I had no luck with 14 at all. I used 13 for ground PLUS ran an extra length of the same wire to the body/chassis of the radio itself. Just taped it off with electrical tape. This extra length allows the AUX button on the front of the radio to work as you would think it might.
If you are reading through the pdf I amended, jump down to page 9 and see if my comments are listed there.
Hope this helps.
-Karen in AZ-
Oh, and thanks for writing all of that up. That's awesome!
-Reg in Boston
-Karen-
You can find the pdf at: http://members.cox.net/kamartin/AuxInstall.pdf
The original pdf is not my work, but make sure you read the ground info I contributed on the last page. Let us all know how it works out.
-Karen in AZ- :shades:
BTW, the volume is controlled entirely by the car's stereo system, not the iPod. Also, the charger (or lack thereof) will not affect the audio, except possibly by creating mild ground loop interference.
Does that help?
-Karen-
Nothing happened when we pushed the rse button with the radio playing nor with the cd playing. Got to be something simple we are missing since it looks to be so straight forward. As I said before, we tried my old ipod (original model), shuffle, itouch and my 3g iphone.
I did not solder additional material to the wires. I did curl the end and pushed them in about an inch, Could it be they are too thin and not connecting inside...I don't know what they are connecting to inside.
We need the car this weekend so it is reassembled but we will try again next week with any words of wisdom from you...and thank you
Tami
Karen is the guru in this area and her "manual" for doing this is awesome! As someone who followed it a few months ago, I can only point to a few things that you should double check. First, double check that you are really grounded. Several times I thought I was grounded and I wasn't. Second, if you followed her advice and purchased the Apple cable, then they are not too thin. You do need to make sure they are securely pushed in. No additional soldering should be needed. If you also did the video hack, does that part work? That might be helpful to know.
FYI, you should know that the volume level that will come out of your iPod will be a lot lower than the level of the stereo. I use an iPhone, and I had to have the stereo at volume 22 or so, compared with 8 or so for normal radio/cd use. I ended up adding a small amplifier in the loop so that I didn't need to constantly adjust the volume to go back and forth between using the iPod and the stereo.
Good Luck!
--David
What is this amplifier, and how does it get connected?
So the AV cable goes into the earphone connector?
If I have the DVD player in the back, is the auxiliary input behind my radio already occupied?
Jeff/433
In the post, the guy mentioned the cable was made by xtrememac, but I haven't been able to find it, or an equivalent.
Jeff/433
I actually patched the Apple AV cable into a Radio Shack cable and stripped the RS cable leads. Then I soldered thicker copper wires (1" or so long) to the leads and used those to patch into the radio connector. And, while I connected everything, I had the ignition/accessory on so I could test each connection as I went. Saved a lot of time re-pulling everything.
I think the similar Monster-brand cable has been discontinued, although you might still find it on eBay or Amazon. Apple's is readily available at many local stores (I've seen it at Walmart, Radio Shack, Best Buy, Target, etc.) and very good quality.
-Karen-
Tami
-Karen-
Thanks again for your advice. Happy listening
I saw that you had info for direct connection of IPOD and other devices for a 06 Sub B9 Tribeca. I just purchased a used one and would like to hook up my Sirius Satt radio this way. Can you email me this info? I was unable to find a way to contact you thru your profile.
Thanks a bunch!
Lisa
I am already able to connect the phone (it's a HTC HD2) to the AUX jack via the 3.5mm plug in the center console and listen to music. When the phone rings, the music automatically mutes and the caller’s voice is piped into the speakers in the car. However the MIC on the phone is somehow disabled so the called cannot hear me speak.
Does the radio in the Tribeca have a MIC-IN capability? If yes, I think I can wire a microphone and (onto the steering column) and be able to use it as a hands-free solution in the car. Does anyone know if the radio has this capability, please?
Has anyone tried this and got it to work? Thanks in advance.
Do these instructions work for that stereo system.
If so I would love to get them.
Could you send me instruction of setting up AUX Input for the B9 Tribeca? (email: tribeca@nur.otherinbox.com) Thanks
Same problem as you all...want to find a way to connect my iPhone on a direct plug...the FM transmitter was very poor quality sound...so if some one can help me on that...i got a B9 Tribeca 2006 with no Nav and No CD Charger...you can write my at centhron@hotmail.com
Thanks everyone!!!
>. Do you mind my asking which power leads you used in this case?
Thank-you
Thanks Steve. (srgrupe@verizon.net)
http://www.sb9t.com/forums/showpost.php?p=10555&postcount=22
I have only recently seen this post and would love to have the information to direct connect to the stock player in my 06' B9 tribeca. Please advise.
Thank you,
Danny
