Pontiac G6 Tires/Wheels
                    I have been leasing an '05 Pontiac G6 since 11/04.  At 20,000 I need to replace my tires.  This seems unreasonable to me.  Does anyone have any feedback they can offer?  OR can you share your experiences with a short tire life (I've read a few other complaints about this)?
Thank you,
Colleen
                        Thank you,
Colleen
Were they worn out evenly or were the outsides worn out more or the insides or one side more than the other?
Which tires did you have?
If all tires were worn evenly the cause is probably a high performance sticky tire compound that gives up wear life for handling performance.
If the centers were worn out more than the outside then over inflation and under inflation if the outsides worn more than the insides.
If uneven wear then a possible suspension problem.
Not sure how to answer this.
They are worn evenly (front tires and back tires).
Continental (the ones that came with the car?)
So, in your opinion, is replacing my tires reasonable?
Thank you,
Colleen
Which tires are the Continentals? If they are the performance summer only 18's then wearout would happen faster than the others but 20,000 is still low. Since there was nothing wrong with the car the tires must have a very sticky compound. Most you can do is go to a Contintental store since, I believe, they warrant the tires. Sounds like the car was not the problem.
Any tire you pick will effect the ride and handling in different ways. Most likely the tires you had were chosen and developed for handling which meant they had a sticky rubber compound. This sticky rubber will wear faster but gives you better grip/handling. So if you do downgrade to H expect a little less handling, a bit more comfort and more life.
Secondly, I am always amused when car owners are not aware of the components on their vehicle. With regards to the price of the 17" Contenental's. Every tire has a size, and a speed rating embossed in the sidewall, along with a treadwear rating, temperature rating, and tire ply construction. If you take all of this info into a respectable tire dealer, and price the perspective tires, you can logically deduce the amount of tire cost maintenence. This procedure also works with other maintenence items (filters, belts, hoses, brake linings), anything that is DESIGNED to wear. Just some FYI!! Try Tirerack.com on those expensive speed rated, low profiles. I had a disgruntled co-worker line my path home with nails, and had to replace a tire. Discount Tires wanted $250.00 a tire, but Tirerack had them for $130.00. Guess where I bought 'em!!!!
I LOVE my G6 GT!! The only issue I have with mine was a noisy sunroof. Not wind noise, but self loosening attachment bolts. After 2 trips to my local dealer, I finally got the Service Manager involved. He informed his trim "tech" about Loctite thread locker, and my 3rd trip has seemingly corrected this problem. I mention this because I searched this forum, and the web, and saw that NO ONE has experienced my sunroof problem. Anyway, happy $3.00 a gallon motoring people!!! :shades:
BTW, it seems the G6 is least likely of all cars to roll over. Hey, i guesss they really do mean sport, since a performance car is not supposed to be prone to rollovers.
OMG, i hope he is in jail for attemped murder, b/c thats what he/she did!
I saw 2 G6's in my neighberhood today, both red sedans, one was a GTP and the other a justpurchased 4cyl. Man, it looked like the GTP was in another class of car! Good diversification i guess. GM needs to ofer the base models with leather, and meybe some better wheels.
The jerking sideways over bumps is basically the same as when you take a stopped car and at one corner, you rock the car sideways. I assume this jerking sensation over bumps, could be the sidewalls of the tires but I want an expert opinion. I called the dealer who replaced the steering gear about the problems,and the service rep got kind of defensive. I had the alignment checked before the steering gear was replaced and everything was within limits.I am going to have the wheels balanced and the tires checked. They have plenty of tread on them yet.I also get a vibration starting at around 65mph. When going over the railroad tracks, maybe a better way to describe the sensation, is that the car feels as if it kinda floats over them.Please let me know if you have any more thoughts. Thanks
Have had my 05 G6 for almost 3 years now and have 58,000 miles on it. Original tires lasted 50,000. Am writing you because of your comment regarding the steering column. My G6 started making a noise coming from the steering column or front wheels recently. Sounds like two metal objects that are in a bind and then release when the steering wheel is turned. Hard to describe the sound, but "cracking" might be appropriate. May be the same thing as your "poping" description. Am taking it to the pontiac dealer tomorrow. Any thoughts on your end?
S.
I was wondering if anyone knew of a place that would chrome plate plastic. I have 08 G6 that has plastic wheel covers, but they look like real rims, and have the spokes, and they are not the ones on the base model G6. I want them chromed. I have seen similar rims chromed, so where would I need to go. how much $$?
At 25,000miles, they still look like new. Though I always have tire shine on them, rotate them often.
It looks like they now use Firestone. Are they better you think?
Rotating often will give you good service from the tires. The rotate will even out the wear, the front scrubs the outside in a turn, I have noticed I take turns faster because of the solid feel.
I don't know anything about the Firestone, they did have problems a while back. When I put on replacement tires, I always use Michelin , in a rut.
My Accord had real Alloy rims. Oh well, I am over it. At least they look really good though. With a little tire shine, and no one will ever tell they are not real rims. No one has ever said anything. Looks good! But, a disappointment for GM. Just like most new Malibu's. 80% are the fancy wheel covers!!! Even their chromed ones. Seriously?
Now with snow and salt, my car is itching for a big bath!! It bugs me!
When I test drove my G6 is when I noticed the 5 spoke steel, told to salesman GM almost had me fooled, didn't know 5 spoke steel were out.
Check the seat belt. My G6 was doing the same thing and no GM tech could fine the problem.
You still under warranty?
I have 45,000 kilometres on my G6 and I have replaced three tires, one tire had less than a 1,000 kilometres on it, Today I got another flat. I think they are uniroyal, help, any advice. I believe there is something very wrong with G6 tires.
