Toyota Avalon (Prior to 2005) Transmission Questions
                    I recently noticed on my 2002 avalon that at times it will hold 3rd gear and will not shift to 4th immediately even when I leave of the gas pedal. The car is warm and seams to do it when I accelerate hard up to speed and then ease off the pedal and it will stay in 3rd. Anybody experience this problem. It does this only ocassionally.
Having just received the repaired car back everything appeared to be corrected. There is no evidence of leaks in the steering power system and the reservoir is full, but when driving, on turns both left and right the usual ease becomes momentarily stiff. This is not the way the steering responded prior to the accident.
What should I look for and what could be the problem and correction?
The one possible exception that comes to mind is city traffic, stopped, on a 101 degree day. Rev the motor in neutral and the water pump will circulate the water a little faster. This helps cool the motor. But unless the "high temp" light is coming on, even this is unnecessary.
My guess is that you will do far more harm than good to the transmission pump by shifting in and out of gear. Instead, use good fluid, change as recommended and don't worry. Avalon is a quality car designed to last a long time. Enjoy it.
Taking it to dealer. Anyone out there with similar experience or know of any notices or re-calls on this model,I'd appeciate your input.
Has anyone had a tranny replaced, and if so, at what cost? Ditto PS pump and strut caps.
Do you think, as I do, that this is highly unusual for an Avalon?
Do you have any suggestions? Do you think it possible to get some "relief" from Toyota?
Fred
Transmission: Properly maintained, it goes 200k plus. No proper care, a lot less. They run at high temperature and make jello out of fluid every 35k miles. Stop in at local dealers and see if any records are available on the car. If it was serviced regularly you can beg Toyota, not a dealer, for help.
PS pump: No service required but anything after 100k is good fortune. They last longer on cars driven on open highways as opposed to intown traffic.
Struts: A known problem for many Avalon's.
HVAC: Another well discussed problem is the XLS auto-temp system. It fails to work properly far too often for this brand car. With luck you can figure out how to make it work. Some people are never satisfied, if you read all the posts.
Shop around for better prices at several dealers. I drove a '99 XL prior to buying an '03 XL. It was near perfect, driven mostly on the interstates. Never repaired, it had no problems. Hope this helps...good luck. Avalons are a great car.
Let enter in here and piggyback your thoughts a little. My Toyota Service manual does NOT give me a service interval for the AT, although my wife's Honda Civic 03 Service Manual does. Honda's interval changes are changing the AT, Dexron III in the Avalon, after the first 60K, and then 30K thereafter. As lazy as I am, I change it every 50K in conjunction with the oil, every 5K. This makes it easy. In addition to that, you probably know already that the PS fluid, is exactly the same in the Avalon, as the AT fluid. You guessed it, Dexron III. So why not, as I do, change out that fluid in the PS as well, when you do the AT (tranny fluid) since you already have the bottles out. It is very easy to do, and if done on a regular basis, would most likely prolong the life expetancy of the seals, and the PS rack itself.
I hope this helps. Your comments are welcome.
As an aside, we had violent winds here in the northeast, and wouldn't you know it, a shopping cart beelined right for my driver's door, dinging the door, ripping off and smashing the mirror and then digging in the L front fender. Nothing like a "hat trick" to make the season right.
abfisch
The ride has always been great - no evidence of struts or suspension issues with us ...yet. Consumer Reports magazine ratings are only "Fair" for the '98, so we've been lucky this far.
I agree with the posts here about the AutoClimateControl system. The pits. I found doing manual settings and changing as needed worked better.
As for the transmission, Consumer Reports readers' survey gives the Avalon trannys an "EXCELLENT" for every model year. I'm going to guess that perhaps this Avalon you purchased has been abused rather badly due to neglect.
We love our '98 Avalon, for such an underappreciated car we had to buy in a hurry after a tornado totaled my husband's Mazda 929 in April 1998. (he was not in the car and the golf clubs in the trunk survived-LOL) For years we have called it the Little Tornado Car. <grin>
It has proved itself to be a real gem and earned our respect, and we love the body style. We just gave it to our son 2 weeks ago when the tranny died on his '96 Ford Explorer. Kid just graduated from college and needed reliable wheels to move and start his new job.
Did you buy from a dealer or private individual? If a Toyota dealer or reputable used car dealer, they might have some records or should offer you some assistance, IMHO. At least they should have seen these problems coming. Word of mouth is the best advertising and a crummy dealer's worst enemy.
