Toyota Camry Timing Belt/Chain Questions
I have 98 Camary and do not know if I need to change the timming belt(s) and water pump, since I bought the car from a dealer. The car has 92000 miles on it.
The dealer is asking for USD 230 to change the timming belt. Is it ok. How do i know i need a new timing belt. I am meeting dealer tommorow for the service.
See Also: Timing Belts and Timing Chains
You could check condition of your timing belt by opening plastic cover for inspection.
Make sure that you check their works after installing new belts. It happened to me that the belt for water pump was so tight caused water pump bearing failure after 4 months later. After they changed water pump, then the air conditioning bearing making noise ...
I bought this 96 Camry LE from a Toyota Dealer. It had 56K mileage at that time and the sales person said the timing belt is changed (which I do not believe). Now, it has reached 60K. Should I replace the timing belt now ? Someone told me that timing belt for 96 Camry need not be replaced at 60K. It should be done when it reaches 90K. Please advise.
Nikunja
Does it have a Timing Chain or Belt?
you also have to change your water pump?
at my toyota for a camry 2001 says timing belt change at 90k. Dealerships love to say 60k I wonder why hehe.
Ask Toyota
says I have a chain. Anybody know for sure?????????? Also, the salesman at a local dealer said that the car has no spark plugs, but instead has some kind of 'coils'. Is that a load of crap? It is a PZEV, BTW.
xpfshost
Ken
How is the voltage transmitted to the coil?
It's called direct ignition. Integrated with the coil is transistor for switching high voltage to spark plug. Probably, there are at least 4 wires to the coil: 12v, Ground, switching signal, signal return.
Not only that, the ECU can adjust timing (advance or retard) or anti-knocking, maximum fuel economy.
When I inspected the belt, it was amazingly clean. There were no cracks, or drying. I bet it could have gone another 50K miles before it needed replacing.
While changing the belt, the mechanic at the dealership damaged the oil pan while lifting the car. That made me very ticked off. They charge $80/hour labor rate, and don't care to check where the hoist saddle is placed before lifting. I made three visits for one repair. It cost $150 to replace the belt
In 9 years of owning the car, this was the first time ( beside tire and alignmnet guys) a mechanic every touched the car.
Joe
Timing belts don't show any visible signs of deterioration normally, so you can't base replacement need on appearance.
I hope that dealership replaced your oil pan for free! They had to be pretty far off with the hoist to snag the oil pan. I'd go elsewhere in the future.
Does anyone know when the scheduled timing belt change is for this vehicle? If it helps its a timing chain.
I have to push hard on gas to pick up its a V4, doest throttle cleaning takes care or improve pick up?
I am nearing 60K what are the major maintainance i have to do?
You should have them itemize what they plan to do for that outrageous sum. Or go elsewhere. The last time I was at my local dealer, they had a sign posted listing service prices, and I think the timing belt change was around $300.
When I had it done on my former '97 Camry 4-cylinder a few years ago at 93K miles, I had the timing belt itself changed, as well as the tensioner spring, crankshaft oil seal, and both drive belts. But I had a co-worker (a former Toyota dealership tech) do it for me. We agreed on $100 for labor, and the parts total was about $60.
I think on the V6, it would be advisable to replace the same items, unless of course you've already replaced the drive belts recently. Now the dealer will probably want to replace your water pump, because it's "right there" once the other items are off. Certainly if there are signs of leakage, it should be replaced, but if not, the choice is up to you. I gambled that it wouldn't need replacement, and I ended up selling the car at 111K miles.
Toyota Owner
I would like to know if you were able to resolve your problem with setting timing. I have 93 Camry and I am having exactly the same problem setting the timing after installing water pump and timing belt. The car starts and idles fine but has absolutely no power at all. Been through it twice now and haven't had any luck. any help would be appreciated.
There have previous instances when the same dealership in Northern VA recommended service work that was questionable.
Questions:
1. How cam I check for the valve cover leak if there is no visible oil leakage under the car?
2. When is the timing belt supposed to be replaced? I understand that replacing the water pump makes sense concurrent with the belt replacement.
3. What is a reasonable price for all this work? I have a feeling I am being over charged.
Toyota recommends changing the timing belt at 60k miles for vehicles normally driven under "severe" category usage, i.e., taxi cab, police, constant stop'n'go driving, etc. People differ about the need to change the belt under normal driving conditions. It's true that a broken belt will be an unpleasant and expensive experience.
The prices quoted are well above what a quality independent garage would charge.
sambo49's model year 2000 Toyota Camry is about 14 years old? No matter... sambo49, be aware that some engine designs exhibit "interference" between pistons and open valves in the event of a timing belt failure while running. Moving pistons striking a stationary open valve extending down into the combustion chamber in the event the timing belt breaks will result in a bent or broken valve and possibly a broken piston. In an extreme case, connecting rods have been known to fracture, too, and result in busting a hole through the lower side of the engine block casting. (When that happens, it's replacement engine time - which might well wipe out most or all your car's current market value.) I don't know whether your Camry's engine is an interference design, but if there are four "dimples" cast into the piston crowns, it would be considered such. You'd probably need to call a Toyota dealership's service department for confirmation on this point. At 80,000+ miles on the original timing belt, consider replacing it an investment in continued, reliable service from your car - you're already 33% into borrowed time. The cam cover gasket oil seepage is probably a minor issue that the dealership's service department is attempting to scare you into unnecessary makework. Unless you observe actual oil loss on the dipstick from the "Full" mark to the "Add Oil" mark or lower over the course of your usual oil change interval, f'gedaboudut.
Hmm, somehow I thought it was a '93. Must have been thinking about another car. Sorry.
The 2000 Camry V6 has a non-interference engine, so your horror story doesn't apply. As I said, people will differ over the need to replace the belt. Toyota dealers, of course, are one mind on the subject. Somewhere around the year 2000 Toyota changed the recommended mileage for a belt change to 90K when driving under severe conditions.
Not a problem, I believe the message right before mine was a 93 camry. Thank you very much for your reply. I will replace the timing belt at the next service since I intend to pass this car to one of my kids in college and he will need reliable wheels...
I will replace the timing belt at the next service and hold off on the valve cover while keeping an eye on the oil level.
I checked the engine again today and could not find any visible signs of oil leaks, just dust and grime acculmulated over the years and 80+ k miles.
Many Thanks!
So, you really ought to have it replaced now. I assume you wouldn't like to be stranded somewhere if the belt breaks, because the car instantly becomes undrivable.
I'd look around for a good locally owned independent shop that can handle the job. Ask friends, relatives, and co-workers for recommendations. You don't have to go to the dealer, who will charge the proverbial arm and leg.
I also wouldn't trust the chain places (tires stores and discount stores).
If you have a 4-cylinder, there is no timing belt to change as of the 2002 model year, just timing CHAIN that should last the life of the car. If you have a V6, there is a belt, but the replacement interval is 90K miles.
$180 is a good price, though!
Run, don't walk away from that dealership!
Does a 2007 V6 Camry have a timing chain or a timing belt? ---- If it has a timing belt, when does it have to be replaced? -------- Best regards. ----- Dwayne
I would think probably around 100,000 miles......let me know what you find out.
