Toyota Camry Transmission Questions (MY Prior to 2007)
in Toyota
I have a 2003 Solara SLEv6.
Some may say I am a bit cuckoo about maintenance.
At 15k I dropped the transmission pan drained the transaxle, cleaned the pan and filter, and replaced the gasket and fluid.
At 30k I simply drained the transmission pan and transaxle and replaced the fluid. I have repeated this process TWO more times since 30k, and I'm now at 44k.
Each time I do this, at first I view the fluid as it drains as having SOME red coloring to it. But when I then transfer the fluid from the pan to a container (to dispose of it) it looks QUITE BROWN!
I can't imagine that there's much residue in my pan that this is coming from, as the pan has not been used that much.
My question is....Do you think I'm over-doing it?
I HATE to see such a brown color in my fluid, so I am obsessed with changing it. If I had a more convenient place to do this, I would probably do it every 3k miles!
Each time I drain/fill it's only 4 quarts, which costs me all of $8 at WAL-MART.
I use CASTROL DEXTRON III.
ALSO...FYI...be VERY CAREFUL as to which fluid you use. I had a BIG disagreement with the Toyota Parts Manager regarding this. He was certain that it was okay for me to put in Toyota Type IV fluid but before doing so I found a Lexus/Toyota TSB that warned NOT TO.
That's great for you that you can look over the mechanic's shoulder. I wouldn't mind doing the same. However, if I were the mechanic, I wouldn't like it.
Checking with a torque wrench is a good idea. I never used one in the past except for specialized jobs like replacing seat belts or spark plugs, but we've got one at work now, so I do check my lugs now. I found that I was overtightening them.
H-rated tires are perfectly adequate - they're good for 118 mph, and I'm almost certain the original Solara tires were not rated higher than H.
I think you are overdoing it on the tranny fluid changes; a drain and refill every 30K miles should be enough, even if you can only get about half of it out.
Where is the fuel filter located and where did you obtain the flare nut wrench? Also, I don't think the fuel filter needs to be changed anywhere near as frequently as you're doing it.
The maintenance manual, IIRC, doesn't even mention changing the fuel filter at all under normal operating conditions. But on my lawn tractor, I'm supposed to do it every year...go figure.
With the tranny fluid, I just HATE draining it out and seeing it on the brown side, so I will continue to do it perhaps every 10k.
On my car the fuel filter is cylindrical in shape, perhaps about 6" long, 4" wide. It is located in front of the area where the battery is. I believe I had to take the battery out to access this area. This special wrench can be bought at SEARS. I would recommend buying a complete set of about 6 or 10. I'm not a mechanic, so I cannot tell you the real specifics, but I CAN tell you that certain nuts call for this type of wrench. You can cheat and use a plier, vice-grip, or other, but you risk damaging the nut AND not getting the job done right. These tools don't cost much more than the other box-end wrenches and will be required for several other tasks on an automobile.
You've GOT TO have the RIGHT TOOLs.
You're probably right about the manul not saying anything about changing the fuel filter. But I don't believe the manual says anything about changing the tranny fluid either. But that issue is sometimes controversial. I've actually heard some people say NEVER to change the tranny fluid. NEVER. Can you imagine? I can't.
But as I said, I believe heavily in preventive maintenance and I enjoy tinkering. So for the $$$ it's going to cost to buy the parts it's still worth it to me because I have fun at the same time AND I learn something more about my car(s).
Isn't there a saying that goes "An ounce of prevention is worth a pound of cure"?
You are absolutely right about having the right tools for the job; I've learned this in working on my cars, bicycles, and lawn mowers. Quicker, easier, and safer.
I made a mistake in my earlier post. H rated tires are good for 130 mph, IIRC. T rated tires are rated for 118 mph, and S rated for 112 mph.
You certainly don't need V rated tires on a Camry or Solara.
if you are serious about the transmission, I suggest you to have it "power flush" (which will suck out most of the fluid compare to just draining it from the pan which only drain about 1/3 of the actual fluid).
That's the reason your PINK fluid get BROWN because you are mixing that new 1/3 to the rest.
My Camry has 110K miles and I only have the tranny flushed twice (1 drain ($70, replace gasket & filter), 1 power flush ($130) I can tell you the different.
