I was shocked when the service manager told me HE HAD NEVER HEARD OF THE PROBLEM! All of Ford and their dealers are aware of this problem now! Also, the woman I spoke with on the phone to make the appointment said Escapes HAD been in for the problem. Here he was lying to me! I made it very clear that this was strike one against them, and that if it happens again I will seek remedy under the Lemon Law. THIS IS A MATTER OF SAFETY.
They did their useless battery of tests, all of which came back OK. I told them of course everything is OK, I have not had a single problem with this vehicle before or after the stall.
So I drove away in my ticking time bomb. I will post again after my next stall, if I am still alive after being rear-ended by a tractor trailer.
Also, I am posting a complaint with NHTSA as should everyone to get Ford to fix their defect.
I am an Escape owner with stalling problems. Putting this aside, it's a great car. However, I would recommend NOT going with a Trib/Escape. There's not much scarier than going down a windy road and your car loses all steering and braking power. And Ford DOES NOT know how to fix it yet according to my dealer when I asked them straight out - they only are doing "well, let's see if this works" type of things. Am currently pursuing Lemon Law against Ford.
I purchased a Mazda Tribute (DX-I4 AWD, 5 speed) the first of March 2001 which was delivered to me with the battery light on. A new alternator was installed on March 6, 2001.
After that the battery light disappeared, however I encountered several incidents where I would come to a stop and the engine would lose power, with the idle loping to 250rpms. The vehicle would shudder and almost stall. I reported this to Mazda and they asked me to "look for a pattern" to help diagnose, but the symptom seems too damn intermittent.
On November 7, 2001 the battery light came on again. I immediately drove straight to the dealer as it felt like the alternator has stopped working (which it did).
They could not diagnose the problem and kept the vehicle in the shop for 3 weeks. I picked it up again on November 22nd and was assured that "the problem was fixed". The work order indicates that they replaced (in this order) alternator, PCM, wire harness, GEM, PCM (again), airbag module, alternator (yet again), EEC relay, instrument cluster and battery.
Sooo... I'm on my 4th alternator and 3rd PCM. I guess that I'm getting mileage out of the warranty, heh. The bad news is that I had a power drain/idle loping incident within days of picking the vehicle up, and several since that.
On Wednesday, Dec 12, 2001 I brought the vehicle back to Mazda. It checked out 100%... nobody can find the problem.
I've lost complete confidence in this vehicle and have approached Mazda for a replacement or refund. Mazda reassures me that this is what warranties are for.
I can honestly say that this has been the worst consumer experience of my life. I have owned three Mazda vehicles back-to-back (two previous B2600 trucks) and seriously doubt there will be a fourth.
More importantly I am very concerned that eventually I will encounter the stalling problem, or the alternator will fail again somewhere up in the mountains.
I am sorry to see that others have experienced similiar or worse problems.
I still believe that the Tribute is the best designed vehicle in it's class, and I have found it a joy to drive. However Mazda needs to address these serious power problems and work on the Tribute's reliability.
I'm hoping that Mazda will eventually stumble across the problem and we will all put this issue to rest... before somebody is seriously hurt as a result.
I'm also looking for others who have experienced these brief power drains while stopping the vehicle, notably with the DX 5 speed model.
Dino Nardini
Do not take this personally, but before you start posting numbers, you should know the the facts. A few weeks a ago I would have agreed with your estimate "about 100 complaints". You need search through all categories (components). For example, when I posted my stalling complaint, I listed it under "engine" but it appeared under "fuel: throttle linkage and control". So when you add up all incidences of stalling from the various categories, you are over 100 for the 2001 Escape alone. Now add to that the 2002 Escape, the 2001 and the 2002 Tribute. I will bet anything that there are well over 250 complaints of stalling. As a percentage of total vehicles built, you are correct in that it is very small, but 1 in 1,000 is too many for a life threatening problem and is unacceptable for a new $24,000 vehicle.
Thxs.
This is partially true, you can manage to steer and brake the Escape on a stall until you can restart it, when you put some muscle into it. It certainly is not "easy", but not "hard" - if you are expecting it. However, going down a windy hill, and not expecting it, you can easily loose power around a curve and not be able to react to it in time as you swerve into another lane. If you don't think this is a serious problem, well, I would say you sound like a Ford Tech trying to protect the company. I suspect most people would not want to drive a car like this though...
