Pontiac Grand Prix Fuel System
well my heavy foot city mpg is up to 13.2 at 1100miles-would love to end up getting 15+...maybe in time.
also, i travel on rte 295 in s. jersey same stretch every day when i go to work and few times i've tried cruise control at 80mph (b/c of the posts seen here), sometimes DOD has definitely kicked in b/c i'm getting at least the upper 20's and maybe higher (can't remember) mpg, while other times it's lower, but i've noticed more wind resistance.
chats1 sorry about your hum, but mine is not loud and goes off as soon as you turn the car on too...maybe it is onstar.
In the interest of science (ahem) I tried an experiment this AM on the way in to work.
Since the traffic was (much) lighter than usual, I was able to set the cruise at 80 for a few minutes. Twice.
Although there is no “DoD On” indication like there is in the Impala SS, my observations are that even the slightest incline \ upslope (Interstate upslope on I85 just north of I285 and just south is likely less than 1%) will dramatically reduce the instant MPG – from 28 – 30 on level or (very) slight downslope to below 20 MPG.
As always, YMMV.
- Ray
Wishing my every commute could be this light, traffic-wise . .
Tjr GXP :shades:
-Ryan
I read that a good way to verify when the DOD turns on is to put your information display on 'Instant MPG'. That way, you can watch your actual miles per gallon usage as you drive. I have tried this on the highway. Normally it is around 19-24, but after a few minutes if the road stays level you can tell it has turned on because the MPG starts going up to around 30 or more. I think it has to be running at a constant speed for a set amount of time before it kicks on.
Not sure if these two are related or separate problems.
thanks !
1.Rebuilt SuperCharger
2.ACDelco SparkPlugs
3.Wire Set (spark plug)
4.oil change every 3K (oil filter too)
5.New PCV Valve
6.New O2 sensor (before catylic)
7.New Fuel Filter
8.K&N filter and intake
Anyone out that can really help. with any Idea Please EMAIL ME at Sol9586yahoo.com as you can see there has been alot of money invested and im not seeing any progress. 12.2mpg city / and 12.5mpg hwy. HELP!!! HELP!!! HELP!!!
2001 gtp
:confuse:
I purchased & installed a OEM GM sending unit, but it still did the same thing. A few weeks after that my fuel pump went out so I replaced it with 1 from Auto Zone which come with a sending unit attached. I was really hoping this would fix my problem but it hasn't.
So for months now I've been keeping up with my mileage so I dont run out of gas, but this is getting very difficult as HIGH as gas is now.
If anyone can let me know what I need to do, PLEASE HELP ME OUT & DROP ME A LINE.
PLEASEEEE HELP ME !!!!!
it's your mass air flow sensor. Trust me, i've repaired a million already. Easy test is to just unplug the mass air see if it runs fine, if so replace mass air.
I have a 2000 Grandprix SE for my daughter.
I am trying to trouble shoot the exact same problem with the fuel gauge reads full on engine startup and with a couple of minutes goes to empty with the low fuel light on! I even tried swapping out the tank fuel pump assembly with another good unit and still the same issue!
I gave up on the issue after the first time i dropped the tank down, to find out the fuel pumps are different. I work for Autozone, and I did some research. I have the same fuel pump, that goes with the GTP model. I picked up the unit for the GT. It was a pain in the royal, dropping the tank, to find this out. I use the odometer to keep an idea of how much fuel I have. I get roughly 280 miles on a tank. Let me know what you come up with.
I stopped by my local dealership today and asked about other possible causes for the fuel gage reading incorrectly. The next step after replacing the fuel sender unit and still having the gauge read incorrectly is to trace the wiring up to the front car. Looking for burned spots or animal chew spots in the wiring. The service manager did say they have a special tool to flash the gauge cluster to test for functioning. Cost is $25.00 I would imagine there would be an additional labor charge too.
