Chevrolet Malibu Brakes
in Chevrolet
Hi All,
In October 05, I purchased my Malibu LT V6...Two weeks after my purchase I began to hear a sqeeling noise upon comming to a stop...Upon placing the car in reverse I began to hear grinding...In short I have taken my car back to the dealership 3 times for the same problem and I am being told that these are GM's top of the line brakes and as lond as they have 66% or more of usage left, GM REFUSES to replace them...Has anyone had this problem?? Please-Please-Please HELP!!!! :lemon:
:mad:
When it's raining out or very damp mine make a nasty kind of vibrating/squaking noise when applied in reverse. I dont think much of it, once they're dried out the noise isnt there. They're very quiet brakes otherwise.
Other than that, my brakes are very good and as smooth as silk.
If brakes were wet and allowed to dry, the rotors would develop some rust and the brakes were noisy when applied. After a few applications, the noise stopped (I assume the rust was ground off by the pads).
It sounds like rotors, except it is too intermittent. And just last week I did take the car in for regular service and they checked the brakes and other than some uneven wear they're fine. They did do a brake service.
I didn't tell them about the problem then, cause it was so intermittent and hadn't been doing it for a while. But now, it does it almost every other day.
Because it is so intermittent, I'm afraid that they won't be able to spot the problem. Any thoughts would be appreciated.
Joe
I have an '01 Malibu and it did the same thing yours is doing right off the lot with 3 miles it. It kinda sounds like a trolley car coming down the street. khhhhhh___, right ? The car would not stop !
Then the rotors warped after the first 3,000 miles.
The dealership gave me a hard time about it and said that GM's fix is to use ceramic brake pads but I would have to pay for the uprgraded pads not the standard pads and they would cut my rotors not replace them.
And that the warping problem is due to overheating because of a bad runout alignnment between the rotor and the caliper.
The fix for that is to not overtighten the lug nuts and clean and adjust the rear brakes.
Isn't that special.
I've also noticed that the brake's rotors get excessive rust after only one night when put away wet... especially if it is salty wet. This is also much worse on the Maxx than on any other car I've owned. It makes the brakes rub and howl for the first few appications of the pedal. Again, my Taurus never had this issue.
I think GM is using some really poor quality material for their rotors. Probably cheap Chinese castings.
I'm looking forward to replacing them when out of warranty with something better... maybe something cross drilled if I can find them that way. Meanwhile I'll let GM keep fixing them. :shades:
I've just purchased a set of Pro Stop drilled and slotted rotors to combat the constant issue of warped/soft rotors that GM is put on my 2005 LS Malibu.
They weren't cheap, $400 for a set of 4, but I'm anticipating less squealing, longer rotor life and cooler brakes. Plus, they're made not to rust and a nice 12,000 mile warranty.
As soon as I brake them in, I'll let you know if they were worth it.
Bulletin No.: 05-05-26-002A
Date: September 22, 2006
TECHNICAL
Subject:
Squeak or Creak Type Noise From Rear of Vehicle (Replace Park Brake Cable Grommets)
Models:
2005-2007 Chevrolet Malibu (Sedan Only)
with Rear Drum Brakes (RPO J41 or JM4)
Supercede:
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 05-05-26-002 (Section 05 - Brakes).
Condition
Some customers may comment on a squeak or creak type noise coming from the rear of the vehicle. This noise occurs at slow speeds while driving over small bumps and is most apparent when the underbody of the vehicle is wet.
Cause
This condition may be caused by the park brake cables rubbing or slip-sticking on the retainer grommet.
Correction
Replace both existing white parking brake cable grommets with new black grommets, P/N 15807015, using the procedure below. These new black grommets are made from a Teflon(R) material.
Raise and support the vehicle.
Open the underbody clip (2) to provide some slack in the parking brake cable. Use a flat bladed tool to release the lock tab. Use care not to permanently bend the parking brake cable. If the cable becomes bent, it must be replaced. Remove the white grommet (1) from the bracket. Pull the park brake cable inboard, gripping the cable on both sides of the grommet.
Use pliers to remove the white grommet from the cable.
Line up the new black grommet slot with the cable and compress onto the cable using pliers.
Install the black grommet into the bracket.
Reinstall the parking brake cable into the underbody clip.
Repeat the steps above for the other side.
Lower the vehicle.
as for squeeling brakes, parking on concrete when it is damp usually causes this. unsure why? but i have noticed that, suppose the concrete keeps the moisture in and around.
also, talk about warped roters, got a pontiac GTP that wew got in on trade for (DAH a malibu) and that sucker has horrible warped roters! so bad it makes the whole stering wheel shake! good think i am almost done rebuilding my 06 malibu maxx ss then can replace those roters.
Driving to work today, just got off the highway, slowing on the ramp, when my car wouldn't stop. I had the brake pedal pressed all the way down, and the car kept inching forward. I wasn't sliding on ice...I just kept inching.
There was a car in front of me, so, not wanting to rear end him, I pushed into Park. Not sure how wise that was. It did stop the car with centimetres to spare! As soon as I shifted into park, though, it made a nasty growling sound and the parking brake light came on.
When traffic started moving, I shifted out of park, noise went away, parking brake light went off and braking was normal.
Drove back home trepidatiously, but had no problem at all.
I suppose I have to go back to the dealer (was there just last week to deal with my remote start issue).
Should I be concerned? Any ideas? Just a one-off glitch? My fear is that it's working properly and they won't diagnose anything.
If you do you will need a ABS capable scanner to activate the ABS valves to bleed.
http://i45.photobucket.com/albums/f98/gonogo/1365685Picrearcaliperretracttool.jp- g
I've been having a little problem with my brake pedal that I can't quite understand yet. Sometimes when I turn my car on, I'll hear a grinding noise from the brake pedal. Other times, I may need to push the brake all the way in with force in order to shift out of park.
The other day, a man stopped me and asked if my emergency brake was in. I told him no, and he proceeded to tell me that I had travelled through about 6 redlights and my brake light never went out while he was behind me. If I gave my pedal another forceable push, things would go back to normal for a few seconds; then my brake light would come on by itself again.
Someone at a dealership told me months ago he thought my Brake Sensor Module (the $20 part that goes under the dash) was going bad. I just now had it replaced.
I got through a day, then the light came on by itself again. Curiousity caught me, so I parked the car and used my pedal adjustment button to move the pedals back and forth a little bit. Then, boom! It's been fine since.
Why do I have to move the pedals again every once in awhile? Is something going bad? Any thoughts are appreciated. Thanks!
I'm looking at after market rotors from Brembo they are crossdrilled with slots for better cooling. Mine has warped after a road trip to Seattle driving through the Steven's pass ,very steep grade and lots of hot braking which showed the poor quality of the rotors. Just looking for superior braking without warping rotors.
Russ
Now its doing the same thing, intermitting catching, no rhyme or reason, we can be out on the highway and it feels like the emergency brake is on, the brake pedal is extremely sensitive, RPMs are high and I can’t get up to speed, I have to get to the nearest exit quick. Doesn’t happen all the time and I never know when it will catch.
Chevy has no answer for me either; we've been back and forth with them. Same old story, they can't fix it until they can reproduce the problem.
EP
