Toyota Camry Hybrid Brake Problems
24
  • plknjplknj Posts: 121
    It has happened in the cold weather, usually at start-up and quickly goes away. Have not heard the sound recently as it has gotten warmer... I have 10,000 miles on my TCH.
  • mrpatmrpat Posts: 24
    I hear a brake squeak or squeal at low apeeds, parking lot, garage etc..
    Ive seen refernce to a technical service bulletin but i dont know where to find them.
    Going in for the first service appointment tomorrow, will check back in the morning.
    I also want to get fog lights and a block heater for winter FE.
    average 35 mpg so far, 22 with my Volvo
    Please tell us what they say about fog lights as I have never gotten a plausible answer. Thanks.. Peter
    I dont want them any more I just posted a reply to someone who got the zenon headlights installed instead. I will try to get them installed.
    Dealer said fog lights would cost about 900.00
    Definitely not worth it unless done at the factory.
  • thaipthaip Posts: 32
    Hi all,
    I just picked up my TCH and everything is good so far except for the break. When I am breaking to stop the car or simply slowing down the car, it makes some kind of noise like wind blowing noise or hail noise.
    Does anyone expriencing this problem? please share!
    thank
  • lzclzc Posts: 483
    What you describe sounds normal to me. Both the hybrid system and regenerative brakes make distinct sounds, most noticeable when braking or slowing down. Some people call it a whine.
    Hi All,
    I am in the process learning all about the TCH. If anyone exprience the below situation please share! When the car stop at a traffic light or at park or when just started, the fuel consumption gauge at E, now you step on the gas pedal to get the car rolling, the car is not rolling smoothly like a regular gasoline engine car would. If I step on the gas pedal very slowly then the car rolling smoothly. I don't know if because it is in the transition stage from electric to gasoline so the car is hesitating?
    The ECO button, is it o.k to use it all the time? Does it really help with the MPG? My first tank, I averaged 32 miles and I put on 480 miles. Will I get better MPG?
    PT
  • lzclzc Posts: 483
    From a standing stop, it's normal to feel a slight shudder when the engine starts up. Once up to speed, the back and forth switching of the hybrid system should be hard to detect.
    If the ECO mode saves gas, I haven't noticed it. On hot days I think it reduces the cooling output of the AC too much.
    Your mileage will vary greatly based on how and where you drive, length of trips, outside temperature (cold weather hurts hybrid mileage), and I'm sure a few other factors.
    The best test is probably to take a long freeway drive. At 70 mph I'd be surprised if you didn't get 38-40 mpg (assuming it wasn't mostly uphill!).
    "From a standing stop" you mean at when the car just started, at a full stop sign, and at a traffic light right? I didn't feel anything once the car is rolling at a very slow speed like 2-5 miles and during transition from this low speed to higher speed. The car only shuddering when I step on the gas pedal after the car is at full stop. Is the above situation you exprienced?
    I also noticed that when I had the ECO button on the AC reduced the cold air. I read the manual and it says that the ECO can help to improve MPG but will reduce cold air or heat, take longer to cool or heat up.
    PT
    I havent noticed the eco problem, I want to have my dealer set eco up to be always on.
    I normally start out gently and hardly feel the shudder, now that I have 2500 miles I sometimes accelerate fast when the situation calls for it; it takes off like a v6 and no shudder at all.
    I looked up toyota canada and im going to try to have the back up assist, a canadian spoiler and a block heater installed there, should be about 2 500 mile tanks of fuel and a nice ride.
    Toyota canada has a better customizing web site if you choose the xle model. they dont show much for our hybrids
  • I've owned a TCH for 5 months. Today I noticed a couple of odd noises that concerned me. I'm not the primary driver, but my partner and I heard them for the first time today, and I wonder if this sounds familiar to anyone here.
    1) a rumbling/clunking sound like something stuck on one of the wheels, because of how it cycled, coming from under the body of the car. We noticed it pulling out of a parking lot; it was very audible at low speed. We checked all four tires and under the car, and didn't see any obstructions.
    2) Eventually, the first sound stopped, but shortly after it started, we started to hear a vibrating sound coming from the engine. Vibration lasted about 5 seconds, and repeated every few seconds -- almost like a broken DVD player trying to read a disc. We pulled over, opened the hood, and saw that a unit in the brake system (in left front of engine, next to wiper fluid container) was vibrating every few seconds. The sound continued through the rest of our drive - about 20 minutes.
    We never went over 30mph, and no indicator lights or messages appeared on the console. Brake fluid was full. Brakes themselves were as responsive as usual. After we parked the car, we opened the hood again, and the vibrating persisted for about 5 minutes after the vehicle was turned off.
    My partner drives the car daily, and we have had no problems with it before now. Dealership maintenance dept. is closed for the holiday, so I thought I would ask if anyone has experienced something like this. I am a novice at autos, so maybe I'm missing something simple, but it seemed abnormal.
