's all that concrete and asphalt -- move to the country where the temperature is always just right.
Took it to the dealer today and they could find nothing wrong.
Did you open all the windows and exhaust all the pre-existing superhot air out before you tried to cool the vehicle with the A/C?
Did you have the A/C on maximum cooling and maximum fan speed and did you have it set in the recirculation mode? All car A/Cs cool the cabins much faster if you use the recirc setting (usually done for you when you choose a "Max AC" setting.
How long did you run the A/C? If you did short trips, you may not have had enough time to cool down the interior before parking again.
That said I have Tinted windows, more of an asthetic thing. I think most cars look better once you tint them. I do keep the moonroof cover drawn in this heat.
If you park outside all the time, use a sun shade on the front windshield (I got one at Costco that fits fine) when parked. Your ac system is blowing cold air, but if the dash duct works/vents it's traveling through to get to the cabin is hot, then air is going to warm up before it gets to you. It's one of those laws of thermodynamics...
You can also close the two side vents so you'll get more air out the two center vents. And angle those two center vents slightly up. Hot air rises, so if the vent is angled up, it'll cool the hot air in the car faster.
But I agree with everyone else, you're better off tinting the windows.
Thanks again all!! First tank was 25.3 mpg much better than the 16 I was getting in the ford I was driving before, more zoom too...
Has anyone else experienced this?
So far no luck with the dealership on this problem, by the way.
The measurements I've done are when it is in the 70's out. It is most noticeable then, as AC really shouldn't be necessary, and all you want is some fresh air.
Many here have complained about the A/C's performance, but I've never really had a problem with it. I remember in my 06, we used to have to turn it down a lot of times since it just got too cold. I agree that in the middle of summer and when it's really hot the A/C is not the strongest of cars I've experienced, and it could be cooler, but it isn't BAD. I do believed the rear vents on the 08's also helped out. But, I definitely recommend getting tints. Not only do they help, but they make the 5 look even better!
Go to Home Depot and buy/install a manual water flow shut-off valve and use the valve to block water flow throughout the cooling season. My system also has an electrical switch to disable the A/C compressor throughout the winter months.
Not using the A/C to cool the water jacket nor for ONLY dehumidifcation in the wintertime results in a FE gain that is not insignificant.
Larry
