Chevrolet Impala Brakes
A quick question, is the ABS on a 04 Implala just on the front wheels or both the front and back.
Thanks in advance
Chris
Thanks in advance
Chris
Click on the "how to" button on the left of the screen, and the first thing listed there is how to adjust the parking brake. Granted, this is for the previous generation Impala, but it might still be applicable to the '06.
Is there a problem with the new pads and rotors? Also, it rained the night I got them installed and the next day they were full of rust!
Here is the procedure from the GM Manual.
Park Brake Adjustment
Tools Required
J 21177-A Drum-to-Brake Shoe Clearance Gage
1. Apply and fully release the parking brake six times.
2. Verify that the parking brake pedal releases completely.
-Turn ON the ignition. Verify that the BRAKE indicator lamp is off.
-If the BRAKE indicator lamp is on, ensure that: the parking brake pedal is in release mode and fully returned to stop. Remove the slack in the front parking brake cable by pulling downward on the cable.
3. Raise and suitably support the vehicle. Refer to Vehicle Lifting.
4. Remove the rear tire and wheel assemblies.
5. Remove both rear caliper brackets.
6. Relieve tension on the park brake system at the park brake equalizer.
7. Remove both rear brake rotors.
8. Set the J 21177-A inside of the park brake drum at the widest point.
-Place the contacts on the tool to the widest point of the drum.
-Tighten the set screw on the tool to ensure the proper measurement when removing the tool from the drum.
9. Position the J 21177-A over the park brake shoe at the widest point.
10. brake shoe just contacts the J 21177-A.
11. Repeat steps 8-10 for the opposite side.
12. Install both rear brake rotors.
13. Install both rear caliper brackets.
14. Install the rear tire and wheel assemblies.
15. Adjust the parking brake by turning the nut at the equalizer while spinning both rear wheels. When either rear wheel starts to drag, back off the nut one full turn.
16. Lower the vehicle to curb height.
17. Apply the parking brake, then inspect for rotation of the rear wheels. If the rear wheels rotate during this inspection, then readjust the parking brake shoes.
18. Release the parking brake. Verify that the wheels rotate freely.
19.Lower the vehicle.
My sister just had an accident where she failed to negotiate a turn. She told me that the whole time she was approaching the guard rail that she inevitably hit, the only thought going through her mind was, "don't hit the brakes, don't hit the brakes!" She was taught this over 30 yrs ago and just wasn't fully aware of the capabilities of modern cars. Most likely, if she HAD used her brakes, there would've been no accident at all.
Those of us who try to stay informed often assume that everyone knows of these (now) extremely common safety features on cars. However, you'd likely be surprised to find out how many have no idea.
Thanks for your concern. Yes, she is fine (and so is her grandaughter). The car had $3K in damage, I believe, but she was fully insured.
The repairs only took a couple days however, they did notice the new bumper had not lined up evenly. The body shop said it isn't possible to get it even but I wholeheartedly disagree. She's not the confrontational type but I think she's going to get her husband involved. I told her to tell her insurance company about it as they would very likely demand it be done right. Any thoughts?
Ron
I agree with your assessment. I think the body shop is just attempting to say, "It's too hard to get it right and I don't want to put that amount of effort in it." I think the insurance company should support your sister; the intent is to return it to "as good as new" condition. If they accept less than quality work, where do they draw the line--shabby paint (orange peel, over-spray, thin color coat, etc), uneven filling/sanding, mis-matched colors? Granted, those are extreme examples, but if they accept less than quality in any area, then they're setting themselves up for any or all of the above. Your sister pays insurance premiums based on the understanding that damages will be corrected; my interpretation of correct is "unable to distinguish that a repair has been made." Regards, Clark
It's about my 2007 Impala LT.
It didn't happend until couple of months ago.
Whenever I parked my car, my Impala tends to slide a bit. I mean a lot compared to the other cars.
So I took to the services but they told me that it's normal. One guy even told me that it's a 'feature', called something-brake-system. Two different service shop, same opinion; no problems found.
Everyone in my family noticed the sliding. Some says not much, but I feel it almost every time when I park. Over the years, our family owned 8 different cars, 4 of them Chevy, but never had this kind of problem/issue/feature(?).
So I did a little testing. I parked my Impala on a flat surface, then pushed the car car a little. Even with not alot of force, the body slided quite a few inches. I tested with other cars that was parked on our house but no other cars moved as much as my Impala. I told this to the service but they told me that every car is different and there's nothing we can do about it. They adviced to use parking brake, but come on..
Am I being too sensitive? Is it really nothing to worry about?
Thanks for any replies.
I would agree with your service reps. This is completely normal and different makes/models will "roll" a little more or less than each other. I wouldn't be concerned unless you hear a "ratcheting" sound like the vehicle is slipping out of it's parking gear.
As for the parking brake, anytime you park on an incline, you should be in the habit of using it. Not just for the added safety but for the reduced stress on the transaxle. Although it will hold in almost every case, it's not actually designed for that much stress. It will also be easier for you to get the car into gear when you leave.
Big Bill
Be sure the wheel nuts are tightened to spec and tightened in proper order.
Big Bill
My repair manual states 100 ft-lbs of torque.
thanks bill