If you want a PINK looking fluid, Power Flush it. By the way, you don't have to do it every 15K or 30K. You know how you drive your car, I think 48K is about right
The reason it's brown because when draining, you only drain out 1/3 of the fluid, so you are basiclly mixing the new PINK fluid into the BROWN fluid so it doesn't really matter how many miles you put on it will still be BROWN.
I don't know how much time and money it costs to do a tranny drain. But next time, you might want to have it power flush by a toyota dealer. You will be surprised to see the different if you really want to get the PINK looking fluid back in your tranny. And you usually don't need to do it that often,. I think you can have it done every 36-48K miles.
Same for the fuel filter. I was thinking about replacing mind too but after talking to 3 different dealers (2 I trusted told me it's not necessary since the filter supposed to last for the life time of the car unless the fuel I used has problem) I did some research from the Internet and made me believe it's not necessary.
What I do instead is to use FUEL SYSTEM CLEANER about every 2000-3000 miles
I use TECHRON in my tank about every 12k. I understand it is THE BEST in it's class. Be careful not to buy a sister product that you'll see on the shelf that is packaged VERY similar in style/color, in fact made by the same manufacturer, but it only CONTAINS Techron, as opposed to the bottle I buy which IS Techron.
I'm going to try to attach hoses to the transmission fluid tubes that run into the radiator part where it gets cooled. I'm going to put one into a pail on the ground, the other into a bucket that will contain about 15 quarts of fluid. I will then run the engine until it flows all the way thru. The only residual should be what's left in the radiator/cooler.
What do you folks think about that idea?
You'd be running the transmission for a short time with low or no fluid. I don't think that's a good idea.
Also, what if the bucket tips over?
Seems to me that you're just better off draining and refilling at more frequent intervals if you want cleaner fluid but don't want to spend the money on a flush.
Personally, I wouldn't get a flush either.
I think he did state that this would happen if you never had the trans changed in the past. If you flush it at real high milege for the first time it could damage it say 70,000 I would think.
I have a 01 Highlander and thinking about flushing the tranny too.
I have a 97 Camry LE (V6) with about 50K miles.
I’m going to flush the radiator and (maybe) change ATF before my summer trip.
Dealer changed ATF once before at ~30K. Wondering if I should change the ATF filter this time - or just the fluid - or - is it too soon to worry about the ATF period?
tia
srp
Appreciate the input!
srp
~Jfoy
Has anyone used dexron III fluid instead of the toyota trans fluid???? thanks
Trick is to find out which line from the tranny is out and which is in. The right one (as you face the engine) comes from lower on the tranny case and the left one from higher. Both enter the factory cooler at the same level. Anyone know which is which? Don't want to find out the hard way.
any other tips on adding a transmission cooler?
To my understanding, only high performance cars or trucks (do a lot of towing) will required a transmission cooler.
I had a 4 cyl turbo (Conquest) and it had a transmission cooler but I don't recall which way go first nor did it go to the radiator at all)
I understand is is not hard to do and can overall extend the life of the tranny.
Does the transmission need to be tuned up? DO the spark plugs need to be changed? I was at the dealership the other day and they suggested getting the timing belt/drive belts changed at 90K ($350). would replacing these belts remedy this issue?
Thanks in advance!
Henry
The timing belt has a 90K mile change interval, so you may want to just wait 6K more miles. At the same time, it's no more labor intensive to replace the drive belts. Changing these will have absolutely no effect on the jerkiness problem.
I failed to mention that i use 87 octane. I'm getting, on average, 27 mpg (that's city and interstate). I'll make sure the transmission fluid is topped off , although, i just had my oil changed and brake pads replaced at the dealership, so i would assume they've already filled any low fluids.
Finally, what's the average life span for a clutch?
Again, i've only noticed this "jerking" in 1st and 2nd gear, but i don't know what that means.
Thanks again in advance for any help/suggestions anybody throws my way.
Henry
Never assume the dealer has checked all the fluids, especially the manual transmission fluid, as typically you must remove a bolt and stick your finger inside to check the level.
There's no such thing as an average life span for a clutch. You can fry one with just a few all-out tire-spinning acceleration runs, or a clutch can last well over 200K miles, as mine did on a 1980 Volvo.
The 87 octane gas is not contributing to the jerkiness.
Always consult the owner's manual or maintenance manual for the proper fluids. Don't believe the dealer without checking. What's "regular" power steering fluid supposed to mean, anyway?
