Pontiac G6: Real World MPG
I have been looking at the G6 4cyl base model. What kind of real world
city and highway gas mileage can I expect? Does the 4 have adequate
power? Thanks
power? Thanks
I have driven the car and power is more than sufficient, it's quite peppy. The 2.4L is very modern with VVT.
Can anyone tell me if the mileage improves? The best I got one time from a road trip was 25.
I like the car otherwise, our fifth Pontiac.
Driving about 700 miles, mostly highway, I got 30 MPG one way and 32 MPG the other way.
It was a while before I realized the trip computer was in the stereo. Once I found it, I was able to do some quick checking in the brief amount of city driving that I did. It appeared to be 22-24 mpg in fairly heavy traffic.
Based upon this trip, I would not hesitate to recommend the G6 to someone looking for a fairly inexpensive car. I don't see any reason to pay for any more engine than the 2.4.
Overall, I was impressed by the G6. My only significant complaint was that the stereo had no minijack input or cassette deck, so I had to play my XM Roady radio through the FM transmitter, and there was a lot of interference from other people doing the same thing.
Love the remote starter however just recently the air conditioner acts up when starting remotely like its trying to do blow air but doesn't. Only happens on remote start.
Otherwise, great car. I'm pleased.
This is mainly highway driving, but I have gotten better than 30 on long trips. Given the size of the car and the power put out from the V6 engine I am very satisfied with my gas mileage.
The first type is the lead-foot who drives at high speeds, tailgates, and is always having to hit the brakes to keep from rear-ending the slowpokes. Even if you are not a tailgater, driving at 80mph will get much much worse mileage than someone who drives a modest 60mph.
The second type of driver who gets poor mileage is one who I have particular enmity towards--that is the people who drive an automatic with two feet, one on the gas and one on the brake. This type will swear that they are not riding the brake, but in fact they are and it will kill your gas mileage.
A good way to tell if you are either of the above driver types is to ask the following question: How many miles do I get off of a set of brakes? If the answer is anything less than 50,000 (and it should be more), you are either riding the brake or having to brake too often and it will kill your gas mileage.
If you can honestly say you are not one of these drivers, have the dealer check the car because something must be wrong.
Just my two cents. Hope it helps.
I've seen the mileage computers be off 5 mpg or more.I have a 2004 Chevy truck that was off about 1.5 mpg consistently. It always got about 1.5 mpg less than the computer said it got.
It was gallons divided by miles.
For the total package considering size, roominess, comfort, performance, I am reasonably happy. We will see about long term. I am used to taking my cars to 200,000 miles but do not expect that of this car. I have owned mostly VW or Subaru over the years.
The 2008 owners manual states:
"If your vehicle has the 2.4L L4 engine (VIN Code
use premium unleaded gasoline with a posted octane
rating of 91 or higher. You can also use regular
unleaded gasoline rated at 87 octane or higher, but
your vehicle’s acceleration could be slightly reduced,
and you might notice a slight audible knocking
noise, commonly referred to as spark knock. If the
octane is less than 87, you might notice a heavy
knocking noise when you drive. If this occurs, use a
gasoline rated at 87 octane or higher as soon as
possible. Otherwise, you could damage the engine. If
you are using gasoline rated at 87 octane or higher and
you hear heavy knocking, the engine needs service".
A 4 cylinder engine would not benefit from reduced acceleration. I also don't want my ride sounding like some beater. Premium unleaded in my area is 93 octane. I will not use a fuel posted 6 octane points lower than recommended. Back in the day, you could get around spark knock by adjusting the timing and fuel mixture. Since cars these days are computer controlled and no user adjustments are available, I'll go with what is stated in my owners manual.
It also states the 3.6 VIN code 7 will run better on 89 octane for towing. Everything else in the 09 line up is 87 octane.
Something must have changed from 08 to09.
2008 G6 2.4L with 64,000 mi on the 5/10/2011 road trip. I just returned from a 725 mi round-trip N. GA / N. MS on 07/29/2012. Car averaged 29.4 mpg @ 70 mph with A/C on full-time & 1 adult passenger.