    Sorry for the long post, and thanks for any suggestions.
  • ixi26cixi26c Posts: 1
    This is normal; when you press gently on the gas pedal you can probably still stay in E mode, which means your gas engine is completely off and you're only using the electric motor. But when you "give it some gas," the gasoline kicks in, causing a jolt. You'll also feel a jolt when you stop and the gas engine turns off.
    Sure you can use the Eco mode; it's just for the cabin thermostat. Sounds like you could accelerate a little slower and get better gas mileage; I get 38-42. The THC doesn't have the power of a regular gas car which can be difficult to adjust to, I think, for some people.
  • acco20acco20 Posts: 211
    Not exactly right. The hybrid although not as fast as the 6 cylinder, is actually faster than the 4 cylinder. The test was done by one of the car magazines, and the hybrid left the 4 cylinder behind. Seems that most hybrid owners concentrate on mpg and forget how to DRIVE. The 2007 camry hybrid, and all camry hybrids since, have been favorably compared to earlier 6 cylinder models.I hope you find this information helpful.
  • I have a 2007 TCH with 44,000 miles on it. I have never changed any of the brake pads, front or rear. Suddenly I can hear the rear brake calipers grinding the rotors. By just looking it appears the rear pads are at 0% pad left while the front are probably 80% or more. I have never had a car where the front pads didn't wear way faster, not the other way around. My Toyota dealership tells me it's because it's a Hybrid. Can anybody verify that?
    Another question: Can anybody think of a reason I should pay $239 at the Toyota dealership for rear pads and machine rotors as opposed to $89 at Just Brakes.
  • lzclzc Posts: 483
    This is a question not a problem. I'm about to take the car in for its 3-yr service and I was expecting to have to the brake fluid changed. But the maintenance schedule doesn't suggest it, nor even mention changing the brake fluid through 10 yrs or 120K miles.
    I thought changing the brake fluid every 3 yrs had become standard maintenance. Why not with the TCH? Thanks.
  • cdn_tchcdn_tch Posts: 194
    The rear break pads will wear more since the regenerative braking is only on the front and the car uses the standard brakes on the back.
  • I have an 07 TCH with about 85000 miles. About 3 months ago, I had to do an emergency stop from about 40 mph to avoid a dog (succesfully). I did not notice the problem before. After the car is warmed up (10+ miles) and particularly at highway speeds, I hear a high pitched squeal - it sounds like the metal break wear indicators. Occasionally, you can hear the squeal at around town speeds. It changes when you hit the brakes - sometimes worse, sometimes it goes away. If you gently steer right / left on the highway the noise changes as well.
    I took it to the dealer and asked them to look at the brakes. They said everying is fine - 10 mm left on front, 8 mm left on back. They cleaned the brakes and said that should take care of it - but it didn't. When I stop the car, then feel the brake rotors - generally the fronts are cold, and the backs are warm with the drivers side back being warmer than the passenger side.
    Is it possible that I cracked a brake pad, and they didn't see it when they did the brake inspection? Is it possible that one brake pad is worn out and they didn't notice? Braking performance seems to be fine. Coincidentally, the mileage is worse than normal (33 on this tank) but it always gets worse at this time of year with the colder weather. The tires I put on this spring didn't appear to help either - General Altimax RT - T rated. They appear to have lost 2+ MPG.
    Any other possibilities? Should I just get the rear pads replaced and see if that helps? Could a caliper be frozen? Could there be a computer problem in controlling the brakes? Any ideas are appreciated!
  • lzclzc Posts: 483
    No, I wouldn't start replacing brake parts just "to see if that helps."
    I'd take the car back to the dealer and make sure the tech knows exactly what noise you're talking about. If it occurs even when you're not braking, it may be something else. The dealer may have looked no farther than the brakes.
  • I have an "air" hissing sound coming from the ABS controller (pump) located between the wiper fluid tank and the radiator overflow tank at right front under the hood. Number on top is 44510-30270 TOYOTA 1QB02 - 106. The "pump" cycles on about every 5 seconds, runs about 5-7 seconds but the hissing sound continues. When I push on the brake pedal, the hissing sound becomes muted but the pump continues to cycle... Any ideas
  • Thanks for the reply. In the end, I took it to a different brake shop. They found that the dealer had done a poor job looking at the brakes, and that on the passenger rear, one of the brake pads had 8 mm left, and the other only had 5 mm left. One brake pad had rusted into the anchors and was stuck. They reported that this was common with Camry's of this vintage. I may have gotten taken to the cleaners a little bit - they replaced the rotors and pads, and bled the brakes for ~ $450. It's hard to believe that it wouldn't have worked to pull it apart and clean things out.
    The good news: no more squealing, mileage is back to normal. I suppose that $450 in repairs in 3.5 years / 85,000 miles is not so bad.