You are right that stalling is a bit more serious than I made it out to be, but none (that I know of) have resulted in a crash. I do believe that most cases have been in very similar conditions and I haven't heard curvy roads being mentioned.
arroyo1, the actual number that have stalling problems is less than 1/2% of all Escapes/Tributes. And on those affected, stalling is pretty rare. Also, for the majority of the vehicles afflicted, a new PCM relay fixed the problem permanently. All manufacturers will produce a lemon every so often and the Escape/Tribute is no different. Your chances are very slim, but if it makes you feel better, try adding language to your sales contract stating something like this:
"Mazda has recognized that a small percentage of Tributes are affected by a stalling problem and there is no known remedy that fixes this problem in all affected vehicles. If this vehicle exhibits this problem and after 3 attempts to fix the problem have not remedied the problem to the customers satisfaction, then this dealership will buy back this vehicle, at selling price minus $0.10 per mile." Your sales contract is just like any other contract - negotiable. Just write that in, initial it and have the sales manager initial it as well. Then sign the contract.
To check on recalls, go to the NHTSA website and you can look up recalls, TSBs, complaints, and more relating to any vehicle sold in the USA.
My 02 Trib gas pedal does not work smoothly. The very first moment when I push the pedal, it does not go, so I have to push it a little harder and then I got hi RPM... kinda hard to keep the car in traffic. I went to the dealer, they cleaned it. It helped for a while, but I got the problem again next month. Went to the dealer. He told me he does not feel that gas pedal works not smoothly...
Please help!! My wife got RAV4 and gas pedal there works very soft. Does anyone else have same problem???
Happy Holidays!
Real world warranty claims on this stalling issue are nowhere near the percentage of vehicles that you would be led to believe on here.
Rich
stalling Escape/Tribute: 1 in 1000 to 1 in 5000.
not really the same.
I was worried when we first purchased it as there were complaints of stalling over the internet. But now, I can say that it's just one of those lemons that those people ended up with. That is very unfortunate. We have already turned some heads on the highway. I thought it was a mini SUV, but when we parked next to the Jeep Cherokee, it's the same size. We love the vehicle's classy design, the spacious cargo space, visibility, and it handles the road very well.
I honestly believe the first production run of Escapes/Tribs were questionable. And if you look closely at the recalls and the numbers and lots involved the number shrinks.
Ford/Mazda have a winner on the table and Ford has the ability to mass produce as many as the market wants. Subaru, Honda, and other competitors don't ahve the ability
It would not crank over at all but seemed to try to engage the starter. The battery "indicator" is green and all seems well electrically. There's oil in the engine. But this does NOT look good. I think the engine may be toast.
2,950 miles and this kind of problem is WHOLLY unacceptable for ANY car. I paid almost $25k for this SUV and I am absolutely apalled that this could happen. It's really too bad because up until this point I have absolutely LOVED this Escape.
2002 Escape XLT 4X4, V6, Auto.
I sense a major engineering flaw here from my experience and that of many others... especially post 1121 from wpooh. The similarities are amazing although I don't remember seeing any smoke. The tranny HAD kicked down to go up the hill from the bridge but the hill wasn't so big that it would require excessive power from the engine.
So I'll take it to the dealer and leave this note for the service department:
CHANGE THE ENGINE, CHECK THE OIL.
TECHY1
road noise from the front door windows, and certainly would like better mpg. My wife
loves the vehicle also. Any others with my
LUCK!!!
Keith
vehicle didn't stick to his argeement and sold the SUV the day it arrived instead of swapping it
with my local dealer. Plus after reading all the problems I was starting to get nervous about
buying one. So I bought a new Chevy Trailblazer LT 4WD and love it. Thanks for all the good
info. and good luck to all of you with Tributes.
Happy Motoring!
I have a 2001 Tribute. I too had a stalling problem (happened twice). My dealer was not helpful, so I called all of the local dealers to see which ones would look at the SUV. I found one and printed off the previous messages about replacing the EEC module and gave it to him. After running tests, he said that was my problem and replaced the part. I haven't had any problems since! Also, when the first stalling problem occurred, I called the Mazda customer hotline and wrote them a letter demanding my money back. A month later, I received a letter back from them to start the buy-back procedures. Since, my car appears to be fixed (I've driven down the same road in which I had the stalling problem several times now), I'm going to keep the Tribute.
Well hopefully Ford will do you guys some justice and get your cars fixed. I think they will, but it may take them time, I heard they were still working on the tire recalls. Good Luck Guys!
Steve
Sorry Steve, can't get that thought out of my head!
Steve