I don't believe your experience is necessarily unique. I purchased a 1995 with 99k...knew about the rack and pinion power steering leak, but it isn't leaking too badly yet, so I'm just monitoring the fluid level. If your daughter's car needs a power steering pump, and you don't want to shell out the $250 for the part, you might find an industrious (non-dealer) mechanic who can rebuild it. Mine was done and it worked fine. Struts, valve cover gaskets, power steering fluid leakages...all very common problems with Avalon. I'll keep mine Avalon for a few more years, then trade it in a brand new Honda Accord EX V-6. IMO, Honda experiences none of these relatively high dollar repairs, if regular preventative maintenance is conducted. RE: Relief from Toyota...I sincerely doubt it.
Good Luck!
Thanks for any feedback.
Missy1, I have the same car with 162K miles on it but I haven't had that problem. You might try a shot of wd-40 at the throttle body where the cable attaches to the half-moon looking wheel. I did this to the cruise control cable and it helped.
MikeS.
I hoped this helped - it may not be the solution, but it would be the first/least expensive area I would look at.
Same goes for the engine - no problems with gasket leaks or usage at all. I use Amsoil 0W-30 and Amsoil filters - change the filters at 12.5k miles or 6 months, and filter/ oil at 12 months, per Amsoil instructions. Oil lab analysis has shown this to be perfectly acceptable and in fact I could probably go up to 15k miles on the filter change. Other than top-off at filter change, the engine doesn't use a drop of oil. (Wish I could say the same for my Infiniti I30 engine - great performer but uses about a quart between filter changes - same oil and filters as in Avalon).
I have also drained the trans pan once, and refilled with Amsoil ATF (as I recall was about 5 quarts), and had the filter changed/ pan cleaned/ refilled one other time - was around the same amount of lube, maybe a little more. So most of the trans lube should be synth at this point. Even at the initial drain (90k miles), the fluid looked to be in fine shape, no discoloration or burned smell. However, I have no idea if it was original fluid/ filter or not. Never have to add ATF either.
Needed a cv boot when I bought the car (replaced whole axle at Toyota dealer, paid for by used car dealer) - but this looked to be due to a tear from road debris as opposed to a failure - other unit is original and in fine shape. Did the tie rod ends and ball joints 20k ago - but I blame this wear as much on the crappy roads around Detroit as any fault of Toyota. Just did the right side wheel hub/ bearing - ditto on the crappy roads. Neither of these repairs seem to be chronic issues with Avalon.
BTW my friend used to be a field engineer for Toyota, he said 250k miles should be easy, if general maintenance is followed and the timing belt replaced every 100k miles.
I put 16" 2004 Camry wheels and Kuhmo ASX tires (215-55/16) on last year - a nice combination although the tires are overkill for this car. Have 35k miles and still about 60% tread - not bad for a $75 (Sears) W-rated tire.
I will drive this car until the wheels fall off~ has been a great runner for me overall. 27mpg with mostly highway miles (500+ miles per week) at 70-80mph.
The fluid goes in at the dip stick tube. Use a funnel. Measure in PINTS, not quarts, this is not motor oil.
Existing fluid should be reddish or near clear. Black may be worn out or contaminated and needs a change. Smell it. If a strong burnt odor is present, change it all, not just add.
Add slowly. Never overfill. Too much causes internal foaming. That's bad. Engine and transmission must be normal operating temp for accurate check.
You might also check for leaks on the ground or on the sides of the housing. Toyota's are very tight and do not generally leak. Anything.
Properly maintained, Toyota transmissions last 200k miles or more. Many posts in Edmunds.com attest to that.
Hope this helps...my '99 XL was perfect at 92k when traded for a loaded '03.
I just bought a 2005 Avalon XLS a month ago.
It's a real smooth ride ,and I enjoy driving it. The only complaint I have is the acceleration from a dead stop is not the greatest . Anyone notice a lack of power in low gear ? My old Camry seems to take off faster . The 280HP is at it's best at the higher speeds. The dealer is going to check it out anyway. Maybe I just have to get used to it.
Jimmy
abfisch
The 2004 and later RX models use a DBW, e-throttle, to delay the onset of engine torque during downshift to allow the internal clutches to more firmly and fully seat and therey prevent an inordiante level of wear on the clutch surfaces.
Some of us have begun to believe Lexus has instituted a secret warranty to cover at least some of the costs in order to keep steady or return, GOOD customers, in the "fold".