There is stuff sold called "power steering fluid" that is not ATF. It's essentially just very low viscosity mineral oil (10 weight or something). It's yellow like engine oil and not synthetic like ATF. Chrysler used to use it but not sure if they still do.
A small/big problem. My second hand 200 Toyota Camry 4cyl/auto was working fine till a few months ago, when I suddenly started feeling the unease with which my gear changes when I increase the speed. Its not smooth at all and I can feel a jerk when I increase the speed. Clearly something is wrong. Since its 60K + I took it for a 60K servicing and the Midas guy ( I think ripped me off ) with 470 bucks worth of servicing. I guess everything was needed except the spark plug wire change that cost me arnd 200 bucks. The Transmission flush was done too, which I thought will take care of the gear changing problem. But its still there.
Any idea what else could be wrong? I am gonna take the car to the Midas guy again, lets see what he says
> Toyota of Redlands dealer to get her camry's 110K Mile Service Maint
> Done, they did the Basic engine stuff Serp Belt etc.. and Drained
and
> Filled the Transmission $500 bucks, thats what was Listed on the work order.
> this was done a month ago, now there was a tapping shutter sound
> comming from the tranny, she experienced slippage after 40 mph, she
> brought the camry back to the dealer and they came back with an
> estimate of $3K. WTF???!!! there was no tranny problem reported
> durring the initial 110K mile service maint check. what went wrong
> here.....
OK, I checked last night and found 4 oil pan bolts were loose where a leak was discovered, I have pix(I just need to know how to show it),...and its down about a quart.......I tightened the loose bolts and I told my Sis to pickup a bottle of Genuine Toyota ATF-T IV oil and add it see what happens,...the Service Dept should have seen this leak a month ago if it existed then and listed it as an issue on the Work Order. Sabatoge????
> Please Advise Me
> CEDs01
PS My Sister said the Service Done is irrelevent to what had happened....I see a letter to BBB.
not moving for an automatic transmission? Or stay on "D". I always leave on "D"
while driving just for convenience. My first two cars were manual, so I had to
on "N" while stopped. Driving an auto for many years now, just thought about
why not switch to "N" when stop - may save on some gas (?). Does anyone
have experience on switching "D" and "N" for auto-trans cars? If you do switch
between "D" and "N", is there any harm to the auto-transmission?
Last time I did the transsmission oil change at Jiffy Lub in May 2004 and do nothing since then. (I did not even check it!). Can anybody let me know would it be a really leaking problem? Could it be a normal thing for an old car like my 97's camry?
Many thanks.
Can you see oil under your transmission pan? Did you see oil from your driveway?
The main reason for oil leak is usually from a bad gasket. Run your finger around the pan and see if find something.
The question is :
A) Has anyone experienced a similiar problem with 1998 (or close) Toyota or Camery Transmission?.
C) Is a rebuilt transmission the right way to go ?
D) How long do the Toyota Camery really last? 200,000 miles + ?
Any help would be greatly appreciated.
Arshad
If I had to guess, the change was probably made as of the 2002 model year, when the car was redesigned again and a 5-speed automatic replaced the 4-speed in V6 models. In 2005, the 4-cylinder models also got the 5-speed. (My 2004 Camry with the 4-cylinder, 4-speed auto required the new-type fluid.)
Have you ever had the transmission fluid replaced before? If not, and the repair shop just did a drain and refill, about half of the dirty old oil will still have been left in your tranny.
I'd go to another shop for a second opinion. A bum transmission doesn't necessarily make the engine noiser, unless the tranny isn't upshifting properly (that is you are running in third gear when it should be in fourth).
You may simply need to have the fluid drained and refilled a couple of times or flushed to get all of the old fluid out. (I'm not a big fan of flushing.)
There are no hard and fast guidelines for how long a car will last. A lot depends on how well it's cared for. However, the weakest link in today's cars' drivetrains appears to be the automatic transmission.
Discovered, here on the internet, that the transaxle holds five qts and the only way to drain that fifth qt is to remove the second drain plug in the differential case. The second time I dropped the sump pan and cleaned out about 1/8" of what looked like ground up pencil lead, non-magnetic, I assume wear from the clutches' frictional surface.
Another 10,000 miles and my ATF is still pink and no burnt odor.
