Chevrolet Malibu Maxx General Care and Maintenance
This problem kind of gradually creeps up on you, scares the hell out of you, then fades away as if it never occurred. I finally experienced it while driving this past weekend, so I don’t think my wife is imagining it. I drove the car on the interstate at 70 mph for about 45 minutes, with no issues. The wife needed to have me stop at a rest area so she could use the facilities. I parked the car and turned off the engine. I waited about 10 minutes, then we proceeded on our way. In merging onto the interstate, I noticed that traffic was really coming up behind me fast. I pressed down on the accelerator, and it seemed unusually “stiff”. I finally kicked it into passing gear to get up to speed. The tachometer shot up way past 4000 rpms, then settled back to under 2000 rpms pretty quickly. About 5 minutes later, I started to hear this rhythmic thumping coming from the right front of the car. It almost sounded like I was driving over those rumble strips that they have along the edges of the highway. It was faint at first, but then it got louder and louder and I could feel a matching vibration thru the floor and the steering wheel. I went to use the brakes to slow the vehicle and I thought the front end was going to shake right off of the car. It was really scary. I drove a few extra miles at reduced speed, and it eventually faded away to nothing and it was like it had never happened. We got to our destination, and stayed for about an hour.
I drove the car home, and it never once happened the whole way home (about 90 miles). I have the car in for service at the dealership that I bought it from, and they are doing a few things under warranty. I had asked them to look into a clunking noise from the front end which occurs when I straighten out the steering wheel after making a turn. They said it was a loose outer tie rod end and they replaced it. They didn’t mention any other front suspension issues. I figured that if it was something mechanical like a bent half-shaft or bad CV joint that it would be doing this constantly. They said that no fault codes were stored in the ECM, and that they had taken the car out on the highway several times and were unable to get the car to do it again. While they had the car, I had them do the recommended 50,000 mile transmission service. I figured that if this turns out to be a transmission problem, at least I can say that we did the recommended maintenance. My extended warranty has only got another 40,000 miles on it, although I’ll be making another 3 years of car payments on this vehicle. My wife puts about 100 miles a day on it going to/from work.
Have you ever heard of anything like this happening with a Malibu Maxx, and if so, what was it?
I hope that you can shed some light on this or give me some advice. I just lost my job 2 weeks ago, and money is going to be kind of tight till I find a new one.
I called the dealer that did the work, and told him that I still hear the "thump" coming from the left front after straightening the wheel out after turning. He suggested that I bring the car back and have one of his tech's ride with me to see what I'm hearing.
So......I guess it's time to do some brake work. The question for all you who have had work done on your Maxx's discs...what kind of ball park $$$ am I looking at? Did you have it done at your dealer, a Goodyear-type place or an independent? Just wondering -- thanks.
Most trouble-free service I've had has been from small shops that are owned by the guy doing the job - who should be a ASE certified Master Technician.
I'm in the South and some time ago had brake work done by a place called "Just Brakes" - not recommended. Have had Sears do some work - not recommended.
Had a ASE Master Tech do some work - excellent.
After getting the dealer to replace the outer tie rod end on the passenger side front and putting new brakes on all way round last Friday, I had the tire with the dinged rim moved back to the rear of the car. We took a trip yesterday with 2-1/2 hrs of driving each way, and didn't feel a single ominous vibration of any type, so I think the problem may be fixed. I was really surprised at how cheesy the design on these wheels looks (we have the factory steel rims with the fake aluminum colored wheel covers). Are the factory alloy wheels for this car any beefier in construction than the steel wheels? It doesn't look like it would take much to damage these stock wheels.
Then look towards the top of the opening and you will see a small latch and door on the side of the HVAC housing. Once the latch is opened (you either press it down or flip it - it's been a year since I've owned a Maxx), the door can be raised and you can then pull the cabin air filter out and replace it.
'04 Maxxes did not come with the filter. I juryrigged a Saturn ION filter and plastic support mesh inside my HVAC filter opening, which worked very well.
or Trico 45205 wiper refill (have to trim); ANCO N-14R, 350 mm
Also, what are the best sites online to buy parts for the Maxx? I live in Canada, so shipping fees are important. Thanks. We've had our Maxx for 5 months now and so far, so excellent!
The same of the drivers side electric seat operation. It gets stuck in one position for a few days and then it just starts working again.
Other than that, love this car.