Bad luck is bad luck. I am sorry you have had this misfortune. You did not mention how often you changed the tranny fluid and filter. Did you have this done??? Is this car driven in stop and go driving alot?? If so, did you turn the O/D off??? 93K sounds premature indeeed. I cannot see how you would buy another one.
If you do buy another car with an auto tranny, develop a habit of not only taking it out of O/D when needed, but "back off" on the accelerator a little at its normal shift points to decrease the load on the tranny. This will make the shifts seamless and make it run much longer.
I have an 02 XL with 77K on it, and I regularly tow a utility trailer, yesterday loaded with X-mas tree mulch for our Spring planting. The catepillar front loader must have put in about 1200 lbs worth of mulch. I drove home slowly, and put the tranny in D2 in town, and out of O/D on the state highway. I change the filter and tranny fluid about every 40K. I use slotted rotors in the front brakes and the back for the extra load and performance.
Let us know what happens.
abfisch
A change includes a filter/kit(gasket) with the fluid change.
Hope this helps someone.
abfisch
FWIW: There's a lot of interesting information on http://www.autoshop101.com although it might be a bit dated, i think the fundamentals of fuel injection scheduled by an ECU aren't drastically different in your car.
Look under Technical Articles.
If an engine control module were mainly there to provide fine control of scheduling fuel/air, thus the fuel injectors to admit fuel consistent with air flow and engine speed (i think there are optimum values the ECU tries to hit measuring many sensors and adjusting injector on/off duty cycles to adjust fuel flow rate and timing), then I think it is also true these modules are programmed to play additional tricks when the vehicle is first starting and also when running with the engine at sub-optimal temperature.
Being a complete novice at this stuff (i'm interested in reading more and learning more so again, take it for what it's worth), maybe the coolant temp sensor read by the ECU to tweak the schedule mainly formed by throttle, airflow, engine speed is at fault.
You say when the engine warms up, you are fine. So I'm thinking, I'd perhaps look at the coolant sensor. If this part isn't too much, or if you can get one from a pull-it place and find it to remove and replace it, I'd give it a shot next.
- Paul
A faulty wire connection someplace.
What were the fault codes??
Other than affecting fuel consumption what other damage this could cause?
Anbu
I bought a 2000 Avalon XLS which I purchased at 60,009. After driving 615 miles, my check engine light (CEL)came on...no codes stored...but for some reason dealership check code #0773. It was not my gas cap!! Drove the car 1,948 miles, CEL came on with code #0773. Dealership replaced the transmission under my extra care warranty. Drove the car 15,908, CEL comes back on with code #0773..dealership replaced vehicle speed sensor. Now at 89,000 CEL is back on with code #0773 and code #0171 (air flow sensor). Extra care warranty is expired and now they want to replace
Engine Control Module at the cost of $1283 (pts/labor) and the air flow sensor at $251 (pts/labor)..plus its time for a transmission flushing for$169.95 for a total cost of $1705.95. After reading all the postings on the AT in Avalons, I wonder if cars owners could start a campaign to get Toyota to recall whatever is causing so many people to experience transmssion problems so early in the life of avalons or any other toyota products. Toyota boast such reliable cars. :lemons??:
P0773 Generic Shift Solenoid E Electrical
P0171 Generic System Too Lean (Bank 1)
Perhaps its time to talk to your dealer. There are many things that can case a System Too Lean. I'd look towards the O2 sensors or mass airflow sensor.
Hope that helps,
Net
PS - Here is a link to a code look up data base just select Toyota and enter P before your codes p0171, etc.
CANOBDII.com
Take it to someone else. Overpriced. Way overpriced. Yes, the power steering uses same TypeIII fluid as the tranny in our model. Fluid resevoir on the passenger side of the engine bay nearer to the R wheel well. Black colored cap, easy to access. After repairs are made, changing the tranny fluid and the PS fluid(relatively easy to do) at the same time is a good idea in this car.
abfisch
(1) At 63,000 miles I changed the transmission filter and fluid. Unfortunately, the check engine light and VSC lights came on with an error code of P2735, Pressure control solenoid Electrical (if I remember correctly). Toyota Dealer couldn't find anything wrong just using the scanner. Would have to charge to drop transmission pan to view - be prepared to replace a valve at a cost of $166 + 2 hours labor. Car runs great; no burning smell in fluid; proper fluid levels.
(2) One neighbor, a former Toyota mechanic, recommended I buy the service manuals since I plan to keep my car for 200,000+ miles. Should have asked which one(s). Recommendations?
